Home » Archived » M2M (model-to-model transformation) » [ATL] ATLTransformations
[ATL] ATLTransformations [message #77534] |
Wed, 26 March 2008 14:27  |
Originally posted by: bravus.martins.yahoo.com.br
I'm trying to execute a transformation programmatically through the
ATLTransformations class. I've modified that class to lauch the
Public2Private example, but I didn't have success.
Thanks for any help.
The code is:
package atl;
import java.io.*;
import java.net.*;
import java.lang.reflect.*;
import java.util.*;
import javax.jmi.reflect.*;
import org.atl.eclipse.engine.*;
import org.atl.engine.extractors.*;
import org.atl.engine.extractors.ebnf.*;
import org.atl.engine.injectors.ebnf.*;
import org.atl.engine.extractors.xml.*;
import org.atl.engine.injectors.xml.*;
import org.atl.engine.repositories.emf4atl.*;
import org.atl.engine.vm.nativelib.*;
import org.eclipse.core.runtime.*;
import org.atl.engine.repositories.mdr4atl.*;
import org.atl.engine.vm.*;
import javax.xml.parsers.SAXParser;
import javax.xml.parsers.SAXParserFactory;
import org.xml.sax.Attributes;
import org.xml.sax.Locator;
import org.xml.sax.SAXException;
import org.xml.sax.SAXParseException;
import org.xml.sax.helpers.DefaultHandler;
* Main class for running ATL transformations programatically (template)
* TODO: Add support for running AM3 Ant tasks
* @author Milan Milanovic (milan [at] milanovic.org)
* @version 2.3
public class ATLTransformations {
// Stop on error in EBNF Injection
private final static boolean stopOnError = !false;
// Relative location of transformations
String transformationsLocation = "";
// Relative location of metamodels
String transformationsMetamodels = "";
// URL's to compiled ATL transformations (an example of OneMM to OtherMM
transformation)
private URL OneMM2OtherMMurl =
ATLTransformations.class.getResource("Public2Private.asm");
// Add here URL's to your other compiled transformations...
// TCS specific (MM is pseudoname for some your metamodel which is used
for TCS injection/extraction)
//private URL MM_tcs =
ATLTransformations.class.getResource("MOF-1.4.xmi");
//private URL TCS = ATLTransformations.class.getResource("TCS.xmi"); //
uses MDR (change to .ecore for EMF)
// MDR model handler
private AtlModelHandler mdramh = null;
// EMF model handler
private AtlModelHandler emfamh = null;
// MDR meta-metamodels
private ASMModel oneMM_MDR = null;
private ASMModel otherMM_MDR = null;
private ASMModel xmlMDRmm = null; // XML metamodel is needed because of
XML injection/extraction
// Add here objects for you metamodels (MDR - MOF-1.4)...
// For TCS (MDR) support
//private ASMModel tcsMDRmm = null;
//private ASMModel mmTcsMDRmm = null;
// Used for keeping metamodel names
Map MDRMetaModels = new HashMap();
// EMF meta-metamodels
private ASMModel oneMM_EMF = null;
private ASMModel otherMM_EMF = null;
private ASMModel xmlEMFmm = null;
// Add here objects for you metamodels (EMF - Ecore)
// For TCS (EMF) support
//private ASMModel tcsEMFmm = null;
//private ASMModel mmTcsEMFmm = null;
// General meta-models
private ASMModel pbmm = null;
// Instance of ATLTransformations class (Singleton)
private static ATLTransformations atlTransformations = null;
// Markers for Problem metamodel
private MarkerMaker markerMaker;
// Constructor
public ATLTransformations() {
initMDR(); // Initialize MDR based metamodels
//initEMF(); // Initialize EMF based metamodels - if needed
} // -- end of constructor
//// General ATL transformation initialization with domain metamodels
specific initialization
* Initialize MDR model handler and MOF based metamodels
private void initMDR() {
if(mdramh == null) { // if MDR is not initialized
// Initialize MDR model handler
mdramh = getDefaultHandler("MDR");
// URL's to MOF-1.4 (XMI) metamodels
URL onemmurl = ATLTransformations.class.getResource("UMLDI.xmi");
URL xmlmmurl = ATLTransformations.class.getResource("xml.xmi");
URL othermmurl = ATLTransformations.class.getResource("UMLDI.xmi");
// Add here URL's to your metamodels (MDR - MOF-1.4)...
try {
// Get metamodels
oneMM_MDR = mdramh.loadModel("UMLDI", mdramh.getMof(),
onemmurl.openStream()); // ONE MM
xmlMDRmm = mdramh.loadModel("xml", mdramh.getMof(),
xmlmmurl.openStream()); // XML MM
otherMM_MDR = mdramh.loadModel("UMLDI", mdramh.getMof(),
othermmurl.openStream()); // Other MM
// Load your metamodels here...
