Test guidelines [message #77698] |
Tue, 18 July 2006 15:05  |
Originally posted by: prince.pajero.gmail.com
Is there any documentation which is followed for writing tests for
eclipse components.
Some things like what naming convention to be followed, how to test
classes that require instantiation of other classes(would not want that
if the dependency fails then it be reported as the main plugins failure)
I've found some general JUnit test guidelines, which I've started adding
to the http://wiki.eclipse.org/index.php/Naming_Conventions
under "Test Suit Packages".
But still, if we could have a pattern that is followed by eclipse, then
it would be great.
FUDForum. Page generated in 0.03191 seconds
