Home » Archived » Visual Editor (VE) » VE and Debugging are awfully slow ?
VE and Debugging are awfully slow ? [message #77110] Sun, 16 January 2005 10:06 Go to next message
Originally posted by: tballmann.gmx.de
Did I do something wrong or did I right ?
I just installed the Win32-Eclipse-Platform and updated the required =
plug-ins to use the Visual Editor.
However, trying to use the GUI-Editor (1.0.2) is very painful - it seems=
to freeze the whole application (after about 2-5 minutes I can continue =
with "working").
The same is true for debugging :-(
What could be the reasons ? Considering these circumstances, unfortunate=
ly =
Eclipse is not usuable for developping :-(
Thomas Ballmann
Re: VE and Debugging are awfully slow ? [message #77173 is a reply to message #77110] Sun, 16 January 2005 16:18 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
What is your memory available? It just dawnded on me that is one reason
for such extremelly slow. It should be at least 500m, a gig is better.
500meg can still run slow because of everything else running at the same
time.
> seems to freeze the whole application (after about 2-5 minutes I can
> continue with "working").
> unfortunately Eclipse is not usuable for developping :-(
> Thomas Ballmann
Rich Kulp
Re: VE and Debugging are awfully slow ? [message #77189 is a reply to message #77173] Sun, 16 January 2005 16:31 Go to previous messageGo to next message
What do you mean by memory - the processor/memory of my computer ?
I have an AMD Athlon 2400 with 2000 mhz and 512 MB memory - that should =
be =
sufficient enough to run the most programs without problems.
Or the settings for eclipse - these settings I didn't changed I read =
somewhere the default is 256 mb, I haven't changed anything (actually =
because I 've tried eclipse for 3 days now,I have no idea where to chang=
e =
this)
Thomas Ballmann
Re: VE and Debugging are awfully slow ? [message #77220 is a reply to message #77189] Sun, 16 January 2005 16:38 Go to previous messageGo to next message
512meg can be tight. look at your taskmanager (Windows Taskbar->popup
menu->TaskManager), go to the Performance page and see if your Total
Memory, Available, Commit charge indicate you are using up all of your
memory and it bouncing into swap land.
Is your disk being accessed continually when it gets slow like this
(heavy disk activity at these times indicate a lot swapping going on)?
Is the rest of Eclipse slow too?
> be sufficient enough to run the most programs without problems.
> change this)
> Thomas Ballmann
Rich Kulp
Re: VE and Debugging are awfully slow ? [message #77251 is a reply to message #77220] Sun, 16 January 2005 17:05 Go to previous messageGo to next message
The task manager tells me (I am debugging now), that there are about 200=
mb from 500mb are available - there is no significant disk activity, so =
there are no real important swap activities.
On Sun, 16 Jan 2005 16:38:54 -0500, Rich Kulp =
<richkulp@us.NO_SPAM.ibm.com> wrote:
> 512meg can be tight. look at your taskmanager (Windows Taskbar->popup =
> menu->TaskManager), go to the Performance page and see if your Total =
> Memory, Available, Commit charge indicate you are using up all of your=
> Is your disk being accessed continually when it gets slow like this =
> (heavy disk activity at these times indicate a lot swapping going on)?=
>> I have an AMD Athlon 2400 with 2000 mhz and 512 MB memory - that shou=
ld =
>> Or the settings for eclipse - these settings I didn't changed I read=
>> somewhere the default is 256 mb, I haven't changed anything (actually=
>> because I 've tried eclipse for 3 days now,I have no idea where to =
>> change this)
>> Thomas Ballmann
Thomas Ballmann
Re: VE and Debugging are awfully slow ? [message #77267 is a reply to message #77251] Sun, 16 January 2005 17:51 Go to previous messageGo to next message
Please check one more time that there isn't a .log file in your
workspace's .metadata directory. The other .log you had doesn't say
anything useful.
If that is not there, then I'm stumped because sure, the VE is slow to
start up, but it is never in the minutes range once it is up and
running. It only gets like that if there were errors, and such errors
are logged.
Rich Kulp
Re: VE and Debugging are awfully slow ? [message #77283 is a reply to message #77251] Sun, 16 January 2005 19:24 Go to previous messageGo to next message
I installed eclipse once again include online updates
GEF 3.0.1.
EMF 2.0.1
VE 1.0.1
Then I used the VE again for editing something easy.
The result was nearly the same :-(
I didn't even run the Operabrowser which uses the same java VM.
