Home » Eclipse Projects » Equinox » Component descriptions, update, and Eclipse
Component descriptions, update, and Eclipse [message #76829] Wed, 08 November 2006 16:39
What is the most effective way of updating a bundle and having the
Equinox environment pickup those changes *if the bundle's component
descriptions have changed*? I would like to use a technique that works
from within the Eclipse IDE.
My problem is that often after I update a component description and
restart/update the bundle that contains an updated component
description, the bundle is activated without all the changes. This is
specifically observed when I add a new service reference, and the
activation sequence simply never sets the newly referenced service
object on the component.
I have tried and succeeded in getting the runtime to pick up the new
reference after spending a couple of hours on this issue, but I am not
sure I can repeat the process.
Is there a step I am missing or am I observing buggy behavior?
Thanks for your help,
Nikunj
Previous Topic:Best way to determine whether Equinox is running
Next Topic:Difference between exit and shutdown. Problem with bundle state persistence
Current Time: Tue Jul 08 23:17:25 EDT 2025
Powered by FUDForum. Page generated in 0.06101 seconds
