Home » Modeling » BPEL Designer » Extending BPEL Designer
Extending BPEL Designer [message #6960] Mon, 19 February 2007 03:37 Go to next message
Originally posted by: srinathkc.induscorpindia.com
I have a requirement as follows...
Can I extend bpel designer to an application, which will have all
diagramming capabilities like drawinf flowchats, diagrams etc. Something
like Microsoft Visio.
So that i can select an option whether i need to design BPEL or just a
diagram. To which extend this is possible??
Many Thnx
sRiNatH k.c.
Re: Extending BPEL Designer [message #7079 is a reply to message #6960] Tue, 27 February 2007 21:27 Go to previous message
Hmmm ... perhaps you could elaborate on exactly what you need to do.
The BPEL editor using the GEF framework to draw the process map form the
EMF model.
If you wanna draw flowcharts using the same mechanism than look into GEF.
> Many Thnx
> sRiNatH k.c.
Previous Topic:How can I validate a bpel model instance using Eclipse.org BPEL code?
Next Topic:can not update eclipse for BPEL designer installation
Current Time: Tue Jul 22 01:53:36 EDT 2025
Powered by FUDForum. Page generated in 0.46907 seconds