I created a jav.awt.Dilaog-derived class, tried to resize it, every =
operation took about one minute.
Then I wanted to insert a JTextfield - for whatever a progress dialog =
popped up.
On Sun, 16 Jan 2005 23:05:42 +0100, Thomas <tballmann@gmx.de> wrote:
> The task manager tells me (I am debugging now), that there are about 2=
00 =
> mb from 500mb are available - there is no significant disk activity, s=
o =
>> 512meg can be tight. look at your taskmanager (Windows Taskbar->popup=
>> Memory, Available, Commit charge indicate you are using up all of you=
r =
>> (heavy disk activity at these times indicate a lot swapping going on)=
>>> I have an AMD Athlon 2400 with 2000 mhz and 512 MB memory - that =
>>> should be sufficient enough to run the most programs without proble=
ms.
>>> Or the settings for eclipse - these settings I didn't changed I rea=
d =
>>> somewhere the default is 256 mb, I haven't changed anything (actuall=
y =
>>> change this)
>>> Thomas Ballmann
Thomas Ballmann
Re: VE and Debugging are awfully slow ? [message #77299 is a reply to message #77267] Sun, 16 January 2005 20:14 Go to previous messageGo to next message
------------jzzBE9AUaqooIHoPmncF5q
Content-Type: text/plain; format=flowed; delsp=yes; charset=iso-8859-15
Content-Transfer-Encoding: Quoted-Printable
Sorry, I sent the last message without finishing.
Meanwhile I weait for the coming back of Eclipse - I pointed with the =
mouse to the place I want to insert the text field - this took about 3 =
minutes.
And so on and so on. Every operation takes a lot of time and now and the=
n =
a progress dialog pops up ("Operation in progress").
It works, but obviously too slowly - so no wonder that there is no =
..log-file. ( I even closed and opende Eclipse again).
And debugging is the hell too - it is the same, every step over a source=
code line takes a few minutes (to get the debugger-perspective took 5 =
minutes, that means it takes very long to establish the debug-connection=
After the debugging I got a .log-file that I include - it tells somethin=
g =
about time out of connections - no wonder :-)
I suppose the reasons are to be found
either in the java-installation (1.4.2 installed by Opera installation)
or
the memory the java vm should use (what is the default value?)
or
in some programs that could influence eclipse (like Opera, that uses the=
same java-installation, a firewall or the webwasher. However, all these =
programs didn't run)
I have no idea how to check out the things or what else to check.
Thomas
On Sun, 16 Jan 2005 17:51:53 -0500, Rich Kulp =
> Please check one more time that there isn't a .log file in your =
> workspace's .metadata directory. The other .log you had doesn't say =
> anything useful.
> If that is not there, then I'm stumped because sure, the VE is slow to=
> start up, but it is never in the minutes range once it is up and =
> running. It only gets like that if there were errors, and such errors =
> are logged.
Content-Disposition: attachment; filename=.log
Content-Type: application/octet-stream; name=.log
!SESSION Jan 17, 2005 02:01:02.46 --------------------------------------=
eclipse.buildId=3DM200409161125
java.version=3D1.4.2_01
java.vendor=3DSun Microsystems Inc.
BootLoader constants: OS=3Dwin32, ARCH=3Dx86, WS=3Dwin32, NL=3Dde_DE
!ENTRY org.eclipse.jdt.debug 4 120 Jan 17, 2005 02:01:02.46
!MESSAGE Internal error logged from JDI Debug: =
!STACK 0
org.eclipse.jdi.TimeoutException
at org.eclipse.jdi.internal.connect.PacketReceiveManager.getRep ly(Packe=
tReceiveManager.java:149)
tReceiveManager.java:158)
at org.eclipse.jdi.internal.MirrorImpl.requestVM(MirrorImpl.jav a:173)
at org.eclipse.jdi.internal.MirrorImpl.requestVM(MirrorImpl.jav a:191)
at org.eclipse.jdi.internal.MirrorImpl.requestVM(MirrorImpl.jav a:206)
at org.eclipse.jdi.internal.ThreadReferenceImpl.threadGroup(Thr eadRefer=
enceImpl.java:454)
at org.eclipse.jdt.internal.debug.core.model.JDIThread.getUnder lyingThr=
eadGroup(JDIThread.java:1655)
