Remove whitespaces from generation [message #76988] |
Wed, 28 March 2007 11:12  |
Originally posted by: matroska.libero.it
i am using emft jet generation to create java code however i cannot find
how to remove whitespaces (these whitespaces are that from used tags).
Thanks in advance
Tobia Loschiavo
Re: Remove whitespaces from generation [message #78355 is a reply to message #77898] |
Wed, 04 April 2007 08:18   |
Stu:
<c:log>Log here</c:log>
would add a line, while
<c:log>
Log here
</c:log>
will not.
The whitespace/line stripping would have to get smarter about the intent of
individual tags to successfully do the right thing on:
and, and the same time:
<f:lc>Lower Case here</f:lc>
I'll give it some thought. Here's a bugzilla to track it...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=180927
Paul
"Stu" <evaandoli@dodo.com.au> wrote in message
news:euqsgl$rhf$1@build.eclipse.org...
>I have all comments on a separate line so it must be something else. I'll
>look more into it and post something with more detail if I can narrow it
>down.
> The <c:log>Log here</c:log>
> Seems to add a blank line is what I have found so far.
> Cheers for all your time.
> Stu
> "Paul Elder" <pelder@ca.ibm.com> wrote in message
> news:euqrei$jfl$1@build.eclipse.org...
>> Stu:
>> No, just put them on a separate line.
>> I'll have another look at the new line trimming algorthim to see if I can
>> make it more friendly with respect to comments. No promises for this
>> release, so it still comes down to, put your comments on a separate line.
>> <%-- Good: do something --%>
>> <c:iterate ... >
>> <c:iterate ...> <%-- Bad: will result in a an unexpected new line --%>
>> Paul
>> news:eugl88$70b$1@build.eclipse.org...
>>>I get the same thing and yes I have comments all over the place trying to
>>>make the text understandable.
>>> Are you saying to remove these ghost blank lines you have to remove all
>>> comments ? Seems a shame.
>>> news:eugbj7$qk8$1@build.eclipse.org...
>>>> John:
>>>> JET2 removes write space when a tag (or other language element) is
>>>> alone on a line.
>>>> Rule of thumb: If you don't want write space associated with a tag, put
>>>> it on its own line.
>>>> So:
>>>> <c:iterate select... >
>>>> Some code
>>>> </c:iterate>
>>>> Should produce
>>>> Some code
>>>> Some code
>>>> Some code
>>>> But, if you put a comment on the line
>>>> <c:iterate select... > <%-- a comment --%>
>>>> Some code
>>>> </c:iterate>
>>>> You'd get:
>>>> Some code
>>>> Some code
>>>> Some code
>>>> "Ed Merks" <merks@ca.ibm.com> wrote in message
>>>> news:euelal$d3e$1@build.eclipse.org...
>>>>> John,
>>>>> Please use the M2T newsgroup for JET2 questions. I've added it to the
>>>>> "to" list so Paul should see your question. He might need more detail
>>>>> though. Often the goodness of the answer is proportional to the
>>>>> amount of information provided in the question...
>>>>> John Slave wrote:
>>>>>> Hi,
>>>>>> find how to remove whitespaces (these whitespaces are that from used
>>>>>> tags).
>>>>>> Thanks in advance
>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #79526 is a reply to message #78355] |
Thu, 12 April 2007 00:47   |
Originally posted by: evaandoli.dodo.com.au
Ok I got around to finding my problem with a blank line appearing when I
think it shouldnt.
Here is the line that caused trouble:-
PreText1
<c:addTextElement select="$conductorType/valueHolder" name="notFoundName"
var="notFound">NotFound</c:addTextElement>
PostText1
Output looks like:
PreText1
PostText1
I tried:-
var="notFound">
NotFound
</c:addTextElement>
but got the same result.
Stuart
news:ev053l$dvg$1@build.eclipse.org...
> Stu:
> <c:log>
> Log here
> </c:log>
> will not.
> of individual tags to successfully do the right thing on:
> Paul
>>down.
>> Stu
>>> Stu:
>>> can make it more friendly with respect to comments. No promises for this
>>> line.
>>> <c:iterate ... >
>>> Paul
>>>>to make the text understandable.
>>>>> John:
>>>>> alone on a line.
>>>>> put it on its own line.
>>>>> So:
>>>>> Some code
>>>>> </c:iterate>
>>>>> Should produce
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> </c:iterate>
>>>>> You'd get:
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>>> John,
>>>>>> the "to" list so Paul should see your question. He might need more
>>>>>> detail though. Often the goodness of the answer is proportional to
>>>>>> the amount of information provided in the question...
>>>>>> John Slave wrote:
>>>>>>> Hi,
>>>>>>> tags).
>>>>>>> Thanks in advance
>>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #79835 is a reply to message #79526] |
Fri, 13 April 2007 08:17  |
Stu:
Thanks for you persistence. I have filed bug 182311
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=182311). I'll be fixed
shortly.