// Only for TCS output!!
//tcsMDRmm = mdramh.loadModel("TCS", mdramh.getMof(),
TCS.openStream()); // TCS MM
//mmTcsMDRmm = mdramh.loadModel("MOF-1.4", tcsMDRmm,
MM_tcs.openStream()); // MM-TCS MM
// Put metamodels in map for easy lookup
MDRMetaModels.put("OneMM", oneMM_MDR);
MDRMetaModels.put("XML", xmlMDRmm);
MDRMetaModels.put("OtherMM", otherMM_MDR);
//MDRMetaModels.put("TCS", tcsMDRmm);
//MDRMetaModels.put("MOF-1.4", mmTcsMDRmm);
} catch (IOException e) {
e.printStackTrace();
} // -- end of initMDR
* Initialize EMF model handler and Ecore based metamodels
private void initEMF() {
if(emfamh == null) { // if EMF is not initialized
// Initialize EMF model handler
emfamh = AtlModelHandler.getDefault(AtlModelHandler.AMH_EMF);
// URL's to Ecore (XMI) metamodels
URL onemmurl =
ATLTransformations.class.getResource(transformationsMetamode ls +
"oneMM/oneMM.ecore");
URL xmlmmurl =
"xml/xml.ecore");
URL othermmurl =
"otherMM/otherMM.ecore");
// Add here URL's to your metamodels (EMF - Ecore)...
try {
// Get metamodels
oneMM_EMF = emfamh.loadModel("OneMM", emfamh.getMof(),
xmlEMFmm = emfamh.loadModel("XML", emfamh.getMof(),
otherMM_EMF = emfamh.loadModel("OtherMM", emfamh.getMof(),
//tcsEMFmm = emfamh.loadModel("TCS", emfamh.getMof(),
//mmTcsEMFmm = emfamh.loadModel("MM.tcs", tcsEMFmm,
pbmm = emfamh.getBuiltInMetaModel("Problem");
markerMaker = new MarkerMaker();
} // -- end of initEMF
* Returns default model handler (currently supported MDR and EMF)
* @param repository String which represents model handler
* @return default repository for input (EMF or MDR)
private AtlModelHandler getDefaultHandler(String repository) {
AtlModelHandler amh = null;
try {
amh = AtlModelHandler.getDefault(repository);
} catch (Throwable e) {
if ("MDR".equals(repository)) {
AtlModelHandler.registerDefaultHandler("MDR", new
AtlMDRModelHandler()); // register
} else {
throw new RuntimeException(e);
return amh;
} // -- end of getDefaultHandler
* Returns static instance of ATLTransformations class (Singleton)
public static ATLTransformations getATLTransformations() {
if(atlTransformations == null)
atlTransformations = new ATLTransformations();
return atlTransformations;
* Check if input XML file is well-formed - helper method
* @param file path to input XML file or XML code
* @param isFile if it is true then it is path to file, otherwise it
is String that contains XML code
* @return true if input XML file is well formed, otherwise is false
private boolean checkForWellFormedness(String file, boolean isFile)
SAXParser saxParser = null;
DefaultHandler dh = null;
InputStream in = null;
// init parser
try {
SAXParserFactory spfactory = SAXParserFactory.newInstance();
saxParser = spfactory.newSAXParser();
dh = new DefaultHandler();
catch(Exception e) {
System.out.println("Cannot initialize SAX parser.");
return false;
// parse the XML document using SAX parser
try {
if (isFile == true) { // it is file
in = new FileInputStream(file);
else { // it is String that contains XML code
byte currentXMLBytes[] = file.getBytes(); // Get bytes from input
String
in = new ByteArrayInputStream(currentXMLBytes);
saxParser.parse(in, dh); // SAXException, IOException
catch(SAXParseException spe) { // Document is not well-formed: Error
System.out.println("Document is not well-formed.");
return false;
catch(SAXException se) { // (*)
System.out.println("Error while parsing input XML file: " + file);
se.printStackTrace();
return false;
catch(FileNotFoundException f) {
System.out.println("Error: File is not found-1");
return false;
catch(IOException ioe) {
System.out.println("Cannot read file.");
return false;
return true;
} // -- end of checkForWellFormedness
* Inject input XML file to XML model (instance of XML metamodel - MOF
1.4)
* Note: if you want to use EMF, just change 'mdramh' to 'emfamh' and
'xmlMDRmm' to 'xmlEMFmm'
* in this method, and also in other methods if needed.
