Home » Eclipse Projects » GEF » Where to start when creating a new GEF plugin?
Where to start when creating a new GEF plugin? [message #76971] Sun, 27 April 2003 06:09 Go to next message
Originally posted by: newseclipse.dagerot.nu
I'm about to write a simple DocBook WYSIWYG editor and have been told that
the GEF is the right path to follow.
I have downloaded GEF SDK and Samples but still have a feeling that I'm
floating around. Can someone point me to a "Create your first textbased GEF
editor" or any similar resource.
Also I appreciate all references to non-spec-type documents regarding GEF.
It's somewhat hard to read java-API's without having any idea on what the
GEF does.
note: I have downloaded and installed the GEF logic example, but there was
no help-guide bundled as the case with JDT.
Re: Where to start when creating a new GEF plugin? [message #77051 is a reply to message #76971] Sun, 27 April 2003 21:25 Go to previous messageGo to next message
Are you trying to create an editor that supports text entry? Something like
Microsoft's FrontPage?
"Joachim Dagerot" <newseclipse@dagerot.nu> wrote in message
news:b8ga85$141$1@rogue.oti.com...
GEF
> GEF does.
Re: Where to start when creating a new GEF plugin? [message #77225 is a reply to message #77051] Mon, 28 April 2003 05:34 Go to previous messageGo to next message
Yes, exactly. I don't aim for competing with XMetal, XML Spy or frontpage.
But to create a tailored editor for the DocBook format.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b8hvug$s5j$1@rogue.oti.com...
like
that
> GEF
GEF.
the
> > GEF does.
was
Re: Where to start when creating a new GEF plugin? [message #77257 is a reply to message #77225] Mon, 28 April 2003 17:12 Go to previous messageGo to next message
Creating a wysiwyg text document editor is not a small task. This has been
done already in IBM's Page Designer, which uses GEF. However, nothing
reusable has been pushed up into GEF.
You might look at the draw2d.text packages for some simple paragraph and
block support. This package could be extended to support tables, margins,
etc., but this is not in the plan. As far as managing a caret and
range-based selection, there is nothing in GEF for this.
news:b8k1ls$iil$1@rogue.oti.com...
> like
> that
I'm
textbased
> > GEF
> GEF.
> the
> > > GEF does.
> was
Re: Where to start when creating a new GEF plugin? [message #77384 is a reply to message #77257] Tue, 29 April 2003 15:22 Go to previous message
Hmmm, everyone I've been talking to says this will be a huge task or that
it's not that simple. I think I'll just sit tight until someone else
releases the idea! :-\
Thanks for your help anyway!
news:b8k5gf$lql$1@rogue.oti.com...
been
frontpage.
Something
> > like
told
> > that
> I'm
> textbased
> > > GEF
regarding
> > GEF.
what
> > the
> > > > GEF does.
there
> > was
Previous Topic:How to implement DND DROP_COPY in Outline
Next Topic:Mapping model elements to EditParts
Current Time: Tue Jul 22 13:54:27 EDT 2025
Powered by FUDForum. Page generated in 0.71333 seconds
