Home » Eclipse Projects » Remote Application Platform (RAP) » Mixing RAP With HTML
Mixing RAP With HTML [message #76836] Wed, 05 March 2008 23:17 Go to next message
Originally posted by: anupgokhale.rediffmail.com
Hi all.
While reading another message on this forum i came across the following
quote:
"have you thought about implementing your login dialog outside of your RAP
application (as pure HTML)? This avoids a long startup time and might
preserve resources, as the whole worbench stuff is only loaded if the user
successfully logs in."
Any ideas on how the above could be done?
Anup Gokhale
Re: Mixing RAP With HTML [message #76853 is a reply to message #76836] Thu, 06 March 2008 02:01 Go to previous message
Originally posted by: fappel.innoopract.com
you can manipulate the startup page for example by using the branding
mechanism. For more information about this see the documentation of the
branding extension point.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Anup Gokhale [mailto:anupgokhale@rediffmail.com]
Bereitgestellt: Donnerstag, 6. März 2008 05:18
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Mixing RAP With HTML
Betreff: Mixing RAP With HTML
Hi all.
RAP application (as pure HTML)? This avoids a long startup time and
might preserve resources, as the whole worbench stuff is only loaded if
the user successfully logs in."
Anup Gokhale
Previous Topic:org.eclipse.rap.search project
Next Topic:UICallback - Server- side refresh
Current Time: Mon Jul 21 21:57:35 EDT 2025
Powered by FUDForum. Page generated in 0.04253 seconds
