Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Problem using JOINED value for PersistenceOptions.INHERITANCE_MAPPING
[Teneo] Problem using JOINED value for PersistenceOptions.INHERITANCE_MAPPING [message #76933] |
Tue, 27 March 2007 17:30  |
Martin,
I have a problem in that my model has sub-classes which have attributes of
the same name, but different types. So using the default SINGLE_TABLE will
not work.
I tried to set the PersistenceOptions.INHERITANCE_MAPPING to JOINED, but
then have a problem in that there seems to be a limit in mysql that
prevents accessing my objects when there are more than 61 tables in a
join...
So, can I use TABLE_PER_CLASS.? If so how do I handle the issue with not
being able to use generated column keys...?
I get this when I use TABLE_PER_CLASS..
Exception in thread "main" org.hibernate.MappingException: Cannot use
identity column key generation with <union-subclass> mapping for:
AttrCueSource
org.hibernate.persister.entity.UnionSubclassEntityPersister. <init>(UnionSubclassEntityPersister.java:67)
org.hibernate.persister.PersisterFactory.createClassPersiste r(PersisterFactory.java:61)
Mark.
Re: [Teneo] Problem using JOINED value for PersistenceOptions.INHERITANCE_MAPPING [message #76948 is a reply to message #76933] |
Tue, 27 March 2007 17:41   |
--------------050409010800020100050706
Mark,
For single-table: you can try to set a column annotation on these attributes with the same name so
that they are stored in different columns.
So something like:
@Column(name="myothercolumnname")
Or for table-per-class you can use a different id-strategy (there are others which also
auto-generate the ids). I attached an example which is used as a testcase in Teneo.
Note that you can also set annotations on EDataType, that is sometimes easier if efeatures share the
same edatatype.
gr. Martin
Mark wrote:
> Martin,
> of the same name, but different types. So using the default SINGLE_TABLE
> will not work.
> join...
> AttrCueSource
> at
> at
> Mark.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Content-Type: text/xml;
name="id.ecore"
Content-Disposition: inline;
filename="id.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="id"
nsURI=" http://www.eclipse.org/emf/teneo/samples/emf/annotations/hb/ generator/id"
nsPrefix="id">
<eAnnotations source="teneo.hibernate">
<details key="appinfo" value="
@GenericGenerator(name="system-uuid&qu ot;, strategy = "uuid")
@GenericGenerator(name=&am p;quot;hibseq", strategy = "hilo",
 parameters = {
 @Parameter(name="table", value = "hilo_table"),
 @Parameter(name="column", value="the_hilo_column")
</eAnnotations>
<eClassifiers xsi:type="ecore:EClass" name="IdentityID">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="IdentityID"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="myid" unique="false" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Long" unsettable="true">
				@Id @GeneratedValue(strategy="IDENTITY")&# xA;			 "/>
</eAnnotations>
<details key="kind" value="element"/>
<details key="name" value="myid"/>
</eAnnotations>
</eStructuralFeatures>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="SimpleID">
<details key="name" value="SimpleID"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="autoID" unique="false"
lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//Long"
unsettable="true">
				@Id @GeneratedValue
				@Column(name=&a mp;quot;AUTOD" nullable="false")
	&#x 9;	 "/>
</eAnnotations>
<details key="name" value="autoID"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="TableID">
<details key="name" value="TableID"/>
</eAnnotations>
				@Id @GeneratedValue(generator="hibseq")&#x A;			 "/>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
--------------050409010800020100050706--
Re: [Teneo] Problem using JOINED value for PersistenceOptions.INHERITANCE_MAPPING [message #76962 is a reply to message #76948] |
Tue, 27 March 2007 17:50  |
As an extra tip, after adding annotations to the ecore you need to regenerate the java code (and the
hbm file), otherwise the annotations are not visible at runtime.
Annotations can also be added in a separate xml file, then regeneration of the java code is not
required. See the elver.org website for more information.
gr. Martin
Martin Taal wrote:
> Mark,
> attributes with the same name so that they are stored in different columns.
> So something like:
> others which also auto-generate the ids). I attached an example which is
> easier if efeatures share the same edatatype.
> gr. Martin
> Mark wrote:
>> Martin,
>> attributes of the same name, but different types. So using the default
>> SINGLE_TABLE will not work.
>> but then have a problem in that there seems to be a limit in mysql
>> that prevents accessing my objects when there are more than 61 tables
>> in a join...
>> not being able to use generated column keys...?
>> AttrCueSource
>> at
>> at
>> Thanks,
>> Mark.
> nsPrefix="id">
 parameters = {
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> unsettable="true">
				@Id @GeneratedValue
	&#x 9;	 "/>
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
a
The Netherlands
Re: [Teneo] Problem using JOINED value for PersistenceOptions.INHERITANCE_MAPPING [message #603909 is a reply to message #76933] |
Mark,
So something like:
same edatatype.
gr. Martin
Mark wrote:
> Martin,
> will not work.
> join...
> AttrCueSource
> at
> at
> Mark.
The Netherlands
name="id.ecore"
filename="id.ecore"
nsPrefix="id">
 parameters = {
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</eAnnotations>
unsettable="true">
				@Id @GeneratedValue
	&#x 9;	 "/>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
Re: [Teneo] Problem using JOINED value for PersistenceOptions.INHERITANCE_MAPPING [message #603914 is a reply to message #76948] |
gr. Martin
Martin Taal wrote:
> Mark,
> So something like:
> gr. Martin
> Mark wrote:
>> Martin,
>> in a join...
>> AttrCueSource
>> at
>> at
>> Thanks,
>> Mark.
> nsPrefix="id">
 parameters = {
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> unsettable="true">
				@Id @GeneratedValue
	&#x 9;	 "/>
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> </eAnnotations>
> </eAnnotations>
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
a
The Netherlands
Current Time: Tue Jul 22 21:31:11 EDT 2025
Powered by FUDForum. Page generated in 0.06118 seconds
