Home » Eclipse Projects » GEF » Editor with Context-Menu/ActionBar
Editor with Context-Menu/ActionBar [message #77454] Wed, 30 April 2003 10:45 Go to next message
Originally posted by: junost.gmx.de
Hello
I need a ContextMenu and a ActionBar in my Editor. So I tried to take over
these things from 'Logic Example'. But it doesn't work.
I wrote two classes, which extends 'ActionBarContributer' and
'ContextMenuProvider'. I also implemented the 'createAction' -method in my
'SymbolEditor'-class.
What other classes from the 'Logic Example' need to be implemented?
Thank you
Alexander M
Re: Editor with Context-Menu/ActionBar [message #77470 is a reply to message #77454] Wed, 30 April 2003 11:40 Go to previous messageGo to next message
Are either of these classes being created? Or is it a problem of
appropriate methods not being called? Does your plugin.xml reference
your ActionBarContributor subclass?
From logic example's plugin.xml:
contributorClass=" org.eclipse.gef.examples.logicdesigner.actions.LogicActionBa rContributor "
Eric
Alexander Müller wrote:
> Hello
> Thank you
> Alexander Müller
Re: Editor with Context-Menu/ActionBar [message #77501 is a reply to message #77470] Wed, 30 April 2003 12:06 Go to previous messageGo to next message
Thank you, I forgot the changes in 'plugin.xml'. ActionBar works now.
Do I need an entry in 'plugin.xml' for the Context-Menu?
Alexander M
Re: Editor with Context-Menu/ActionBar [message #77551 is a reply to message #77501] Wed, 30 April 2003 12:52 Go to previous message
"Alexander M
Previous Topic:Mapping model elements to EditParts
Next Topic:Multi-page printing
Current Time: Sun Aug 31 07:44:16 EDT 2025
Powered by FUDForum. Page generated in 0.04304 seconds