at org.eclipse.jdt.internal.debug.core.model.JDIThread.determin eIfSyste=
mThread(JDIThread.java:361)
at org.eclipse.jdt.internal.debug.core.model.JDIThread.initiali ze(JDITh=
read.java:217)
at org.eclipse.jdt.internal.debug.core.model.JDIThread.<init>(JDIThread=
..java:200)
at org.eclipse.jdt.internal.debug.core.model.JDIDebugTarget.cre ateThrea=
d(JDIDebugTarget.java:455)
at org.eclipse.jdt.internal.debug.core.model.JDIDebugTarget$Thr eadStart=
Handler.handleEvent(JDIDebugTarget.java:1745)
at org.eclipse.jdt.internal.debug.core.EventDispatcher.dispatch (EventDi=
spatcher.java:137)
at org.eclipse.jdt.internal.debug.core.EventDispatcher.run(Even tDispatc=
her.java:221)
at java.lang.Thread.run(Unknown Source)
!ENTRY org.eclipse.jdt.debug 4 120 Jan 17, 2005 02:03:59.140
!STACK 0
enceImpl.java:454)
read.java:217)
..java:200)
spatcher.java:137)
her.java:221)
------------jzzBE9AUaqooIHoPmncF5q--
No soution - but found out the basic problem [message #77315 is a reply to message #77267] Mon, 17 January 2005 06:23 Go to previous messageGo to next message
Hi Rich,
please forget the other mails I sent here in order to reply. The basic =
problem is that the
connection to the java VM is very slow, whatever the reasons are for tha=
t. =
I have no idea, even when I turned off all the programs that could =
influence Eclipse or the Java VM (virus scanner, firewall, Opera browser=
it is very slow. So I assume I must tell eclipse or the java VM somethin=
g =
more about each other by setting some parameters ?
Thomas
> anything useful.
> are logged.
Re: VE and Debugging are awfully slow ? [message #77376 is a reply to message #77283] Mon, 17 January 2005 10:21 Go to previous messageGo to next message
> GEF 3.0.1.
> EMF 2.0.1
> VE 1.0.1
I suggest getting debugging working quickly first. Debug has been
stable for a lot longer than VE. What they do is also a lot simpler and
better-understood than what we do. Once you get debugging performing
well, I'll be that VE will perform well too.
Off the cuff, it really sounds like you're getting network timeouts
there. Both debug and VE establish network connections to "remote"
JVMs, and use those for various purposes.
I suspect a possible routing problem or something like that.
What O/S are you on?
Dave Orme
Visual Editor Project leader
db4objects Senior Engineer (www.db4o.com)
Essential Data Project maintainer (essentialdata.sf.net)
Re: VE and Debugging are awfully slow ? [message #77399 is a reply to message #77376] Mon, 17 January 2005 10:29 Go to previous messageGo to next message
------------OavkUUqRmk83cLubd3V8x2
I just installed everything new including JAVA SDK.
I suppose there is problem between the JVM and Eclipse, because simple =
debugging causes timeouts.
I attached the settings that are told me by Help-About Eclipse and the =
..log-file from debugging of a simple HelloWorld program.
I have no idea where the communication problem is to be found, I closed =
the firewall without more luck, so it must be 'system intern".
Are there some settings within Eclipse I have forgotten (I didn't set =
anything for the simple HelloWorld) ?
Or do I have to tell the JVM more - as I said I just installed the Eclip=
se =
and did not changed anything (but I included java into the path-variable=
My OS is Windows 2000.
Thomas
> I suggest getting debugging working quickly first. Debug has been =
> stable for a lot longer than VE. What they do is also a lot simpler a=
nd =
> better-understood than what we do. Once you get debugging performing =
> Off the cuff, it really sounds like you're getting network timeouts =
> there. Both debug and VE establish network connections to "remote" =
> Dave Orme
Thomas Ballmann
Content-Disposition: attachment; filename=debug.log
Content-Type: application/octet-stream; name=debug.log
!SESSION Jan 17, 2005 15:34:10.921 -------------------------------------=
java.version=3D1.4.2_06
!ENTRY org.eclipse.core.runtime 4 2 Jan 17, 2005 15:34:10.921
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse=
..core.runtime".
