Home » Eclipse Projects » Equinox » Startup order effecting servlet registration classloader
Startup order effecting servlet registration classloader [message #77396] Thu, 16 November 2006 20:55 Go to next message
Hey,
I have a servlet that I'm trying to run under equinox but it's behaving
differently on two separate servers.
The difference between the two seems to be with the startup ordering of
the org.eclipse.equinox.servlet.bridge.http bundle and the servlet bundle.
Depending on which one starts first the servlet will either be
registered with a
org.eclipse.core.runtime.internal.adaptor.ContextFinder class loader or
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.
The ContextFinder if the servlet bundle is started first, and
DefaultClassLoader if the bridge is started first.
It appears that the servlet can't find some resources when starting with
the DefaultClassLoader but it can when started with the ContextFinder so
it's running into problems.
Is this the correct way for the class loaders to work in this situation?
Or is the servlet doing something it shouldn't?
Shaun
PS. I guess I'll try the latest equinox builds to see if they're different
Re: Startup order effecting servlet registration classloader [message #77433 is a reply to message #77396] Thu, 16 November 2006 21:48 Go to previous messageGo to next message
I've found that putting org.eclipse.equinox.jetty.http to start level 2,
so it starts before org.eclipse.equinox.servlet.bridge.http stops the
problem, but I'm not convinced that the displayed behaviour is correct.
Cheers
Shaun Forbes wrote:
> Hey,
> registered with a
> Cheers,
> Shaun
Re: Startup order effecting servlet registration classloader [message #77452 is a reply to message #77433] Thu, 16 November 2006 22:14 Go to previous messageGo to next message
Originally posted by: skaegi.sympatico.ca
Hi Shaun,
That sounds strange -- you shouldn't have to mess with the start levels and
unless you're explicitly setting a thread context class loader the
ContextFinder shouldn't really enter into the picture.
Are you running in an appserver (e.g. with bridge.war) or using the embedded
Jetty HttpService?
You mentioned updating to the latest code and that's probably a good idea.
There's a couple of documents on http://www.eclipse.org/equinox/server that
should help setting up.
If you're still having problems can you tell a bit more about how your
Servlet is looking up resources.
-Simon
"Shaun Forbes" <sforbes@sforbes.myip.org> wrote in message
news:ejj7tl$cdi$1@utils.eclipse.org...
> Cheers
> Shaun Forbes wrote:
> > Hey,
bundle.
> > registered with a
> > Cheers,
> > Shaun
different
Re: Startup order effecting servlet registration classloader [message #77747 is a reply to message #77452] Mon, 20 November 2006 18:47 Go to previous messageGo to next message
Hey Simon,
Something setting the context class loader, but it's not me.
At the moment I'm using the embedded Jetty service.
org.eclipse.equinox.http.registry (dev.eclipse.org/HEAD),
org.eclipse.equinox.http.servlet (dev.eclipse.org/HEAD),
org.eclipse.equinox.jetty.http (dev.eclipse.org/HEAD) and
org.mortbay.jetty (dev.eclipse.org/v5_1_11).
And I have two scenarios depending on the start order:
1. Doesn't work when I need the resources later
org.eclipse.equinox.http.registry.internal.Activator tracks PackageAdmin
and IExtensionRegistry services and when it has both creates a
HttpServiceTracker
org.eclipse.equinox.http.registry.internal.Activator.addingS ervice is
triggered (twice) and creates a HttpServiceTracker
org.eclipse.equinox.http.servlet.internal.Activator starts
HttpServiceProxy by registering any HttpServices is knows about (there
are none)
org.eclipse.equinox.jetty.http.internal.Activator constructs and starts
new HttpServer
HttpServiceTracker.addingService(for HttpService) is triggered and
creates a new ServletManager (and HttpContextManager and ResourceManager)
ServletManager.added(IExtension) is triggered which creates a new
ServletRegistration with a
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader as the
registeredContextClassLoader
2. Does work when I need the resources
new HttpServer
HttpServiceTracker
HttpServiceProxy by registering any HttpServices is knows about (this
time there is one)
org.eclipse.core.runtime.internal.adaptor.ContextFinder as the
So something in there is changing the thread context class loader
I don't know if this is the expected behaviour.
