Home » Archived » M2M (model-to-model transformation) » [ATL] MDR compatibility
[ATL] MDR compatibility [message #77556] Wed, 26 March 2008 14:40 Go to next message
Originally posted by: sapinhu.gmail.com
Is it possible to launch an ATL transformation with XMI files exported
from Rational Rose using MDR as model handler?
Which metamodel should I use?
Thanks in advance.
Leandro.
Re: [ATL] MDR compatibility [message #77660 is a reply to message #77556] Thu, 27 March 2008 09:20 Go to previous messageGo to next message
--------------040007000802010703050307
If you use Rational 7 you can directly export your models into UML2.1
models. Then you will be able to use it with any ATL VM (EMF specific or
Regular), as an UML model.
If you can't do that, you can use the MDR model handler in the ATL
Regular VM. That use case will show you how to do that :
http://www.eclipse.org/m2m/atl/usecases/MDL2GMF/
William
Leandro a
Re: [ATL] MDR compatibility [message #77910 is a reply to message #77660] Fri, 28 March 2008 16:56 Go to previous message
Thanks a lot, William!!
Previous Topic:[AM3] Not bundled with ATL?
Next Topic:Set the path for UML source model
Current Time: Fri Jun 27 14:03:43 EDT 2025
Powered by FUDForum. Page generated in 0.03948 seconds
