Home » Archived » Test and Performance Tools Platform (TPTP) » Getting started with hyades...
Getting started with hyades... [message #6903] |
Mon, 21 February 2005 11:20  |
Originally posted by: bikehead.hotmail.com
I've downloaded hyades 3.2 and installed it over eclipse 3.1M5 on Fedora
Core 3. Eclipse works fine, and the hyades UI work, but I seem to be
have problem with the RAServer. I installed it per the instructions,
but when I start it, it seems to terminate immediately. I checked the
log file and it just has one entry for when the server starts and
another for when it terminates; no other information is given.
The instructions seems to imply that once I start the RAServer it
supposed to stay up until I give it a kill signal right? Any
suggestions on why it may be terminating?
Whenever I try and profile the example instructions in the hyades
tutorial I always get a "unable to communciate with agent" message,
which I'm assuming is a result of the RAServer not running.
Brian
Re: Getting started with hyades... [message #6991 is a reply to message #6957] |
Tue, 22 February 2005 12:41   |
--------------060701020600040301020602
Thank you for replying with some suggestions. See my responses below
Samson Wai wrote:
> Hi Brian,
> Have you run the "SetConfig.sh" script under the "bin" directory to generate
> the config files? The RAServer will terminate if it cannot find the config
> files.
Yes I did do this and I checked the resulting config file it generated
and it looked good.
> Do you have the "compat-libstdc++" RPM package installed? The RAServer is
> compiled using the C++ library "libstdc++-libc6.2-2.so.3" which is available
> on older Linux kernels (it is built on Red Hat Linux 7.2).
Yup, have this also.
> Is port 10002 available? RAServer uses that port for incomming connection
> requests. You can check if port 10002 is available by looking at the output
> of "netstat -a".
The port is available.
> Samson
I've attached the log file in case it helps a more knowledgable person.
I also run RAServer under strace and I've attached the last portion of
it (the whole thing is about 128K). I notice the process gets a SEGV
near the end, but its unclear if this is the cause of the problem.
Again, thanks for any help provided. I'd love to try hyades on our product.
-Brian
> "Brian Anderson" <bikehead@hotmail.com> wrote in message
> news:cvd1p4$e6m$1@www.eclipse.org...
>>Thanks,
>>Brian
Content-Type: text/x-log;
name="servicelog.log"
Content-Disposition: inline;
filename="servicelog.log"
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001A50631B2CF702FD26528" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15944" subComponent="framework/RAServerConfig/RAServerConfigBinding2.cpp " componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001B2003A616A00720887FB" msg="Successfully loaded plugin: org.eclipse.hyades.logging.parsers" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001B37161FF74ED50C241B9" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.linux" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001B602262ACD6857A6813C" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.jmxagent" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001B7561506924B555C3AEE" msg="Successfully loaded plugin: org.eclipse.hyades.datacollection" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001B9DA63EAFE3966E7466E" msg="Successfully loaded plugin: org.eclipse.hyades.test" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001BA1D3D685E8E5BED8896" msg="Active configuration set to: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001BB484C1998042EC75F96" msg="Loaded configuration: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001BB7D1A1115D83D32F672" msg="Service started successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:26:21.000000Z" globalInstanceId="k21B6B3D0001E3330D3457D522129762" msg="Server stopping" severity="30" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15944" subComponent="framework/RAServer/RACommS.