!STACK 1
org.eclipse.debug.core.DebugException[5010]: org.eclipse.jdi.TimeoutExce=
ption
at org.eclipse.jdi.internal.ThreadReferenceImpl.frames(ThreadRe ferenceI=
mpl.java:187)
at org.eclipse.jdi.internal.ThreadReferenceImpl.frame(ThreadRef erenceIm=
pl.java:140)
at org.eclipse.jdt.internal.debug.core.model.JDIThread.getUnder lyingFra=
me(JDIThread.java:571)
at org.eclipse.jdt.internal.debug.core.model.JDIStackFrame.getU nderlyin=
gStackFrame(JDIStackFrame.java:976)
at org.eclipse.jdt.internal.debug.core.model.JDIStackFrame.getS ourcePat=
h(JDIStackFrame.java:1166)
at org.eclipse.jdt.launching.sourcelookup.containers.JavaSource LookupPa=
rticipant.getSourceName(JavaSourceLookupParticipant.java:69)
at org.eclipse.debug.core.sourcelookup.AbstractSourceLookupPart icipant.=
findSourceElements(AbstractSourceLookupParticipant.java:54)
at org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor$Sou=
rceLookupQuery.run(AbstractSourceLookupDirector.java:125)
at org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatf=
orm.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.doS=
ourceLookup(AbstractSourceLookupDirector.java:443)
at org.eclipse.debug.core.sourcelookup.AbstractSourceLookupDire ctor.get=
SourceElement(AbstractSourceLookupDirector.java:692)
SourceElement(AbstractSourceLookupDirector.java:431)
at org.eclipse.debug.internal.ui.views.launch.LaunchView.lookup EditorIn=
put(LaunchView.java:621)
at org.eclipse.debug.internal.ui.views.launch.LaunchView.openEd itorForS=
tackFrame(LaunchView.java:692)
at org.eclipse.debug.internal.ui.views.launch.LaunchView.showEd itorForC=
urrentSelection(LaunchView.java:600)
at org.eclipse.debug.internal.ui.views.launch.LaunchView.select ionChang=
ed(LaunchView.java:474)
at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.ja=
va:450)
orm.java:616)
at org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(=
StructuredViewer.java:448)
at org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedVi=
ewer.java:1094)
at org.eclipse.debug.internal.ui.views.launch.LaunchView.autoEx pand(Lau=
nchView.java:965)
at org.eclipse.debug.internal.ui.views.launch.LaunchView.initia lizeSele=
ction(LaunchView.java:349)
at org.eclipse.debug.internal.ui.views.launch.LaunchView.become sVisible=
(LaunchView.java:1236)
at org.eclipse.debug.ui.AbstractDebugView$DebugViewPartListener .partVis=
ible(AbstractDebugView.java:159)
at org.eclipse.ui.internal.PartListenerList2$7.run(PartListener List2.ja=
va:139)
orm.java:616)
at org.eclipse.ui.internal.PartListenerList2.firePartVisible(Pa rtListen=
erList2.java:137)
at org.eclipse.ui.internal.WorkbenchPage$1.propertyChange(Workb enchPage=
..java:139)
at org.eclipse.ui.internal.LayoutPart.setVisible(LayoutPart.jav a:268)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 7)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:56 8)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(Pre=
sentablePart.java:122)
at org.eclipse.ui.internal.presentations.DefaultPartPresentatio n.select=
Part(DefaultPartPresentation.java:1116)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartS=
tack.java:946)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:467)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.ja va:367)
at org.eclipse.ui.internal.PartSashContainer.createControl(Part SashCont=
ainer.java:432)
at org.eclipse.ui.internal.PerspectiveHelper.activate(Perspecti veHelper=
..java:155)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.j ava:732)=
at org.eclipse.ui.internal.WorkbenchPage.setPerspective(Workben chPage.j=
ava:2818)
at org.eclipse.ui.internal.WorkbenchPage.busySetPerspective(Wor kbenchPa=
ge.java:743)
at org.eclipse.ui.internal.WorkbenchPage.access$8(WorkbenchPage .java:72=
8)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.j ava:2961=
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69=
ava:2959)
at org.eclipse.ui.internal.Workbench.showPerspective(Workbench. java:144=
8)
at org.eclipse.debug.internal.ui.launchConfigurations.Perspecti veManage=
r.switchToPerspective(PerspectiveManager.java:171)
r$5.run(PerspectiveManager.java:312)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.j=
ava:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2749)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2434)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.ja=
va:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)=
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:9=
6)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformAc=
tivator.java:335)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.j=
ava:273)
ava:129)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl=
..java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAcce=
ssorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!SUBENTRY 1 org.eclipse.jdt.debug 4 5010 Jan 17, 2005 15:34:10.921
!MESSAGE org.eclipse.jdi.TimeoutException occurred retrieving stack fram=
es.
!STACK 0
mpl.java:187)
pl.java:140)
orm.java:616)
va:450)
orm.java:616)
ewer.java:1094)
nchView.java:965)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
8)
ava:106)
va:254)
6)
tivator.java:335)
ava:273)
ava:129)
..java:39)
ssorImpl.java:25)
es.
