Side-By-Side Bar [message #76945] |
Fri, 23 September 2005 16:23  |
Originally posted by: Vasundara.xxxx.com
Could some one tell me how do i get Side-By-Side Bar charts for three
columns one besides the other.
I did try the 2d side by side bar.I tried to insert more than two columns
in x-series say row[day],row[component]
On y series row[cost], I want to get side by side bars on x-axis for both
row day value and component value
Help Appreciated.
Vasundara
Re: Side-By-Side Bar [message #77153 is a reply to message #77038] |
Mon, 26 September 2005 12:50  |
Thank You .Got it !!!
David Michonneau wrote:
> Hi Vasun,
> I think you are confused between the X Axis and Y series. What you need is
> two Y Series: you can create them in the Y Axis page (set the number of
> series to 2), then fill each Y Serie Data Definition.
> David
> "Vasun" <Vasundara@xxxx.com> wrote in message
> news:99d90c759772c2a6a7e0e4438b2818da$1@www.eclipse.org...
>> Hello,
>> I kept X-axis type as DateTime but one column day is datetime and
>> component is text.[As i said iam trying to get two side by side bars on
>> chart and inserted row[day],row[component] on x-axis.
>> Y-axis type is linear.i get this error when i use them
>> There are errors on the report page: + There are error(s) in Chart:null
>> Error0 : data.engine.InvalidJSExpr(13times)detail: Invalid Javascript
>> expression: row["MONTH"] row["YEAR"]missing ; before statementmissing ;
>> before statementError1 : Error.ExtendedItemRenderingError(1 time)detail:
>> There are problems(s) rendering Chart extended item .The dataset used by
>> the Chart is invalidThe dataset used by the Chart is invalid
>> other wise if i change the x-axis type to text i get the chart but not
>> side-by-side bars.
>> Help
>> Vasundara
>> Vasun wrote:
>>> Hello,
>>> Help Appreciated.
>>> Vasundara
FUDForum. Page generated in 0.03093 seconds
