Home » Modeling » GMF (Graphical Modeling Framework) » Setting a property that should not change afterwards
Setting a property that should not change afterwards [message #76920] Sat, 11 November 2006 21:43 Go to next message
Hi folks,
I have an EClass Link in my meta-model with an attribute "kind" which EType
is an enumerated with 2 posible values: internalLink and externalLink. I
have set the value of the attribute in the different Links using a Feature
Seq Initializer in the .gmfmap and it works perfectly but... How can I avoid
that value to be changed at runtime? If I set the "changeable" atributte to
false, then the initialization doesn't work (the property is always set to
the default value, doesn't matter what I write in the Feature Seq
Initializer).
Any help will be very wellcomed ;-).
Cheers and thanks in advance!
Cristina
Re: Setting a property that should not change afterwards [message #77831 is a reply to message #76920] Wed, 15 November 2006 09:37 Go to previous message
Originally posted by: 5d5.mail.ru
And what happens if "changeable" is true? Maybe you should just not
expose this property in property sheet?
Cristina wrote:
> Hi folks,
> Initializer).
> Cristina
Previous Topic:enforce fixed node size on node creation
Next Topic:Relaxed dependency on GDI+ ?
Current Time: Mon Jul 21 22:24:45 EDT 2025
Powered by FUDForum. Page generated in 0.03127 seconds
