Background image won't show up on ScrolledForm [message #77573] |
Mon, 10 March 2008 04:31  |
I wrote the following snippet to set background image:
private FormToolkit toolkit = null;
private ScrolledForm form = null;
public void createPartControl(Composite parent)
toolkit = new FormToolkit(parent.getDisplay());
form = toolkit.createScrolledForm(parent);
form.setBackgroundImage(CorePlugin.getInstance().getImage(IP luginPropertiesConstants.WELCOME_IMAGE_BACKGROUND));
form.pack();
Somehow the background image won't show up, is this a known limitation ?
Setya
Re: Background image won't show up on ScrolledForm [message #77895 is a reply to message #77819] |
Tue, 11 March 2008 10:06  |
Originally posted by: fappel.innoopract.com
in the demo we set an image to a label in the banner composite and move
the other components above it using the FormLayout. You may have a look
at the current CVS-Head as Control#setBackgroundImage is now available.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Setya [mailto:jsetya@gmail.com]
Bereitgestellt: Dienstag, 11. März 2008 08:45
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Background image won't show up on ScrolledForm
Betreff: Re: Background image won't show up on ScrolledForm
Rüdiger,
> setBackgroundImage has no (reasonable) implementation. It wasn't
> intended to make this empty API available in the first place.
> However, with the upcoming support of background images on the Control
> widget there is a chance we can implement this.
Thank you for your clarification.
To workaround this limitation I implement the page using browser widget
and put the image in the body element's background.
But this does not work either, the image simply won't show up.
When I browse the html file directly the background image gets displayed
just fine.
In RAP demo I see background image on the upper area, how is this
implemented ?
Setya
FUDForum. Page generated in 0.26828 seconds
