Home » Language IDEs » C / C++ IDE (CDT) » Using make
Using make [message #76900] Thu, 24 July 2003 12:19 Go to next message
I remember that there was a way to automatically have a makefile keep track
of the which "h" files are needed by a "cpp" file. Can someone refresh my
memory of how to set up a make-depend.
Re: Using make [message #76916 is a reply to message #76900] Thu, 24 July 2003 12:27 Go to previous messageGo to next message
http://opensource.cph.dk/xfree86/htdocs/4.3.0/makedepend.1.h tml
"shmuel siegel" <hard2@writeme.com> wrote in message
news:bfp0qr$a7t$1@eclipse.org...
track
Re: Using make [message #76932 is a reply to message #76916] Thu, 24 July 2003 13:57 Go to previous messageGo to next message
track
my
If you use gcc you can use "g++ -MM *.cpp >> .depend" which will write all
the dependencies of all cpp files to the file .depend, excluding all the
system headers. Below is a Makefile in which it is used.
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
tel: 024-3888063 / 06-51855277
fax: 024-3608416
email: J.Kraaijeveld@Askesis.nl
web: www.askesis.nl
####### Start of a sample makefile
####### Directory options
TARGETDIR = ../../Targets/Bin
OBJECTSDIR = ../../Objects/Exe
####### Files
SOURCES := $(wildcard *.cpp)
OBJECTS = $(patsubst %.cpp, $(OBJECTSDIR)/%.o, $(SOURCES))
TARGET = $(TARGETDIR)/Main.exe
####### C++ Compiler options
CXX = g++
CXXFLAGS = -c
####### Common Compiler options
INCPATH = -I ../Dll
####### Linker options
LINK = g++
LFLAGS =
LIBS = $(TARGETDIR)/libObject.dll
####### Pattern matching rule for .cpp file
$(OBJECTSDIR)/%.o : %.cpp
$(CXX) $(CXXFLAGS) $(INCPATH) $< -o $@
####### Targets
all: $(TARGET)
$(TARGET) : .depend $(OBJECTS)
$(LINK) $(LFLAGS) -o$(TARGET) $(OBJECTS) $(LIBS)
..depend:
-rm -f .depend
$(CXX) -MM *.cpp | sed 's/^/$$(OBJECTSDIR)\//' >> .depend
clean:
-rm .depend
-rm $(OBJECTS)
-rm $(TARGET)
ifeq (.depend, $(wildcard .depend))
include .depend
endif
Re: Using make [message #77050 is a reply to message #76916] Thu, 24 July 2003 16:13 Go to previous messageGo to next message
Thank you, this is what I was looking for. Consider adding this information
to some help page since non Unix users are unlikely to know about it.
"John Camelon" <jcamelon@rational.com> wrote in message
news:bfp1c5$ar8$1@eclipse.org...
> track
my
Re: Using make [message #77071 is a reply to message #76932] Thu, 24 July 2003 21:35 Go to previous messageGo to next message
Originally posted by: alain.nowhere.ca
Joost Kraaijeveld wrote:
Very clever.
They was a suggestion to provide an out-of-the-box
makefile when creating a "std make project" ...
hope you snippet below is not copyrighted 8-)
> ####### Files
> CXX = g++
> CXXFLAGS = -c
> INCPATH = -I ../Dll
> LINK = g++
> LFLAGS =
> ####### Targets
> all: $(TARGET)
> ..depend:
> -rm -f .depend
> $(CXX) -MM *.cpp | sed 's/^/$$(OBJECTSDIR)//' >> .depend
> clean:
> -rm .depend
> -rm $(OBJECTS)
> -rm $(TARGET)
> include .depend
> endif
Re: Using make [message #77084 is a reply to message #77071] Fri, 25 July 2003 00:18 Go to previous messageGo to next message
"alain" <alain@nowhere.ca> wrote in message news:bfq1ga$ch4$1@eclipse.org...
> Very clever.
Feel free to use it
Joost Kraaijeveld
Askesis B.V.
Molukkenstraat 14
6524NB Nijmegen
fax: 024-3608416
web: www.askesis.nl
Re: Using make [message #77907 is a reply to message #77084] Wed, 06 August 2003 02:41 Go to previous message
Originally posted by: simon.ou.edu
Hi Joost...
Could this kind of makefile be automated into a plugin? Thanks.
Regards...
Miguel.
>>Very clever.
> Feel free to use it
Previous Topic:CDT for 3.0?
Next Topic:Does CDT work with Eclipse 2.1.1?
Current Time: Tue Jul 15 06:11:04 EDT 2025
Powered by FUDForum. Page generated in 0.03122 seconds
