Home » Archived » Visual Editor (VE) » reopen a project with VE
reopen a project with VE [message #77086] Sat, 15 January 2005 05:24 Go to next message
Originally posted by: cialdi_HATE_SP.M_gmail.com
Where I work I started project using VE. Then I had copied the whole
project directory tree, and I reopened it at home. It is reopened as norma
project: no way to reedit the panels and frames visually, the java beans
view is empty.
How can I reopen that project using VE?
thanks
Re: reopen a project with VE [message #77093 is a reply to message #77086] Sat, 15 January 2005 06:44 Go to previous message
> norma project: no way to reedit the panels and frames visually, the java
> beans view is empty.
> thanks
In the Package Explorer, select file, right-click and then Open With ->
Visual Editor. Eclipse remembers the last used editor of the file, so
the next time you double click the file, it will open with VE again
(Open With -> Java Editor to revert to 'plain' Java editing).
[Of course, you need to have VE installed on your home machine.]
HTH,
Z.
Re: reopen a project with VE [message #604523 is a reply to message #77086] Sat, 15 January 2005 06:44 Go to previous message
> thanks
HTH,
Z.
Previous Topic:reopen a project with VE
Next Topic:VE and Debugging are awfully slow ?
Current Time: Fri Jul 18 02:01:05 EDT 2025
Powered by FUDForum. Page generated in 0.07994 seconds
