Home » Language IDEs » Java Development Tools (JDT) » Mixing Eclipse .2.1 and WSAD
Mixing Eclipse .2.1 and WSAD [message #77678] Fri, 18 July 2003 08:08 Go to next message
Originally posted by: dcorbin.imperitek.com
I have a friend that is stuck on a team using WSAD. Our team uses
Eclipse. Now, I don't know excactly what plugins from WSAD they
actually use, but it is it practical to copy those over to an Eclipse
install, and use all the Eclipse 2.1 features with a handful of WSAD
plugins?
David
Re: Mixing Eclipse .2.1 and WSAD [message #77775 is a reply to message #77678] Fri, 18 July 2003 10:16 Go to previous messageGo to next message
> plugins?
Probably not. WSAD is not running on top of Eclipse 2.1 yet, so WSAD
plugins will very likely break when you try to move them over. There
were some public API changes between 2.0 and 2.1, and WSAD is likely
calling some internal API which has also been changed. In short, you can
try, but expect failure.
Jeff
Re: Mixing Eclipse .2.1 and WSAD [message #77868 is a reply to message #77775] Fri, 18 July 2003 11:57 Go to previous message
Originally posted by: richkulp.NOSPAM.us.ibm.com
It is not "most likely will not work". It is a definite, with no
exception, will not work. The next WSAD that works on Eclipse 2.1.1 is
in process. As per usual IBM policy, no dates are permitted to be given
out until the proper time.
Rich
Previous Topic:Remove All Expression in the Debugger
Next Topic:WindowsXP and Locales
Current Time: Fri Jul 18 18:13:17 EDT 2025
Powered by FUDForum. Page generated in 0.03971 seconds