!STACK 0
mpl.java:187)
pl.java:140)
orm.java:616)
va:450)
orm.java:616)
ewer.java:1094)
nchView.java:965)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
8)
ava:106)
va:254)
6)
tivator.java:335)
ava:273)
ava:129)
..java:39)
ssorImpl.java:25)
!ENTRY org.eclipse.debug.core 4 120 Jan 17, 2005 15:34:10.921
!MESSAGE Error logged from Debug Core: =
!STACK 1
ption
mpl.java:187)
pl.java:140)
orm.java:616)
va:450)
orm.java:616)
ewer.java:1094)
nchView.java:965)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
8)
ava:106)
va:254)
6)
tivator.java:335)
ava:273)
ava:129)
..java:39)
ssorImpl.java:25)
es.
!STACK 0
mpl.java:187)
pl.java:140)
orm.java:616)
va:450)
orm.java:616)
ewer.java:1094)
nchView.java:965)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
8)
ava:106)
va:254)
6)
tivator.java:335)
ava:273)
ava:129)
..java:39)
ssorImpl.java:25)
!ENTRY org.eclipse.jdt.debug.ui 4 150 Jan 17, 2005 15:35:31.750
!MESSAGE Internal Error
!STACK 1
ption
at org.eclipse.jdi.internal.StackFrameImpl.getValues(StackFrame Impl.jav=
a:130)
at org.eclipse.jdi.internal.StackFrameImpl.getValue(StackFrameI mpl.java=
:72)
at org.eclipse.jdt.internal.debug.core.model.JDILocalVariable.r etrieveV=
alue(JDILocalVariable.java:56)
at org.eclipse.jdt.internal.debug.core.model.JDIVariable.getCur rentValu=
e(JDIVariable.java:67)
at org.eclipse.jdt.internal.debug.core.model.JDIVariable.getVal ue(JDIVa=
riable.java:89)
at org.eclipse.jdt.internal.debug.ui.JavaDebugHover.getTypeName (JavaDeb=
ugHover.java:212)
at org.eclipse.jdt.internal.debug.ui.JavaDebugHover.appendVaria ble(Java=
DebugHover.java:190)
at org.eclipse.jdt.internal.debug.ui.JavaDebugHover.getHoverInf o(JavaDe=
bugHover.java:161)
at org.eclipse.jdt.internal.ui.text.java.hover.BestMatchHover.g etHoverI=
nfo(BestMatchHover.java:102)
at org.eclipse.jdt.internal.ui.text.java.hover.JavaEditorTextHo verProxy=
..getHoverInfo(JavaEditorTextHoverProxy.java:69)
at org.eclipse.jface.text.TextViewerHoverManager$4.run(TextView erHoverM=
anager.java:160)
!SUBENTRY 1 org.eclipse.jdt.debug 4 5010 Jan 17, 2005 15:35:31.750
!MESSAGE org.eclipse.jdi.TimeoutException occurred while retrieving valu=
e.
!STACK 0
a:130)
:72)
riable.java:89)
ugHover.java:212)
bugHover.java:161)
anager.java:160)
!ENTRY org.eclipse.jdt.debug.ui 4 150 Jan 17, 2005 15:37:00.250
!STACK 1
ption
mpl.java:187)
pl.java:140)
gMethod(JDIStackFrame.java:227)
at org.eclipse.jdt.internal.debug.core.model.JDIStackFrame.isNa tive(JDI=
StackFrame.java:769)
at org.eclipse.jdt.internal.debug.core.model.JDIStackFrame.find Variable=
(JDIStackFrame.java:608)
bugHover.java:159)
anager.java:160)
!SUBENTRY 1 org.eclipse.jdt.debug 4 5010 Jan 17, 2005 15:37:00.250
es.
