[TENEO] Detect failed login [message #720569] |
Tue, 30 August 2011 16:32  |
In my Application I need a login by the user. Everything works fine but if the User type in a wrong username or password I haven't the possibility to catch the Exception and display a info dialog.
The Exception occur at the moment that i call:
try {
hbds.initialize();
} catch (Exception e) {
//Need to find out a failed login
}finally {
System.out.println(hbds.getMappingXML());
But my code don't run in the catch block. Is there another possibilityto detect a failed login?
Waldi
Re: [TENEO] Detect failed login [message #720595 is a reply to message #720569] |
Tue, 30 August 2011 17:56  |
Hmm, I think you mean that you use the user login to login directly to the database? (and that fails?). I normally use a
fixed username/pwd for a database connection and have a separate table with users/pwds.
In any case if you use the login to login to the database, then to do a pre-check, I would create a normal sql
connection before initializing the datastore.
gr. Martin
On 08/30/2011 10:32 PM, Waldi wrote:
> try {
> hbds.initialize();
> }finally {
> Waldi
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.09265 seconds
