Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Error Resolving Buckminster
Re: [buckminster-dev] Error Resolving Buckminster [message #6908] Tue, 26 February 2008 16:57
Hi Todd,
No, there was no change. But this gremlin worries me a bit. You're not
the first to have an encounter with it.
Could the problem be caused by you having several previous dormant
versions of Buckminster installed in your Eclipse runtime? The reason I
ask is that last time this happened, I suspect that was the cause. I'm
not sure however. Trying to triangulate :-)
Thomas Hallgren
Todd_Lee@amis.com wrote:
> Apparently I'm a victim of gremlins. Tried the same thing today and worked
> fine...
> Did the dev-cquery/dogfood2.rmap change?
> Either way, don't worry about it - works now.
> Todd
> AMI Semiconductor - "Silicon Solutions for the Real World"
> NOTICE:
> This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Previous Topic:Re: [buckminster-dev] Error Resolving Buckminster
Next Topic:Re: [buckminster-dev] Error Resolving Buckminster
Current Time: Mon Jul 21 21:11:21 EDT 2025
Powered by FUDForum. Page generated in 0.03332 seconds
