Home » Modeling » BPEL Designer » How can I validate a bpel model instance using Eclipse.org BPEL code?
How can I validate a bpel model instance using Eclipse.org BPEL code? [message #6981] Mon, 26 February 2007 19:48 Go to next message
Thanks.
Re: How can I validate a bpel model instance using Eclipse.org BPEL code? [message #7010 is a reply to message #6981] Mon, 26 February 2007 21:09 Go to previous messageGo to next message
Originally posted by: nomail.nomail.com
I second this request. I've found web-pages that say IBM has written
extensive BPEL validation and it was implied (but not explicitely stated)
that it would be added to the Eclipse project. So far I have not seen any
validation code in the BPEL CVS repository. Does anyone know if this
validation code has been added to Eclipse and if so, where it can be found?
Roger
Re: How can I validate a bpel model instance using Eclipse.org BPEL code? [message #7056 is a reply to message #7010] Tue, 27 February 2007 21:26 Go to previous message
There is currently no validator that is checked in and part of the BPEL
editor.
One is being worked on.
In due time, it will appear there ... about 70% done.
-m
> stated) that it would be added to the Eclipse project. So far I have
> not seen any validation code in the BPEL CVS repository. Does anyone
> know if this validation code has been added to Eclipse and if so, where
> it can be found?
> Roger
Previous Topic:BPEL 2.0 editor: I don't see compensateScope, validate, and extensionActivity activities in the edit
Next Topic:Extending BPEL Designer
Current Time: Fri Jul 18 05:53:41 EDT 2025
Powered by FUDForum. Page generated in 0.28707 seconds