* @param file name of file from which XML model will be created
* @return created XML model from input file
public ASMModel injectXMLModelFromFile(String file) {
initMDR(); // if MDR is not initialized, do it now !
ASMModel ret = mdramh.newModel("IN", xmlMDRmm); // create new output
model with XML metamodel (MOF-1.4)
XMLInjector xmli = new XMLInjector(); // create XML injector
Map parameters = Collections.EMPTY_MAP; // no parameters
try {
xmli.inject(ret, in, parameters); // Do injection !
} catch(FileNotFoundException f) {
System.out.println("Error: File is not found-2");
} catch(IOException io) {
System.out.println("Error: in injection of XML file");
return ret;
} // -- end of injectXMLModelFromFile
* Convert input String which contains XML code to XML model (instance
of XML metamodel - MOF 1.4)
* @param inputString String which contains XML
* @return created XML model from in XML code
public ASMModel injectXMLModelFromString(String inputString) {
// Get bytes from input String
byte currentXMLBytes[] = inputString.getBytes();
InputStream in = new ByteArrayInputStream(currentXMLBytes);
try {
} catch(IOException io){
io.printStackTrace();
return ret;
* Extract input XML model (instance of XML metamodel - MOF 1.4) to
XML file
* @param model input XML model which will be extracted to XML file
* @param file output XML file in which input XML model will be
extracted
public void extractXMLModelToFile(ASMModel model, String file) {
initMDR();
OutputStream out = null;
XMLExtractor xmle = new XMLExtractor();
try {
out = new FileOutputStream(file);
xmle.extract(model, out, parameters); // Do extraction !
out.flush(); out.close(); // close stream
System.out.println("Error: File is not found-3");
System.out.println("Error: in extraction of XML model to XML file");
} // -- end of extractXMLModelToFile
String
* @return input model returned as String
public String extractXMLModelToString(ASMModel model) {
initMDR();
OutputStream out = null; String ret = null;
try {
out = new ByteArrayOutputStream();
ret = out.toString();
System.out.println("Error: File is not found-4");
return ret;
// An example EBNF inject/extract methods for some MM metamodel (this
should be changed for every metamodel)
// Note: you should have generated MM-ebnfinjector.jar and putted
// in into classpath with other libs
* Extract input MM model (instance of some MM metamodel - MOF 1.4) to
File
* @param MMModel input MM model which will be extracted to File
* @param file path to the file in which will be extracted input MM model
public void saveMMModelToFile(ASMModel MMModel, String file) {
initMDR();
Extractor ext = new EBNFExtractor();
Map params = new HashMap();
params.put("format", MDRMetaModels.get("MM-TCS"));
params.put("indentString", "\t");
try {
ext.extract(MMModel, out, params); // do it!
} catch(Exception e) {
} // -- end of saveMMModelToFile
* Deserializes a MM model from a File. (works with MDR, but if it is
needed, just change to EMF)
* @param file is the MM file.
* @return the MM model that is injected from input MM code.
public ASMModel getMMFromFile(String file) {
initMDR(); // if MDR (and EMF) is not initialized, do it now !
ASMModel ret = mdramh.newModel("IN", oneMM_MDR); // create new output
model with OneMM (or some your MM) metamodel
EBNFInjector2 ebnfi = new EBNFInjector2();
try {
//Class lexer = MMLexer.class; // This are your generated classes
//Class parser = MMParser.class;
//ebnfi.performImportation(oneMM_MDR, ret, in, "MM", lexer, parser);
in.close();
System.out.println("Error: File is not found-5");
System.out.println("Error: in injection of MM file");
// TODO: Check for problems with: int nbPbs =
markerMaker.applyMarkers(file, pbs); ...
