Set the path for UML source model [message #77503] |
Wed, 26 March 2008 10:36  |
I use ATL for model transformation. Both the source and target metemodels
are UML. The source model is a UML file created by Papyrus tool. When I
run a new ALT configuration and try to set the path for the model, it
doesn't show the UML file. It shows the ecore files only.
There are many use cases in ATL website specify the source models in UML
file.
How can I set the path for UML source model and for UML metamodel using
"uri:http://www.eclipse.org/uml2/2.0.0/UML"/
Any help is greatly appreciated,
Rasha
Re: Set the path for UML source model [message #77808 is a reply to message #77776] |
Fri, 28 March 2008 06:03   |
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Rasha,
You can get the latest version of ATL from
http://www.eclipse.org/modeling/m2m/downloads/index.php?proj ect=atl
Don't worry about the versions of Eclipse, EMF and UML2 which are
mentioned on this page. As far as we know, this latest ATL version works
properly with Eclipse 3.3, EMF 2.3 and UML2 2.1 (this is one of the
configuration I'm also using).
Hugo
Rasha a écrit :
> Hi Hugo,
> Thanks so much for your help. The problem that I don�t have the same ATL
> launch configuration wizard as yours. The one I get is the same as in
> the ATL Starter�s Guide file. Unfortunately, there is no way to attach
> the figures. In this wizard, I don�t have the "EMF Registry" button. I
> set the path for the UML2 metamodel by clicking on the �Metamodel by
> URI� and select http://www.eclipse.org/uml2/2.0.0/UML from the list. I
> don�t have also "Workspace" buttons. The only choice to set the
> source/target model path is through the set path which only shows the
> ecore files. I followed the installation steps as in the
> ATL_Installation_Guide file. How can I get your ATL launch configuration
> wizard? Is there is another update version of ATL I have to install? I
> have already the UML2 plugins installed in my Eclipse.
> I greatly appreciate your help,
> Rasha
Hugo Bruneliere - R&D Engineer
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: Hugo.Bruneliere@univ-nantes.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: Set the path for UML source model [message #77925 is a reply to message #77879] |
Sun, 30 March 2008 11:28  |
Originally posted by: freddy.allilaire.univ-nantes.fr
--------------000507070007050001080200
Content-Type: text/plain; charset=UTF-8; format=flowed
Hi Rasha,
Maybe your project doesn't have ATL nature.
Freddy.
Rasha a écrit :
> Hi Hugo,
> Thanks so much, I got now the same configuration as you. But when I
> created a new ATL file, it didn�t create the corresponding asm file as
> the old version does. Is this OK or there is something wrong?
> Thanks again for your help and have a great weekend,
> Rasha
Content-Type: text/x-vcard; charset=utf-8;
name="freddy.allilaire.vcf"
Content-Disposition: attachment;
filename="freddy.allilaire.vcf"
YmVnaW46dmNhcmQNCmZuOkZyZWRkeSBBbGxpbGFpcmUNCm46QWxsaWxhaXJl O0ZyZWRkeQ0K
b3JnOk9CRU8NCmFkcjo7OztOYW50ZXM7OzQ0NDAwO0ZyYW5jZQ0KZW1haWw7 aW50ZXJuZXQ6
ZnJlZGR5LmFsbGlsYWlyZUBvYmVvLmZyDQp0aXRsZTpSJkQgRW5naW5lZXIN CnVybDpodHRw
Oi8vd3d3Lm9iZW8uZnINCnZlcnNpb246Mi4xDQplbmQ6dmNhcmQNCg0K
--------------000507070007050001080200--
FUDForum. Page generated in 0.64335 seconds
