Home » Eclipse Projects » Equinox » problem with export of bundles when resuming an osgi application
problem with export of bundles when resuming an osgi application [message #77350] Thu, 16 November 2006 11:03 Go to next message
hi all!
We are developing a server application using eclipse equinox 3.2. when =
resuming a framework state we recently had a problem starting one of the=
already installed bundles that used to work fine. the following exceptio=
n =
occurred:
org.osgi.framework.BundleException: The activator =
at.scch.pmp.datatypeRepository.DatatypeRepositoryPlugin for bundle =
at.scch.pmp.datatypeRepository is invalid
at =
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActiva=
tor(AbstractBundle.java:141)
at =
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleC=
ontextImpl.java:966)
at =
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHo=
st.java:317)
at =
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractB=
undle.java:329)
at =
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framewor=
k.java:1037)
at =
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles=
(StartLevelManager.java:573)
at =
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(Start=
LevelManager.java:495)
at =
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLev=
el(StartLevelManager.java:275)
at =
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent=
(StartLevelManager.java:455)
at =
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventMana=
ger.java:189)
at =
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventMa=
nager.java:291)
Caused by: java.lang.NullPointerException
at =
org.eclipse.osgi.framework.internal.core.BundleLoader.getLoa derProxy(Bun=
dleLoader.java:238)
at =
org.eclipse.osgi.framework.internal.core.BundleLoader.create ExportPackag=
eSource(BundleLoader.java:210)
(full stack trace and log output see below)
Obviously exporter.getExporter() returns null.
>> final PackageSource createExportPackageSource(ExportPackageDescriptio=
n =
>> export) {
>> BundleLoaderProxy exportProxy =3DgetLoaderProxy(export.getExporter(=
My only cure was to launch the framework clean and thus delete all store=
d =
data, which is conceivably undesired.
My question is: does anybody of you know under which circumstances this =
error might occur and how i might prevent it?
Werner
at =
at =
at =
st.java:317)
at =
undle.java:329)
at =
k.java:1037)
at =
at =
at =
at =
at =
ger.java:189)
at =
nager.java:291)
at =
dleLoader.java:238)
at =
at =
org.eclipse.osgi.framework.internal.core.BundleLoader.addImp ortedPackage=
s(BundleLoader.java:201)
at =
org.eclipse.osgi.framework.internal.core.BundleLoader.findIm portedSource=
(BundleLoader.java:873)
at =
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLo=
ader.java:376)
at =
ader.java:352)
at =
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(Defau=
ltClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:246)
at =
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLo=
ader.java:276)
at =
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost=
..java:227)
at =
tor(AbstractBundle.java:134)
... 10 more
Root exception:
at =
dleLoader.java:238)
at =
at =
at =
at =
ader.java:376)
at =
ader.java:352)
at =
at =
ader.java:276)
at =
..java:227)
at =
at =
at =
st.java:317)
at =
undle.java:329)
at =
k.java:1037)
at =
at =
at =
at =
at =
ger.java:189)
at =
nager.java:291)
!ENTRY org.eclipse.osgi 4 0 2006-11-14 10:10:29.277
!MESSAGE Bundle =
initial@reference:file:plugins/at.scch.pmp.datatypeRepository_1.0.0.jar/=
[23] is not active.
Re: problem with export of bundles when resuming an osgi application [message #77545 is a reply to message #77350] Fri, 17 November 2006 17:42 Go to previous messageGo to next message
This looks very similar to the bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=121148
But that bug should be fixed in 3.2. What build of Eclipse 3.2 are you
using? Try adding osgi.noLazyStateLoading=true to your config.ini.
Tom
Re: problem with export of bundles when resuming an osgi application [message #79066 is a reply to message #77545] Thu, 14 December 2006 09:22 Go to previous message
Thanks Tom for your reply. As we were not able to reproduce the bug we d=
id =
not inquire that matter more deeply.
As it happens we were confronted with this issue today again.
We are using the release build of eclipse 3.2. the propsed fix is in the=
source code (we are building the osgi bundles ourself) but despite that =
it =
still seems to happen.
Is there a testsetup that i can use to reproduce this bug? this might he=
lp =
a lot in narrowing the scope of our search and help me choos a starting =
point.
thanks,
werner
On Fri, 17 Nov 2006 23:42:25 +0100, Tom Watson <tjwatson@us.ibm.com> wro=
te:
> This looks very similar to the bug =
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D121148
> But that bug should be fixed in 3.2. What build of Eclipse 3.2 are yo=
u =
> using? Try adding osgi.noLazyStateLoading=3Dtrue to your config.ini.
> Tom
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Previous Topic:How to open the Equinox sample web page
Next Topic:How to use Equiniox's LogService ?
Current Time: Sun Aug 31 22:38:01 EDT 2025
Powered by FUDForum. Page generated in 0.17238 seconds