!STACK 0
mpl.java:187)
pl.java:140)
bugHover.java:159)
anager.java:160)
!ENTRY org.eclipse.jdt.debug 4 120 Jan 17, 2005 15:38:54.156
!MESSAGE Exception processing async thread queue
!SUBENTRY 1 org.eclipse.jdt.debug 4 120 Jan 17, 2005 15:38:54.156
!STACK 0
at org.eclipse.jdi.internal.VirtualMachineImpl.mirrorOf(Virtual MachineI=
mpl.java:676)
at org.eclipse.jdt.internal.debug.core.model.JDIDebugTarget.new Value(JD=
IDebugTarget.java:1659)
at org.eclipse.jdt.internal.debug.eval.ast.engine.Interpreter.g etResult=
(Interpreter.java:111)
at org.eclipse.jdt.internal.debug.eval.ast.engine.ASTEvaluation Engine$E=
valRunnable.run(ASTEvaluationEngine.java:355)
at org.eclipse.jdt.internal.debug.core.model.JDIThread$ThreadJo b.run(JD=
IThread.java:2516)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!ENTRY org.eclipse.jdt.debug 4 120 Jan 17, 2005 15:40:00.140
!SUBENTRY 1 org.eclipse.jdt.debug 4 120 Jan 17, 2005 15:40:00.140
!STACK 0
mpl.java:676)
IThread.java:2516)
!ENTRY org.eclipse.debug.ui 4 120 Jan 17, 2005 15:41:11.578
!MESSAGE Error logged from Debug UI: =
!STACK 1
ption
at org.eclipse.jdi.internal.ObjectReferenceImpl.isCollected(Obj ectRefer=
enceImpl.java:388)
at org.eclipse.jdt.internal.debug.core.model.JDIValue.isAllocat ed(JDIVa=
lue.java:286)
at org.eclipse.jdt.internal.debug.core.model.JDIValue.getVariab lesList(=
JDIValue.java:192)
at org.eclipse.jdt.internal.debug.core.model.JDIValue.hasVariab les(JDIV=
alue.java:379)
at org.eclipse.debug.internal.ui.views.variables.VariablesViewC ontentPr=
ovider.hasChildren(VariablesViewContentProvider.java:298)
at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(Ab stractTr=
eeViewer.java:1139)
at org.eclipse.jface.viewers.AbstractTreeViewer.updatePlus(Abst ractTree=
Viewer.java:1587)
at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem( Abstract=
TreeViewer.java:382)
at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractT reeViewe=
r.java:361)
at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren( Abstract=
TreeViewer.java:342)
at org.eclipse.jface.viewers.AbstractTreeViewer$5.run(AbstractT reeViewe=
r.java:787)
at org.eclipse.jface.viewers.StructuredViewer.preservingSelecti on(Struc=
turedViewer.java:862)
at org.eclipse.jface.viewers.AbstractTreeViewer.inputChanged(Ab stractTr=
eeViewer.java:777)
at org.eclipse.jface.viewers.ContentViewer.setInput(ContentView er.java:=
238)
at org.eclipse.jface.viewers.StructuredViewer.setInput(Structur edViewer=
..java:1059)
at org.eclipse.debug.internal.ui.views.variables.VariablesView. setViewe=
rInput(VariablesView.java:393)
at org.eclipse.debug.internal.ui.views.variables.VariablesView. selectio=
nChanged(VariablesView.java:1250)
at org.eclipse.debug.internal.ui.views.variables.VariablesView. becomesV=
isible(VariablesView.java:1385)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
at org.eclipse.ui.internal.PerspectiveBarContributionItem.selec t(Perspe=
ctiveBarContributionItem.java:106)
at org.eclipse.ui.internal.PerspectiveBarManager$1.widgetSelect ed(Persp=
ectiveBarManager.java:136)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java=
:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)=
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.PerspectiveBarManager.handleChevron( Perspect=
iveBarManager.java:152)
at org.eclipse.ui.internal.PerspectiveSwitcher$5.widgetSelected (Perspec=
tiveSwitcher.java:402)
:89)
va:254)
6)
tivator.java:335)
ava:273)
ava:129)
..java:39)
ssorImpl.java:25)
!SUBENTRY 1 org.eclipse.jdt.debug 4 5010 Jan 17, 2005 15:41:11.578
!MESSAGE org.eclipse.jdi.TimeoutException occurred determining if object=
has been garbage collected.
!STACK 0
enceImpl.java:388)
lue.java:286)
JDIValue.java:192)
alue.java:379)
eeViewer.java:1139)
Viewer.java:1587)
r.java:361)
r.java:787)
eeViewer.java:777)
238)
..java:1059)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
:89)
:89)
Re: VE and Debugging are awfully slow ? [message #77413 is a reply to message #77399] Mon, 17 January 2005 10:40 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Thomas,
Perhaps your firewall or some other program messed with your loopback
routing. Take a look at the file C:\winnt\system32\drivers\etc\hosts in
a text editor. Make sure that there's a line that says:
127.0.0.1 localhost
Otherwise, I'm stumped. You can ask about the slowness of the debugger
in the eclipse.tools.jdt newsgroup - someone there will most likely have
an idea of what's going on.
