Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Error Resolving Buckminster
Re: [buckminster-dev] Error Resolving Buckminster [message #6932] Tue, 26 February 2008 17:09
The only thing I changed in my workspace was the removal of a svn plugin.
Here's basically a rundown of my attempts today:
1) opened my workspace which has buckminster installed
2) opened my 'manage configuration' to select my installed buckminster
components and 'check for updates' (as an aside, I noticed that some of
the mirrors still seem to have buckminster's update url listed under
'technology'... I'm assuming this will be resolved over time as the mirrors
refresh?)
3) checked for components and saw there were none.
4) noticed that I had a svn provider plugin (incubator) listed that I don't
recall installing, so I uninstalled it.
5) open the dev-cquery and ran it... worked fine.
Not sure if that helps. I'll try and be more mindful of tracing steps if I
run into problems in the future. This one was more of a 'stumble-upon'.
Todd
Thomas Hallgren
<thomas@tada.se>
Sent by: To
buckminster-dev-b Buckminster developer discussions
ounces@eclipse.or <buckminster-dev@eclipse.org>
g cc
Subject
02/26/2008 04:58 Re: [buckminster-dev] Error
PM Resolving Buckminster
Please respond to
Buckminster
developer
discussions
<buckminster-dev@
eclipse.org>
Hi Todd,
No, there was no change. But this gremlin worries me a bit. You're not
the first to have an encounter with it.
Could the problem be caused by you having several previous dormant
versions of Buckminster installed in your Eclipse runtime? The reason I
ask is that last time this happened, I suspect that was the cause. I'm
not sure however. Trying to triangulate :-)
Thomas Hallgren
Todd_Lee@amis.com wrote:
> Apparently I'm a victim of gremlins. Tried the same thing today and
worked
> fine...
> Did the dev-cquery/dogfood2.rmap change?
> Either way, don't worry about it - works now.
> Todd
> AMI Semiconductor - "Silicon Solutions for the Real World"
> NOTICE:
> This electronic message contains information that may be confidential or
privileged. The information is intended for the use of the individual or
entity named above. If you are not the intended recipient, please be aware
that any disclosure, copying, distribution or use of the contents of this
information is prohibited. If you received this electronic message in
error, please notify the sender and delete the copy you received.
> _______________________________________________
> buckminster-dev mailing list
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
NOTICE:
This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
Previous Topic:Re: [buckminster-dev] Error Resolving Buckminster
Next Topic:[buckminster-dev] Getting started, can't set dependency copmonent type
Current Time: Fri Jul 25 21:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.24563 seconds