return ret;
} // -- end of getMMFromFile
* Launch ATL transformation
* @param modelHandler model handler which is used for creating output
model
* @param transformation URL to compiled ATL transformation
* @param inputModel input model for transformation
* @param inputMetamodel input metamodel for transformation
* @param outputMetamodel output metamodel for transformation
* @param inParams additional parameters for transformation
* @param inLibs additional libraries for transformation
* @throws IOException
public ASMModel runATLTransformation(AtlModelHandler modelHandler, URL
transformation, ASMModel inputModel,
ASMModel inputMetamodel, ASMModel outputMetamodel, Map
inParams, Map inLibs) throws IOException {
initMDR(); // Initialize MDR model handler
ASMModel ret = null; // return model
// Set launch configuration
Map models = new HashMap();
models.put(inputMetamodel.getName(), inputMetamodel); // input metamodel
models.put(outputMetamodel.getName(), outputMetamodel); // output
metamodel
models.put("IN", inputModel); // input model
ret = modelHandler.newModel("OUT", outputMetamodel); // output model
models.put("OUT", ret);
Map params = inParams; // Parameters
Map libs = inLibs; // Libraries
// Launch ATL transformation
AtlLauncher.getDefault().launch(transformation, libs, models, params);
return ret;
} // -- end of runATLTransformation
* Load model from file (XMI) as MOF-1.4
* @param file name of file which containts input model
* @param inputMetamodel input metamodel (as String)
* @return model which is constructed from input file
public ASMModel loadMDRModelFromFile(String file, String inputMetamodel) {
// Initialize MDR
initMDR();
// Get metamodel from map
ASMModel metamodel = (ASMModel)MDRMetaModels.get(inputMetamodel);
try {
// Create input stream from file
} catch(FileNotFoundException e) {
System.out.println("Error: Input file is not found!");
return null;
return mdramh.loadModel(file, metamodel, in);
} // -- end of loadMDRModelFromFile
* Save model to file (XMI) as MOF-1.4
* @param inputModel input model for saving to file
* @param file name of file in which model will be saved
public void saveMDRModelToFile(ASMModel inputModel, String file) {
// Bridge actual problem of saving model outside of Eclipse environment
ASMMDRModel model = (ASMMDRModel)inputModel;
try {
// Create output stream
// Save model
model.save(out);
System.out.println("Error: output file can't be created");
System.out.println("Error: model can't be saved to file");
} // -- end of saveMDRModelToFile
* Converts MDR ASMModel to String
* @param MOFmodel input model for converting to string
* @return String which containts input model
public String MOFModelToString(ASMModel MOFmodel) {
ByteArrayOutputStream out = new ByteArrayOutputStream();
String ret = null;
try {
// Save model
((ASMMDRModel)MOFmodel).save(out);
out.flush();
out.close();
System.out.println("Error: model to string");
return ret;
} // -- end of MOFModelToString
//// Specific transformations
* Run OneMM to OtherMM (example) ATL transformation (OneMM2OtherMM).
* Note: MDR is used as model handler, if you want to use EMF, just
* @param oneModel input ONE model
* @return output (cleaned) OtherMM model
public ASMModel getOtherMMFromOneMM(ASMModel oneModel) throws IOException
// If you need library, you can add it in following way:
// e.g., Map libs = new HashMap();
// libs.put("XMLHelpers", XMLHelpersurl);
// And you just have to add this 'libs' object instead of the last
Collections.EMPTY_MAP below
// Run transformation and return output model
return runATLTransformation(mdramh, OneMM2OtherMMurl, oneModel,
oneMM_MDR, otherMM_MDR, Collections.EMPTY_MAP, Collections.EMPTY_MAP);
} // -- end of getCleanedXMLFromXML
* Transform input One (XML-based) file to output Other (XML-based) file
- an example with injection/extraction
* @param InputOneFile name of input One XML file
* @param OutputOtherFile name of output Other XML file
* @return Result of running this transformation
public String transformOnetoOther(String InputOneFile, String
OutputOtherFile) throws IOException {
// Check is input String well-formed (XML)
if (!checkForWellFormedness(InputOneFile, true)) return new
String("Document is not well-formed.");
ASMModel xmlModel = injectXMLModelFromFile(InputOneFile); // One XML ->
XML model
ASMModel otherModel = getOtherMMFromOneMM(xmlModel); // One XML ->
Other
extractXMLModelToFile(otherModel, OutputOtherFile); // Other -> Other
XML
return new String("OK");
} // -- end of transformOnetoOther
//// Main method - used only for testing this class
public static void main(String [] arguments) throws IOException {
// Create new instance of this class
ATLTransformations transformation =
ATLTransformations.getATLTransformations();
// Transform input file to output file
String message =
transformation.transformOnetoOther("src/atl/PetriNet.xmi",
"src/atl/PetriNet-private.xmi"); // Message is OK if all goes well
// or document is not well-formed
Re: [ATL] ATLTransformations [message #79800 is a reply to message #79785] |
Tue, 22 April 2008 13:54  |
Hello again,
Where should I put the file paths in these classes to launch an ATL
transoformation?
(Sorry, I've been having some difficulties to solve it :( )
John
Current Time: Tue Jul 22 00:41:29 EDT 2025
Powered by FUDForum. Page generated in 0.46237 seconds
