Home » Eclipse Projects » Equinox » High load on equinox
High load on equinox [message #77175] Tue, 14 November 2006 20:32 Go to next message
I hit a ConcurrentModificationException when running Equinox under high
concurrent load. Essentially, the problem can be seen from the attached
stack trace.
Does anyone have a suggestion to mitigate this?
Nikunj
java.util.ConcurrentModificationException
java.util.AbstractList$Itr.checkForComodification(AbstractLi st.java:4
49)
at java.util.AbstractList$Itr.next(AbstractList.java:420)
org.eclipse.equinox.ds.resolver.Resolver.resolveSatisfied(Re solver.ja
va:588)
org.eclipse.equinox.ds.resolver.Resolver.justResolve(Resolve r.java:55
4)
org.eclipse.equinox.ds.service.ComponentFactoryImpl.newInsta nce(Compo
nentFactoryImpl.java:74)
at oracle....
at oracle....
at javax.servlet.http.HttpServlet.service(HttpServlet.java:616)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleR
equest(ServletRegistration.java:91)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(P
roxyServlet.java:110)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyS
ervlet.java:76)
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java
:677)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:5
68)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:
245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Re: High load on equinox [message #77207 is a reply to message #77175] Tue, 14 November 2006 21:50 Go to previous messageGo to next message
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
sounds like a known Declarative services implementation bug. Take a
look in bugzilla and see if you find a match. If not, please enter a
new bug report.
Jeff
> stack trace.
> Nikunj
> at
> 49)
> at
> va:588)
> at
> 4)
> at
> at oracle....
> at oracle....
> at
> at
> at
> ervlet.java:76)
> at
> at
> :677)
> at
> 68)
> at
> at
> 245)
Re: High load on equinox [message #77240 is a reply to message #77207] Wed, 15 November 2006 01:27 Go to previous message
I filed a new bug as I did not see any issues reported around concurrent
modification.
Nikunj
> new bug report.
> Jeff
>> high concurrent load. Essentially, the problem can be seen from the
>> attached stack trace.
>> Thanks,
>> Nikunj
>> at
>> 49)
>> at
>> va:588)
>> at
>> 4)
>> at
>> at oracle....
>> at oracle....
>> at
>> at
>> at
>> ervlet.java:76)
>> at
>> at
>> :677)
>> at
>> 68)
>> at
>> at
>> at
>> at
>> 245)
>> at
>> at
Previous Topic:How to compile a plugin dependent from another bundle jars
Next Topic:configure server osgi to run on different port
Current Time: Mon Jul 14 18:20:08 EDT 2025
Powered by FUDForum. Page generated in 0.29090 seconds