- Jeff
> Eclipse and did not changed anything (but I included java into the
> path-variable)
> Regards
> Thomas
Re: VE and Debugging are awfully slow ? [message #77429 is a reply to message #77376] Mon, 17 January 2005 10:41 Go to previous messageGo to next message
I still have an idea - maybe there are some winow services needed ? I se=
t =
all the services I haven't used so far to manual or disabled
Thomas
Re: VE and Debugging are awfully slow ? [message #77443 is a reply to message #77413] Mon, 17 January 2005 10:55 Go to previous messageGo to next message
And so I do now.
I couldn't know at the beginning that the VE problem seems to be the sam=
e =
as the debug problem.
Anyway, thanks for the help :-)
Thomas
Perhaps your firewall or some other program messed with your loopback =
C:\winnt\system32\drivers\etc\hosts in a text editor. Make sure that =
127.0.0.1 localhost
Otherwise, I'm stumped. You can ask about the slowness of the debugger =
in =
likely have an idea of what's going on.
- Jeff
Re: VE and Debugging are awfully slow ? [message #77582 is a reply to message #77429] Mon, 17 January 2005 17:30 Go to previous messageGo to next message
> set all the services I haven't used so far to manual or disabled
Maybe. Try turning them all on again, and see if that fixes it. Then
if it does, try turning them off one-by-one until you see which one
breaks it again.
Dave Orme
Re: VE and Debugging are awfully slow ? [message #81581 is a reply to message #77413] Wed, 23 February 2005 17:24 Go to previous message
Originally posted by: none.nowhere.com
Jeff Myers wrote:
> Thomas,
> 127.0.0.1 localhost
> - Jeff
Thomas:
I had a similar experience with Eclipse then I tried Netbeans and DRJava
and they were the same.
It turns out that the latest version of the ZoneAlarm firewall was the
cause of my problems. I reverted to an earlier version (5.5.062.000)
and my problems went away.
Don.
Re: VE and Debugging are awfully slow ? [message #604548 is a reply to message #77110] Sun, 16 January 2005 16:18 Go to previous message
time.
> Thomas Ballmann
Rich Kulp
Re: VE and Debugging are awfully slow ? [message #604551 is a reply to message #77173] Sun, 16 January 2005 16:31 Go to previous message
be =
e =
this)
Thomas Ballmann
Re: VE and Debugging are awfully slow ? [message #604560 is a reply to message #77189] Sun, 16 January 2005 16:38 Go to previous message
> change this)
> Thomas Ballmann
Rich Kulp
Re: VE and Debugging are awfully slow ? [message #604568 is a reply to message #77220] Sun, 16 January 2005 17:05 Go to previous message
ld =
>> change this)
>> Thomas Ballmann
Thomas Ballmann
Re: VE and Debugging are awfully slow ? [message #604572 is a reply to message #77251] Sun, 16 January 2005 17:51 Go to previous message
anything useful.
are logged.
Rich Kulp
Re: VE and Debugging are awfully slow ? [message #604576 is a reply to message #77251] Sun, 16 January 2005 19:24 Go to previous message
GEF 3.0.1.
EMF 2.0.1
VE 1.0.1
popped up.
00 =
o =
r =
ms.
d =
y =
>>> change this)
>>> Thomas Ballmann
Thomas Ballmann
Re: VE and Debugging are awfully slow ? [message #604579 is a reply to message #77267] Sun, 16 January 2005 20:14 Go to previous message
minutes.
n =
g =
or
or
Thomas
> anything useful.
> are logged.
!STACK 0
enceImpl.java:454)
read.java:217)
..java:200)
spatcher.java:137)
her.java:221)
!STACK 0
enceImpl.java:454)
read.java:217)
..java:200)
spatcher.java:137)
her.java:221)
No soution - but found out the basic problem [message #604585 is a reply to message #77267] Mon, 17 January 2005 06:23 Go to previous message
Hi Rich,
problem is that the
t. =
g =
Thomas
> anything useful.
> are logged.
Re: VE and Debugging are awfully slow ? [message #604605 is a reply to message #77283] Mon, 17 January 2005 10:21 Go to previous message
> GEF 3.0.1.
> EMF 2.0.1
> VE 1.0.1
Dave Orme
Re: VE and Debugging are awfully slow ? [message #604609 is a reply to message #77376] Mon, 17 January 2005 10:29 Go to previous message
se =
Thomas
nd =
> Dave Orme
Thomas Ballmann
..core.runtime".
