Will WTP support JBoss 4 ? [message #77549] |
Sun, 27 February 2005 02:58  |
Originally posted by: michael_furman.hotmail.com
Hi!
A short question: Will WTP support JBoss 4?
Michael
Re: Will WTP support JBoss 4 ? [message #90286 is a reply to message #89794] |
Mon, 04 April 2005 22:03   |
Gorkem,
Thanks for finding my bug. I have attached a new version using the property.
Also, thanks explaining the new direction. I needed support in M3 so it was
worth my effort and good for my understanding. Based on the questions in
this newsgroup, I think others needed it for M3 as well. If you would like
me to provide a JBoss 4.0.1 version for M4 let me know.
I like having each vendor provide their own update sites for all the
different extensions. Is the WTP website going to have a list of updates
sites from the different vendors? Will there be a roadmap of suggested
extensions that each of the vendors should provide? I think this would be
helpful for them and encourage them to provide a full and quality set of
plug-ins.
"Gorkem Ercan" <gercan@REMOVEME.acm.org> wrote in message
news:424FAB0E.9040406@REMOVEME.acm.org...
> Hi Christopher,
> I have looked at your .server files. There are some minor things you
> should look at for instance the line
> <classpath id="jboss" isLibrary="true">
> <archive path="C:/devl/jboss-4.0.1sp1/server/${serverConfig}/conf"/ >
> directly refers to a directory where you should be using a property
> instead.
> Also you may want to alter your files so that they are compatible with
> latest generic server. After the M3 release I have changed the generic
> server a little. First, the way we define a server definition in
> plugin.xml is changed. Also the .server files are .serverdef files now
> since they were mixed with the server config files from the server
> tooling core. And I did a few minor changes in the server definition
> structure but they are really minor.
> In the webtools server tooling we have a different approach than lomboz.
> In lomboz we tried to host as much of the server definitions in lomboz
> project. But in the webtools we provide only a few to be examples,
> because a new server definition can be added and updated in its plugin
> using the update manager. So we would like to encourage hosting server
> definition update sites to server vendors and server experts. But In
> this case we are considering changing the current server definition from
> JBoss 3.2.3 to JBoss 4.
> Gorkem Ercan
> Christopher M. Judd wrote:
> > I have created a JBoss 4.0.1 generic server configuration and tested it
with
> > M3. Attached you will find the necessary three files: jboos401.server,
> > jboss401.xml and plugin.xml. They need to be placed in the
eclipse\plugins\org.eclipse.jst.server.generic.serverdefinit ions_1.0.0\serve
> > rs,
eclipse\plugins\org.eclipse.jst.server.generic.serverdefinit ions_1.0.0\build
> > files and
> > respectively.
> > I also created bug 90100 and attached files.
> > "Tim deBoer" <deboer@ca.ibm.com> wrote in message
> > news:d1l4f5$dom$1@news.eclipse.org...
> >>Hi Michael,
> >>Currently we only have support for JBoss 3.2.3 (via the generic server
> >>support). Although we have had some interest and participation directly
> > from
> >>JBoss, this has not yet ended up producing any code. Please let us know
if
> >>you are interested in getting involved.
> > <project name="deployextension" default="deploy.j2ee.web" basedir=".">
> > <target name="deploy.j2ee.web">
> > <jar destfile="${module.name}.war">
> > <zipfileset dir="${module.dir}">
> > <include name="**/*.*"/>
> > <exclude name="**/*.war"/>
> > </zipfileset>
> > </jar>
> > <move file="${module.name}.war" todir="${server.publish.dir}"/>
> > </target>
> > <target name="deploy.j2ee.ejb">
> > <jar destfile="${module.name}.jar">
> > <exclude name="**/*.java"/>
> > <exclude name="**/*.jar"/>
> > </zipfileset>
> > </jar>
> > <move file="${module.name}.jar" todir="${server.publish.dir}"/>
> > </target>
> > <target name="undeploy.j2ee.web">
> > <delete file="${server.publish.dir}/${module.name}.war"> </delete>
> > </target>
> > <target name="undeploy.j2ee.ejb">
> > <delete file="${server.publish.dir}/${module.name}.jar"> </delete>
> > </target>
> > </project>
> > <?xml version="1.0" encoding="UTF-8"?>
> > <?eclipse version="3.0"?>
> > <plugin
> > id="org.eclipse.jst.server.generic.serverdefinitions"
> > name="Serverdefinitions Plug-in"
> > version="1.0.0"
> > provider-name="Eclipse.org"
class=" org.eclipse.jst.server.generic.serverdefinitions.Serverdefin itionsPlu
gin">
> > <runtime>
> > <library name="serverdefinitions.jar">
> > <export name="*"/>
> > </library>
> > </runtime>
> > <requires>
> > <import plugin="org.eclipse.core.runtime"/>
> > <import plugin="org.eclipse.jst.server.generic.core"/>
> > </requires>
> > <extension
point="org.eclipse.jst.server.generic.core.serverdefinition ">
> > <serverdefinition id="Weblogic8.1"
definitionfile="/servers/weblogic81.server">
> > </serverdefinition>
> > <serverdefinition id="JBoss 3.2.3"
definitionfile="/servers/jboss323.server">
> > </serverdefinition>
> > <serverdefinition id="Jonas 4.1.4"
definitionfile="/servers/jonas.server">
> > </serverdefinition>
> > <serverdefinition id="JBoss 4.0.1"
definitionfile="/servers/jboss401.server">
> > </serverdefinition>
> > </extension>
> > </plugin>
Re: Will WTP support JBoss 4 ? [message #90381 is a reply to message #90286] |
Tue, 05 April 2005 16:48  |
Originally posted by: gercan.REMOVEME.acm.org
Hi Christopher,
As I said on the previous posting JBoss 3.2.3 is becoming less common so
I do consider switching our example to a JBoss 4 release please do
continue to provide server definition for M4 and later releases as well.
Having a list of server plugin providers in WTP web site is definitely
something we would have. I am preparing a how to and a plugin project
template plugin that will create all the extensions etc. I am hoping to
have both ready for M4.
Gorkem
> Gorkem,
> plug-ins.
>>Hi Christopher,
>>instead.
>>Gorkem Ercan
> with
>>>rs,
>>>files and
>>>respectively.
>>>>Hi Michael,
>>>from
> if
>>></zipfileset>
>>></jar>
>>></target>
>>></zipfileset>
>>></jar>
>>></target>
>>></target>
>>></target>
>>></project>
>>><plugin
>>> version="1.0.0"
> gin">
>>> <runtime>
>>> <export name="*"/>
>>> </library>
>>> </runtime>
>>> <requires>
>>> </requires>
>>> <extension
>>></serverdefinition>
>>></serverdefinition>
>>></serverdefinition>
>>></serverdefinition>
>>> </extension>
>>></plugin>
FUDForum. Page generated in 0.25088 seconds
