Home » Eclipse Projects » Equinox » configure server osgi to run on different port
configure server osgi to run on different port [message #77302] Wed, 15 November 2006 14:16 Go to next message
Originally posted by: duncan.krebsnet.com
Hey,
I'm a little foggy and its been a while since I'm been in the server OSGI
code. Can someone tell to configure the equinox http to run on a different
port instead of default 80? Thanks - Duncan
Re: configure server osgi to run on different port [message #77318 is a reply to message #77302] Wed, 15 November 2006 14:42 Go to previous message
Originally posted by: simon.kaegi.cognos.com
Hi Duncan,
You can use the "org.osgi.service.http.port" system property to set your
desired port.
-Simon
"Duncan Krebs" <duncan@krebsnet.com> wrote in message
news:1f9a24e7d4174adae3ba2d0271601921$1@www.eclipse.org...
> Hey, I'm a little foggy and its been a while since I'm been in the server
> OSGI code. Can someone tell to configure the equinox http to run on a
> different port instead of default 80? Thanks - Duncan
Previous Topic:High load on equinox
Next Topic:Equinox WebStart
Current Time: Sat Jul 26 14:01:14 EDT 2025
Powered by FUDForum. Page generated in 0.02616 seconds
