Home » Newcomers » Newcomers » Error: The jar file rt.jar has no source attachment
Error: The jar file rt.jar has no source attachment [message #77477] Mon, 13 June 2005 12:17 Go to next message
i am working with J2ee 1.4.01 and eclipse 3.0.1 on Windows XP.
When i start to debug the application i'm writing the debugger stops in
ResourceBundle.class -> Class File Editor with the message:
Source not found
The jar file rt.jar has no source attachment.
You can attach the source by clicking Attach Source below
In other newsgroups i read, that i have to attach to the file src.zip
but there is no such file on the whole harddisc. I only found files like
editorssrc.zip or jdisrc.zip and so on in the eclipse installation path.
Is there any difference between J2ee and J2se?
Which other file can i attach the rt.jar?
Thank you for a tip.
Regina
Re: Error: The jar file rt.jar has no source attachment [message #77509 is a reply to message #77477] Mon, 13 June 2005 13:16 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Regina,
Did you install the JRE or the JDK? The java source is not included in
the JRE. If you have the JDK installed, make sure your installed
runtimes (Preferences->Java->Installed Runtimes) points to the JDK
directory, not the JRE directory.
Hope this helps,
- Jeff
user@domain.invalid wrote:
> Source not found
> Regina
Re: Error: The jar file rt.jar has no source attachment [message #77524 is a reply to message #77509] Mon, 13 June 2005 13:55 Go to previous messageGo to next message
Originally posted by: regina.gebuehr.freenet.de
Hi Jeff,
i installed the J2ee SDK and my installed runtimes points to the JDK
directory, concrete: D:\Sun\AppServer\jdk.
There is no src.zip in this directory. Where can i get this file?
Thank you for your help.
Regina
Re: Error: The jar file rt.jar has no source attachment [message #77553 is a reply to message #77524] Mon, 13 June 2005 14:21 Go to previous message
Regina,
I don't know if the J2EE SDK includes source code. The src.zip file
you're looking for is included in the J2SE SDK installation.
- Jeff
Regina Gebuehr wrote:
> Hi Jeff,
> Regina
Previous Topic:ArrayList<String> list = new ArrayList<String>() ungültig?
Next Topic:Conflict between JDBC and SWT in Eclipse 3.0
Current Time: Tue Jul 22 01:48:32 EDT 2025
Powered by FUDForum. Page generated in 0.09819 seconds
