Home » Modeling » Epsilon » epsilon.disposeModel ref attribute
epsilon.disposeModel ref attribute [message #6918] Fri, 12 December 2008 11:16 Go to next message
I'm trying to remove a specific model midway through a build file, but
couldn't achieve what the Epsilon Book pdf says (section 13.4.4).
I believe the right thing to use is the epsilon.disposeModel task, and to
specify a ref attribute, as stated. The task had the form:
<epsilon.disposeModel ref="SomeModel"/>
Though, when I run this I get an error saying that epsilon.disposeModel
doesn't support the "ref" attribute. Maybe I've not found an example usage
of it somewhere?
Have a good weekend,
Edd
Re: epsilon.disposeModel ref attribute [message #6942 is a reply to message #6918] Fri, 12 December 2008 12:36 Go to previous messageGo to next message
Hi Edd,
This is an error in the book (I'll fix it shortly). The correct way is
to use model instead of ref:
<epsilon.disposeModel model="SomeModel"/>
Dimitris
Edward Turner wrote:
> Hello,
> to specify a ref attribute, as stated. The task had the form:
> usage of it somewhere?
> Edd
Re: epsilon.disposeModel ref attribute [message #6966 is a reply to message #6942] Fri, 12 December 2008 13:45 Go to previous messageGo to next message
Ah, that's great. Many thanks :)
Edd
Re: epsilon.disposeModel ref attribute [message #6989 is a reply to message #6966] Fri, 12 December 2008 14:05 Go to previous message
Thanks for reporting this! It's been fixed in the book now.
Dimitris
> Edd
Re: epsilon.disposeModel ref attribute [message #563030 is a reply to message #6918] Fri, 12 December 2008 12:36 Go to previous message
Hi Edd,
Dimitris
> Hello,
> Edd
Re: epsilon.disposeModel ref attribute [message #563055 is a reply to message #6942] Fri, 12 December 2008 13:45 Go to previous message
Edd
Re: epsilon.disposeModel ref attribute [message #563076 is a reply to message #6966] Fri, 12 December 2008 14:05 Go to previous message
Dimitris
> Edd
Previous Topic:epsilon.disposeModel ref attribute
Next Topic:Loading multiple model instances, for translation
Current Time: Thu Jul 17 22:40:41 EDT 2025
Powered by FUDForum. Page generated in 0.27110 seconds