!STACK 1
ption
mpl.java:187)
pl.java:140)
orm.java:616)
va:450)
orm.java:616)
ewer.java:1094)
nchView.java:965)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
8)
ava:106)
va:254)
6)
tivator.java:335)
ava:273)
ava:129)
..java:39)
ssorImpl.java:25)
es.
!STACK 0
mpl.java:187)
pl.java:140)
orm.java:616)
va:450)
orm.java:616)
ewer.java:1094)
nchView.java:965)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
8)
ava:106)
va:254)
6)
tivator.java:335)
ava:273)
ava:129)
..java:39)
ssorImpl.java:25)
es.
!STACK 0
mpl.java:187)
pl.java:140)
orm.java:616)
va:450)
orm.java:616)
ewer.java:1094)
nchView.java:965)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
8)
ava:106)
va:254)
6)
tivator.java:335)
ava:273)
ava:129)
..java:39)
ssorImpl.java:25)
!STACK 1
ption
mpl.java:187)
pl.java:140)
orm.java:616)
va:450)
orm.java:616)
ewer.java:1094)
nchView.java:965)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
8)
ava:106)
va:254)
6)
tivator.java:335)
ava:273)
ava:129)
..java:39)
ssorImpl.java:25)
es.
!STACK 0
mpl.java:187)
pl.java:140)
orm.java:616)
va:450)
orm.java:616)
ewer.java:1094)
nchView.java:965)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
8)
ava:106)
va:254)
6)
tivator.java:335)
ava:273)
ava:129)
..java:39)
ssorImpl.java:25)
!STACK 1
ption
a:130)
:72)
riable.java:89)
ugHover.java:212)
bugHover.java:161)
anager.java:160)
e.
!STACK 0
a:130)
:72)
riable.java:89)
ugHover.java:212)
bugHover.java:161)
anager.java:160)
!STACK 1
ption
mpl.java:187)
pl.java:140)
bugHover.java:159)
anager.java:160)
es.
!STACK 0
mpl.java:187)
pl.java:140)
bugHover.java:159)
anager.java:160)
!STACK 0
mpl.java:676)
IThread.java:2516)
!STACK 0
mpl.java:676)
IThread.java:2516)
!STACK 1
ption
enceImpl.java:388)
lue.java:286)
JDIValue.java:192)
alue.java:379)
eeViewer.java:1139)
Viewer.java:1587)
r.java:361)
r.java:787)
eeViewer.java:777)
238)
..java:1059)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
:89)
:89)
va:254)
6)
tivator.java:335)
ava:273)
ava:129)
..java:39)
ssorImpl.java:25)
!STACK 0
enceImpl.java:388)
lue.java:286)
JDIValue.java:192)
alue.java:379)
eeViewer.java:1139)
Viewer.java:1587)
r.java:361)
r.java:787)
eeViewer.java:777)
238)
..java:1059)
va:139)
orm.java:616)
erList2.java:137)
..java:139)
tack.java:946)
ainer.java:432)
..java:155)
ava:2818)
ge.java:743)
8)
ava:2959)
:89)
:89)
Re: VE and Debugging are awfully slow ? [message #604613 is a reply to message #77399] Mon, 17 January 2005 10:40 Go to previous message
Thomas,
127.0.0.1 localhost
- Jeff
> path-variable)
> Regards
> Thomas
Re: VE and Debugging are awfully slow ? [message #604618 is a reply to message #77376] Mon, 17 January 2005 10:41 Go to previous message
t =
Thomas
Re: VE and Debugging are awfully slow ? [message #604623 is a reply to message #77413] Mon, 17 January 2005 10:55 Go to previous message
And so I do now.
e =
Thomas
127.0.0.1 localhost
in =
- Jeff
Re: VE and Debugging are awfully slow ? [message #604665 is a reply to message #77429] Mon, 17 January 2005 17:30 Go to previous message
breaks it again.
Dave Orme
Re: VE and Debugging are awfully slow ? [message #605579 is a reply to message #77413] Wed, 23 February 2005 17:24 Go to previous message
Jeff Myers wrote:
> Thomas,
> 127.0.0.1 localhost
> - Jeff
Thomas:
Don.
Previous Topic:How to create Table Dynamically in SWT
Next Topic:Visual Cafe
Current Time: Tue Jul 15 12:52:42 EDT 2025
Powered by FUDForum. Page generated in 0.38807 seconds