As for the code that's trying to access the resources, it's using JAXB
with the JAXB generated classes in one bundle and another bundle trying
to access these classes with JAXBContext.newInstance(contextPath), for
example
client.servlet bundle contains a servlet that uses
JAXBContext ctx = JAXBContext.newInstance("client.bind");
and has a required dependency in the manifest for client.bind
client.bind bundle contains the JAXB generated classes, including
client.bind.ObjectFactory.class (which is the resource the
JAXB.newInstance() fails on)
JAXBContext.newInstance uses the thread context class loader specified
in the servlet registration to find the ObjectFactory class, which fails
with the DefaultContextLoader but succeeds with the ContextFinder.
Not sure which class loader is supposed to be used, or if JAXB is
supported in this way.
Shaun
Simon Kaegi wrote:
> Hi Shaun,
> Jetty HttpService?
> -Simon
>> Cheers
>> Shaun Forbes wrote:
>>> Hey,
> bundle.
>>> registered with a
>>> Cheers,
>>> Shaun
> different
Re: Startup order effecting servlet registration classloader [message #77764 is a reply to message #77747] Mon, 20 November 2006 22:19 Go to previous messageGo to next message
Thanks Shaun!
Great job tracking this down. That's not the intended behaviour and is
definitely a bug.
The TCCL should be restored to ContextFinder regardless of start order.
I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=165273 to track
the issue.
-Simon
news:45623E97.3080909@sforbes.myip.org...
> Hey Simon,
> HttpServiceTracker
> are none)
> new HttpServer
> new HttpServer
> HttpServiceTracker
> time there is one)
> example
> Cheers,
> Shaun
> Simon Kaegi wrote:
> > Hi Shaun,
and
embedded
> > Jetty HttpService?
idea.
that
> > -Simon
2,
> >> Cheers
> >> Shaun Forbes wrote:
> >>> Hey,
behaving
of
> > bundle.
> >>> registered with a
or
with
so
situation?
> >>> Cheers,
> >>> Shaun
> > different
Re: Startup order effecting servlet registration classloader [message #77891 is a reply to message #77764] Wed, 22 November 2006 22:58 Go to previous messageGo to next message
Fixed in org.eclipse.equinox.http.jetty HEAD.
Thanks Shaun
"Simon Kaegi" <skaegi@sympatico.ca> wrote in message
news:ejtr7m$fa7$1@utils.eclipse.org...
> Thanks Shaun!
> definitely a bug.
> the issue.
> -Simon
> > Hey Simon,
> > HttpServiceTracker
> > are none)
> > new HttpServer
ResourceManager)
> > new HttpServer
> > HttpServiceTracker
> > time there is one)
ResourceManager)
> > example
> > Cheers,
> > Shaun
> > Simon Kaegi wrote:
> > > Hi Shaun,
levels
> and
> embedded
> > > Jetty HttpService?
> idea.
> that
> > > -Simon
> 2,
correct.
> > >> Cheers
> > >> Shaun Forbes wrote:
> > >>> Hey,
> behaving
> of
> > > bundle.
> > >>> registered with a
> or
> with
ContextFinder
> so
> situation?
> > >>> Cheers,
> > >>> Shaun
> > > different
Re: Startup order effecting servlet registration classloader [message #77906 is a reply to message #77891] Thu, 23 November 2006 00:53 Go to previous message
Looks good, thanks for the quick turn around.
Cheers
> Thanks Shaun
>> Thanks Shaun!
>> definitely a bug.
>> the issue.
>> -Simon
>>> Hey Simon,
>>> HttpServiceTracker
>>> are none)
>>> new HttpServer
> ResourceManager)
>>> new HttpServer
>>> HttpServiceTracker
>>> time there is one)
> ResourceManager)
>>> example
>>> Cheers,
>>> Shaun
>>> Simon Kaegi wrote:
>>>> Hi Shaun,
> levels
>> and
>> embedded
>>>> Jetty HttpService?
>> idea.
>> that
>>>> -Simon
>> 2,
> correct.
>>>>> Cheers
>>>>> Shaun Forbes wrote:
>>>>>> Hey,
>> behaving
>> of
>>>> bundle.
>>>>>> registered with a
>> or
>> with
> ContextFinder
>> so
>> situation?
>>>>>> Cheers,
>>>>>> Shaun
>>>> different
Previous Topic:In an RCP application what causes an home/.eclipse dir to be created on unix for some users but not
Next Topic:bundle autoloading
Current Time: Fri Jul 18 05:57:44 EDT 2025
Powered by FUDForum. Page generated in 0.13919 seconds
