Home » Archived » Test and Performance Tools Platform (TPTP) » SampleClient TPTPAgent - Invalid Login Credentials
SampleClient TPTPAgent - Invalid Login Credentials [message #77635] Tue, 18 July 2006 10:10 Go to next message
Originally posted by: martin.schuetz.vmasch.at
I'm trying the TPTPAgent-Sample
( http://www.eclipse.org/tptp/platform/documents/newtechAC/jav adoc/TPTPAgent.java)
to connect to AC and to query all available and runnning agents. I'm using
the same data for the ConnectionInfo-object (host "127.0.0.1" and port
"10002") as in the "Profile"-window via Eclipse (where I can see AC with all
available agents).
Executing the sample, I get the following output:
Connecting to AC..
Error occurred while connecting to
127.0.0.1:org.eclipse.tptp.platform.execution.exceptions.Age ntControllerUnavailableException:
Error: Unable to connect to the Agent Controller.Invalid Login Credentials
I set the AC-network access mode to "ALL" and security enabled to "FALSE"
.... I also configured the AC and tried the connect(ConnectionInfo connInfo,
User user)-method, but it doesn't work.
I'm using Eclipse 3.2.0, TPTP 4.2 and the new technology Agent Controller.
Re: SampleClient TPTPAgent - Invalid Login Credentials [message #77667 is a reply to message #77635] Tue, 18 July 2006 11:56 Go to previous messageGo to next message
You may what to try connecting to the Agent Controller using the old API.
You will be able find a sample of how it is used if you extract the class
AutomationUtil and look at method connect().
AutomationUtil is located in:
/test-results/platform/org.eclipse.tptp.ac.testautomation/sr c/org.eclipse.tptp.ac.testautomation.internal.util
I hope this helps.
-Thay
Re: SampleClient TPTPAgent - Invalid Login Credentials [message #77716 is a reply to message #77635] Tue, 18 July 2006 18:05 Go to previous messageGo to next message
That's documentation for 4.1.0 sample code... how did you get here?
> available agents).
> Connecting to AC..
> Thanks
If you're using that Callisto stuff, you can do as I did
(1) cd
<callisto_install_dir> /eclipse/plugins/org.eclipse.tptp.platform.execution_4.2.0.v 200606140100/src
(2) javac org/eclipse/tptp/platform/execution/samples/TPTPAgent.java -cp
.../tptpcore.jar
(3) java -cp ../tptpcore.jar
oreg/eclipse/tptp/platform/execution/sample/TPTPAgent
I get:
Connecting to AC..
Connected to localhost at port number 10006
Querying Available Agents ...
Available Agents ::org.eclipse.tptp.FileTransferAgent
Available Agents ::org.eclipse.tptp.JavaTimeCollector
Available Agents ::org.eclipse.tptp.legacy.DumpAgent
Available Agents ::org.eclipse.tptp.StressAgent
Available Agents ::org.eclipse.tptp.TimeCollector
Available Agents ::org.eclipse.tptp.legacy.Java
Available Agents ::Profiling
Available Agents ::Agent
Querying Available Agents by type...
Querying Running Agents...
# of Running Agents ::1
Running Agents ::ProcessController
Querying Running Agents by type ...
# of Running Agents ::0
Agent MetaData ::
Agent ID for the agent ac 1
Agent ID for the agent ac true 2
Thay... how do you "query all available and runnning agents" with the
RAC API? I thought that was one of the distinct advantages of the "new
tech AC"!
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Re: SampleClient TPTPAgent - Invalid Login Credentials [message #77732 is a reply to message #77716] Wed, 19 July 2006 02:47 Go to previous messageGo to next message
I started my challenge via
http://www.eclipse.org/tptp/platform/documents/newtechAC/jav adoc/overview-summary.html
.... and I unfortunately mixed different versions.
Now it works,
Thanks!
"Randy D. Smith" <randy.d.smith@intel.com> schrieb im Newsbeitrag
news:e9jlvg$5g1$1@utils.eclipse.org...
>> using the same data for the ConnectionInfo-object (host "127.0.0.1" and
>> port "10002") as in the "Profile"-window via Eclipse (where I can see AC
>> with all available agents).
>> Connecting to AC..
>> Credentials
>> connInfo, User user)-method, but it doesn't work.
>> Controller.
>> Thanks
> (1) cd
> ../tptpcore.jar
> I get:
> Connecting to AC..
> Agent MetaData ::
> Thay... how do you "query all available and runnning agents" with the RAC
> API? I thought that was one of the distinct advantages of the "new tech
> AC"!
> RDS
Re: SampleClient TPTPAgent - Invalid Login Credentials [message #77856 is a reply to message #77732] Wed, 19 July 2006 12:30 Go to previous message
> Now it works,
> Thanks!
I'm glad it works for you. I don't want to belabor the point, but I do
want to prevent anyone else going down this path... can you tell me more
explicitly how you got to the above so that I can bugzilla the
appropriate links to clean things up? I tried going through the main
Documentation link from TPTP, and then through Platform; then tried
through Platform link from TPTP, and then to Documentation... the
variations I tried didn't take me anywhere I saw any newtechAC references.
If you can recall the path you took, I'll try to get it cleaned up. Thanks.
RDS
Previous Topic:Test guidelines
Next Topic:Coverage RAC: missing feature.properties
Current Time: Fri Jul 18 02:04:35 EDT 2025
Powered by FUDForum. Page generated in 0.27619 seconds
