Home » Language IDEs » C / C++ IDE (CDT) » Control on loading a program
Control on loading a program [message #77728] Fri, 01 August 2003 00:40 Go to next message
Originally posted by: javaproject_7.hotmail.com
Hello all,
Is it possible to control loading of program to the hardware from CDT?.
I am using Eclipse 2.1 and cdt 1.0.1.
The user may want to terminate loading during the loading process.
But now if we press the terminate button the program completes loading and
then only terminate.
Is it possible to terminate loading so that it properly kills the GDB at
hardware as well as software
side properly?.
Please let us know,
Jose
Re: Control on loading a program [message #77765 is a reply to message #77728] Fri, 01 August 2003 15:47 Go to previous messageGo to next message
Originally posted by: alain.nowhere.ca
Jose wrote:
> Hello all,
Do you mean by loading? when gdb is "running" the program or when
the program is being downloaded to a remote embedded target ?
> side properly?.
I'm probably on the wrong track here, but ...
CDT does not provide any way(yet, well at least not in the open source
CDT, third parties provide this already) to download a program to an
embedded target, so one assume that you have a ".gdbinit" doing some
magic, and then it is probably to late. When you hit the terminate
-gdb-exit is call.
Something to think about, but in CDT-2.0, we are suppose to provide
a mean for target to be downloaded and at this point it should be possible
to interrupt the stream.
Re: Control on loading a program [message #77813 is a reply to message #77765] Mon, 04 August 2003 02:29 Go to previous message
Hi Alian,
"alain" <alain@nowhere.ca> wrote in message news:bgeg4l$gct$1@eclipse.org...
> Jose wrote:
> > Hello all,
I mean downloading program to remote embedded target .
We are using the load command to do this,unsing a ini file.
But this does'nt allow us to terminate while downloading.
Jose
and
> > side properly?.
> -gdb-exit is call.
Previous Topic:Break point at exit
Next Topic:CDT .cpp source file editor Popup menu help needed
Current Time: Tue Nov 04 13:13:35 EST 2025
Powered by FUDForum. Page generated in 0.03218 seconds