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:50.000000Z" globalInstanceId="k21B6BD2000C63362E60BE3B0E095251" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15975" subComponent="framework/RAServerConfig/RAServerConfigBinding2.cpp " componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD30005C9E03DC3A7477AF44F62" msg="Successfully loaded plugin: org.eclipse.hyades.logging.parsers" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD30005D70615A56F7853370D5F" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.linux" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD30005E3911D84485E577F4BD6" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.jmxagent" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD30005E8DF7B7A226C1B974D2C" msg="Successfully loaded plugin: org.eclipse.hyades.datacollection" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD30005F7303EA17C65693D9B9C" msg="Successfully loaded plugin: org.eclipse.hyades.test" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD300060214450F45693FAC59C5" msg="Active configuration set to: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD3000604350D72AC321B04C4BA" msg="Loaded configuration: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD3000605EB4EB7EC7B46B24743" msg="Service started successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:28:51.000000Z" globalInstanceId="k21B6BD3000EF05D6802496B2CF3C082" msg="Server stopping" severity="30" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15975" subComponent="framework/RAServer/RACommS.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB000896C367FB83560BB2FCCE" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15984" subComponent="framework/RAServerConfig/RAServerConfigBinding2.cpp " componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008B6836583A43F557615AE" msg="Successfully loaded plugin: org.eclipse.hyades.logging.parsers" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008BA6E0D2C4A1127957596" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.linux" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008BF6F69C6EA8B73A5F0C7" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.jmxagent" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008C3412CDED9F7085BF160" msg="Successfully loaded plugin: org.eclipse.hyades.datacollection" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008C86F5E3EF6E22E08E05A" msg="Successfully loaded plugin: org.eclipse.hyades.test" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008C9CC2D4C171921B1FE89" msg="Active configuration set to: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008CBC12B63D2270E4768DE" msg="Loaded configuration: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0008CCD6231C426214ED5F1C" msg="Service started successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-02-22T17:29:31.000000Z" globalInstanceId="k21B6BFB0009123E2D5AF461100B5954" msg="Server stopping" severity="30" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="15984" subComponent="framework/RAServer/RACommS.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
name="hyades.trace"
filename="hyades.trace"
lstat64("org.eclipse.hyades.test", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
open(" /home/development/rac/plugins/org.eclipse.hyades.test/config /pluginconfig.xml ", O_RDONLY) = 5
fstat64(5, {st_mode=S_IFREG|0755, st_size=1944, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x605000
read(5, "<?xml version=\"1.0\" encoding=\"UT"..., 49152) = 1944
read(5, "", 45056) = 0
read(5, "", 49152) = 0
close(5) = 0
munmap(0x605000, 4096) = 0
gettimeofday({1109093371, 575599}, {480, 0}) = 0
time(NULL) = 1109093371
stat64("/etc/localtime", {st_mode=S_IFREG|0644, st_size=1017, ...}) = 0
write(3, "<CommonBaseEvent creationTime=\"2"..., 667) = 667
getdents64(4, /* 0 entries */, 4096) = 0
close(4) = 0
gettimeofday({1109093371, 575948}, {480, 0}) = 0
write(3, "<CommonBaseEvent creationTime=\"2"..., 652) = 652
gettimeofday({1109093371, 576449}, {480, 0}) = 0
write(3, "<CommonBaseEvent creationTime=\"2"..., 645) = 645
gettimeofday({1109093371, 576726}, {480, 0}) = 0
write(3, "<CommonBaseEvent creationTime=\"2"..., 644) = 644
mmap2(NULL, 10489856, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xff1000
mprotect(0xff1000, 4096, PROT_NONE) = 0
clone(Process 15985 attached
child_stack=0x19f14c8, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THRE AD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHIL D_CLEARTID|CLONE_DETACHED, parent_tidptr=0x19f1bf8, {entry_number:6, base_addr:0x19f1bb0, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}, child_tidptr=0x19f1bf8) = 15985
[pid 15984] futex(0x6ec060, FUTEX_WAKE, 2147483647) = 0
[pid 15984] open("/usr/java/j2sdk1.4.2_07/jre/lib/i386/server/libjvm.so ", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0@\257\25"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=7693006, ...}) = 0
[pid 15984] old_mmap(NULL, 6424548, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0x3d55000
[pid 15984] old_mmap(0x4309000, 368640, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x5b3000) = 0x4309000
[pid 15984] old_mmap(0x4363000, 75748, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x4363000
[pid 15984] close(4) = 0