Paul
news:evkdkp$952$1@build.eclipse.org...
> think it shouldnt.
> PreText1
> PostText1
> Output looks like:
> PreText1
> PostText1
> I tried:-
> var="notFound">
> NotFound
> </c:addTextElement>
> Stuart
Re: Remove whitespaces from generation [message #603923 is a reply to message #76988] |
Wed, 28 March 2007 17:05  |
John,
though. Often the goodness of the answer is proportional to the amount
John Slave wrote:
> tags).
> Thanks in advance
> Tobia Loschiavo
Re: Remove whitespaces from generation [message #603979 is a reply to message #76997] |
Thu, 29 March 2007 08:31  |
John:
JET2 removes write space when a tag (or other language element) is alone on
a line.
Rule of thumb: If you don't want write space associated with a tag, put it
on its own line.
So:
Some code
</c:iterate>
Should produce
Some code
Some code
Some code
Some code
</c:iterate>
You'd get:
Some code
Some code
Some code
> John,
> though. Often the goodness of the answer is proportional to the amount of
> John Slave wrote:
>> Thanks in advance
>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604024 is a reply to message #77290] |
Thu, 29 March 2007 11:16  |
> John:
> on a line.
> on its own line.
> So:
> Some code
> </c:iterate>
> Should produce
> Some code
> Some code
> Some code
> Some code
> </c:iterate>
> You'd get:
> Some code
> Some code
> Some code
>> John,
>> John Slave wrote:
>>> Hi,
>>> Thanks in advance
>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604156 is a reply to message #76997] |
Sat, 31 March 2007 11:31  |
Something else I notice is a blank line appears in generation if you put a
<c:log> </c:log> line in.
> John,
> John Slave wrote:
>> Thanks in advance
>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604170 is a reply to message #77471] |
Mon, 02 April 2007 08:03  |
Stu:
<c:iterate ... >
Paul
>> John:
>> on a line.
>> it on its own line.
>> So:
>> Some code
>> </c:iterate>
>> Should produce
>> Some code
>> Some code
>> Some code
>> Some code
>> </c:iterate>
>> You'd get:
>> Some code
>> Some code
>> Some code
>>> John,
>>> John Slave wrote:
>>>> Hi,
>>>> tags).
>>>> Thanks in advance
>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604174 is a reply to message #77882] |
Mon, 02 April 2007 08:21  |
down.
Stu
> Stu:
> <c:iterate ... >
> Paul
>>> John:
>>> on a line.
>>> it on its own line.
>>> So:
>>> Some code
>>> </c:iterate>
>>> Should produce
>>> Some code
>>> Some code
>>> Some code
>>> Some code
>>> </c:iterate>
>>> You'd get:
>>> Some code
>>> Some code
>>> Some code
>>>> John,
>>>> John Slave wrote:
>>>>> Hi,
>>>>> tags).
>>>>> Thanks in advance
>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604333 is a reply to message #77898] |
Stu:
<c:log>
Log here
</c:log>
will not.
Paul
>down.
> Stu
>> Stu:
>> <c:iterate ... >
>> Paul
>>>> John:
>>>> alone on a line.
>>>> it on its own line.
>>>> So:
>>>> Some code
>>>> </c:iterate>
>>>> Should produce
>>>> Some code
>>>> Some code
>>>> Some code
>>>> Some code
>>>> </c:iterate>
>>>> You'd get:
>>>> Some code
>>>> Some code
>>>> Some code
>>>>> John,
>>>>> John Slave wrote:
>>>>>> Hi,
>>>>>> tags).
>>>>>> Thanks in advance
>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604663 is a reply to message #78355] |
think it shouldnt.
PreText1
PostText1
Output looks like:
PreText1
PostText1
I tried:-
var="notFound">
NotFound
</c:addTextElement>
Stuart
> Stu:
> <c:log>
> Log here
> </c:log>
> will not.
> Paul
>>down.
>> Stu
>>> Stu:
>>> line.
>>> <c:iterate ... >
>>> Paul
>>>>> John:
>>>>> alone on a line.
>>>>> So:
>>>>> Some code
>>>>> </c:iterate>
>>>>> Should produce
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>> </c:iterate>
>>>>> You'd get:
>>>>> Some code
>>>>> Some code
>>>>> Some code
>>>>>> John,
>>>>>> John Slave wrote:
>>>>>>> Hi,
>>>>>>> tags).
>>>>>>> Thanks in advance
>>>>>>> Tobia Loschiavo
Re: Remove whitespaces from generation [message #604735 is a reply to message #79526] |
Stu:
shortly.
Paul
> think it shouldnt.
> PreText1
> PostText1
> Output looks like:
> PreText1
> PostText1
> I tried:-
> var="notFound">
> NotFound
> </c:addTextElement>
> Stuart
FUDForum. Page generated in 0.34514 seconds
