ARM with AspectJ [message #76825] |
Mon, 10 July 2006 16:34  |
After some cool stuff I saw at the Rational Software Development
Conference 2006, I wanted to checkout the new ARM functionality of Eclipse
TPTP. I'm using Eclipse WTP 1.5, TPTP 4.2 on a Debian Linux (Sid) box. I
managed to get the ARM functionality up and running using Probes
injection. However, no data get's collected when I select the AspectJ
injection. I've installed the AJDT 1.4.0. I'm using the Sun JDK 1.5.0_06
for both Eclipse and the Agent Controller.
Has someone already succeeded in getting ARM up and running using AspectJ?
If so, does someone know how I can get the AspectJ injection to work?
With kind regards,
Duncan
Re: ARM with AspectJ [message #77172 is a reply to message #76825] |
Tue, 11 July 2006 15:27  |
Duncan Doyle wrote:
> Hello,
> Eclipse TPTP. I'm using Eclipse WTP 1.5, TPTP 4.2 on a Debian Linux
> (Sid) box. I managed to get the ARM functionality up and running using
> Probes injection. However, no data get's collected when I select the
> AspectJ injection. I've installed the AJDT 1.4.0. I'm using the Sun JDK
> 1.5.0_06 for both Eclipse and the Agent Controller.
> AspectJ? If so, does someone know how I can get the AspectJ injection to
> work?
> With kind regards,
> Duncan
In your project folder under the output folder (bin) check to see if
there is a META-INF directory with the aop.xml file exists. Also for
aspects you may need to specifically include the packages or classes to
instrument from the Instrument Collector filters. Does your filters
include the class you wish to instrument?
FUDForum. Page generated in 0.06652 seconds
