Debug with JDK 1.2.2, Eclipse 2.1.0 possible? [message #77170] |
Thu, 17 July 2003 11:10  |
Originally posted by: tobias.knoetzele.premiere.de
I have got a problem to debug some legacy system written with VAJ and JDK
1.2.2 which I wanted to
migrate to Eclipse. Unfortunately I canŽt migrate to JDK 1.3 or 1.4
because we currently donŽt have a
deployment environment in my company.
Running the application in Eclipse works fine, but when I try to debug it,
I get the following
Message:
Exception occured during launch
Reason: Cannot connect to VM
On the console it reads:
Can't load "jdwp.dll", because Can't find dependent libraries
Could not create the Java virtual machine.
The manual says that Eclipse needs JRE 1.3.1_06 or 1.4.x and I heard and
read that there are
significant differences in the Debug API. (See Phillippe Mulet
http://dev.eclipse.org/newslists/news.eclipse.tools/msg05649 .html)
But maybe somebody knows a way to use JDK 1.2.2 nevertheless?
My Configuration:
- Windows XP
- Eclipse Release 2.1.0, Build id: 200306051737 (Running with J2RE 1.4.2)
- Installed JREs (Menu:Window/Preferences/Java/Installed JREs)
j2re1.2.2 (Type "Standard VM")
j2re1.4.2 (Checked, ie. default to build and run)
- Project Settings (Right Mouse on Projekt / Properties)
- Java Build Path / Libraries / JRE System Library [j2re1.2.2]
- Java Compiler / Compliance and Classfiles / Compiler Compliance
level: 1.3 (1.2 is not available)
- Java Compiler / Compliance and Classfiles / Generated .class file
compatibility: 1.2
- Java Compiler / Compliance and Classfiles / Source compatibility: 1.3
- Launch Configuration (Menu:Run/Run...) / JRE: j2re1.2.2
What I tried to solve the problem:
- Read Manual, Search Google, Search eclipse.org (Newsgroups)
- Use very simple programm with no dependencies, just main(...) {
System.out.println("Hello"); }
- Use JRE 1.2.2 or 1.4.2 as Standard Installed JRE
- Different Combinations of Project Settings / Launch Configuration
- Install JRE 1.2.2 as Type "Standard 1.1.x VM" -> not possible, Error
"Target is not a JDK root"
whatever Home Directory I try to give, eg. D:\Programme\j2jre1.2 or
Subfolders
- Copy some DLLŽs from JDK 1.4.2 to JRE 1.2.2 like suggested by Michael
Moser
( http://dev.eclipse.org/newslists/news.eclipse.tools/msg08868 .html) for
JDK 1.3.x (!)
Result: Debugger starts, but ends up with UnsupportedClassVersionError:
java.lang.UnsupportedClassVersionError:
de/premiere/test/test/SimpleDebugTest
(Unsupported major.minor version 47.0) at
java.lang.ClassLoader.defineClass(ClassLoader.java:471)
Tobias Knoetzele
Re: Debug with JDK 1.2.2, Eclipse 2.1.0 possible? [message #77593 is a reply to message #77186] |
Fri, 18 July 2003 05:52   |
Hello Olivier,
Thanks for your response.
Unfortunately it didnŽt solve my problem (maybe I misunderstood you?).
On my machine I have installed the JDK 1.2.2 and SDK 1.4.2, the JREŽs were
installed automatically as a copy in a different directory. In Eclipse I
configured the JREŽs at Menu:Window / Preferences / Java / Installed JREs.
In fact, the location was pointing to the JRE directory, not the JDK/SDK.
I changed it to the JDK directory, but the same error occurs. Anyway with
1.4.2 the location is pointing to the JRE either, and this works. And the
required jdwp.dll does not exist in the JDK.
Am I missing your point?
Tobias
> Le Thu, 17 Jul 2003 15:10:04 +0000 (UTC), tobias.knoetzele@premiere.de
> You should install a JDK1.2.2 and not a JRE 1.2.2 if you want to
> debug.
> Olivier
Re: Debug with JDK 1.2.2, Eclipse 2.1.0 possible? [message #77607 is a reply to message #77593] |
Fri, 18 July 2003 05:56   |
Originally posted by: burner.zclipse.org
On Fri, 18 Jul 2003 09:52:51 +0000, Tobias Knötzele wrote:
> Hello Olivier,
> Unfortunately it didn't solve my problem (maybe I misunderstood you?).
> On my machine I have installed the JDK 1.2.2 and SDK 1.4.2, the JRE's were
> configured the JRE's at Menu:Window / Preferences / Java / Installed JREs.
Did you try getting the JPDA from
http://java.sun.com/products/jpda/download.html ?
I don't know if it works with Eclipse, but you would at least need that to
get JPDA support in JDK1.2.2 (which is what Eclipse uses to do debugging).
mike
> Tobias
>> Olivier
http://zclipse.org
Re: Debug with JDK 1.2.2, Eclipse 2.1.0 possible? [message #77694 is a reply to message #77607] |
Fri, 18 July 2003 08:28  |
ThatŽs it! It works fine with Eclipse 2.1.0.
The steps I took:
1) Download http://java.sun.com/products/jpda/download.html
2) Extract the 3 DLLŽs from bin folder (jdwp.dll, dt_shmem.dll,
dt_socket.dll)
into bin folder of JRE 1.2.2
3) Extract the one jar from lib folder (jpda.jar) into lib folder of JRE
1.2.2
Done.
Thanks a lot,
Tobias
PS: So far I had never heard about JPDA but read a tip of copying these
dllŽs from a newer SDK to the JRE 1.2.2. This did not work.
> mike
FUDForum. Page generated in 0.27962 seconds