[pid 15984] open("/home/development/rac/lib/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/client/libnsl.so.1 ", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/server/libnsl.so.1 ", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("tls/i686/sse2/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("tls/i686/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("tls/sse2/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("tls/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("i686/sse2/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("i686/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("sse2/libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("libnsl.so.1", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/etc/ld.so.cache", O_RDONLY) = 4
[pid 15984] fstat64(4, {st_mode=S_IFREG|0644, st_size=77720, ...}) = 0
[pid 15984] old_mmap(NULL, 77720, PROT_READ, MAP_PRIVATE, 4, 0) = 0xa09000
[pid 15984] open("/lib/libnsl.so.1", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\264"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=97736, ...}) = 0
[pid 15984] old_mmap(0x7e78000, 88064, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0x7e78000
[pid 15984] old_mmap(0x7e8a000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x11000) = 0x7e8a000
[pid 15984] old_mmap(0x7e8c000, 6144, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7e8c000
[pid 15984] mprotect(0x7e8a000, 4096, PROT_READ) = 0
[pid 15984] munmap(0xa09000, 77720) = 0
[pid 15984] open("/etc/mtab", O_RDONLY) = 4
[pid 15984] fstat64(4, {st_mode=S_IFREG|0644, st_size=558, ...}) = 0
[pid 15984] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xcf6000
[pid 15984] read(4, "/dev/mapper/VolGroup00-LogVol00 "..., 4096) = 558
[pid 15984] munmap(0xcf6000, 4096) = 0
[pid 15984] open("/proc/stat", O_RDONLY) = 4
[pid 15984] fstat64(4, {st_mode=S_IFREG|0444, st_size=0, ...}) = 0
[pid 15984] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x605000
[pid 15984] read(4, "cpu 804919 70648 186442 5205624"..., 1024) = 264
[pid 15984] read(4, "", 1024) = 0
[pid 15984] munmap(0x605000, 4096) = 0
[pid 15984] open("/proc/meminfo", O_RDONLY) = 4
[pid 15984] read(4, "MemTotal: 1555320 kB\nMemFre"..., 1024) = 670
[pid 15984] gettimeofday({1109093371, 583613}, NULL) = 0
[pid 15984] lstat64("/usr", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre/lib", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre/lib/i386", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre/lib/i386/server", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre/lib/i386/server/libjvm.so ", {st_mode=S_IFREG|0755, st_size=7693006, ...}) = 0
[pid 15984] open(".hotspotrc", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/usr/java/j2sdk1.4.2_07/jre/lib/endorsed", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY) = -1 ENOENT (No such file or directory)
[pid 15984] rt_sigaction(SIGSEGV, NULL, {0x804d0f0, [SEGV], SA_RESTORER|SA_RESTART, 0x813a48}, 8) = 0
[pid 15984] rt_sigaction(SIGSEGV, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_STACK|SA_RESTART|SA_SIGINFO, 0x7e58d0}, {0x804d0f0, [SEGV], SA_RESTORER|SA_RESTART, 0x813a48}, 8) = 0
[pid 15984] rt_sigaction(SIGPIPE, NULL, {SIG_IGN}, 8) = 0
[pid 15984] rt_sigaction(SIGPIPE, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7e58d0}, {SIG_IGN}, 8) = 0
[pid 15984] rt_sigaction(SIGCHLD, NULL, {0x804d134, [], SA_RESTORER, 0x7e58d8}, 8) = 0
[pid 15984] rt_sigaction(SIGCHLD, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_RESTART|SA_SIGINFO|SA_NOCLDSTOP, 0x7e58d0}, {0x804d134, [], SA_RESTORER, 0x7e58d8}, 8) = 0
[pid 15984] rt_sigaction(SIGBUS, NULL, {SIG_DFL}, 8) = 0
[pid 15984] rt_sigaction(SIGBUS, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7e58d0}, {SIG_DFL}, 8) = 0
[pid 15984] rt_sigaction(SIGILL, NULL, {SIG_DFL}, 8) = 0
[pid 15984] rt_sigaction(SIGILL, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7e58d0}, {SIG_DFL}, 8) = 0
[pid 15984] rt_sigaction(SIGFPE, NULL, {SIG_DFL}, 8) = 0
[pid 15984] rt_sigaction(SIGFPE, {0x410a928, ~[RTMIN RT_1], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7e58d0}, {SIG_DFL}, 8) = 0
[pid 15984] old_getrlimit(RLIMIT_STACK, {rlim_cur=10240*1024, rlim_max=2147483647}) = 0
[pid 15984] open("/proc/self/stat", O_RDONLY) = 4
[pid 15984] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x9c7000
[pid 15984] read(4, "15984 (RAServer) R 1 15983 15983"..., 1024) = 188
[pid 15984] munmap(0x9c7000, 4096) = 0
[pid 15984] open("/proc/sys/vm/heap-stack-gap", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] rt_sigprocmask(SIG_BLOCK, NULL, [], 8) = 0
[pid 15984] rt_sigaction(SIGUSR2, {0x41091ec, [], SA_RESTORER|SA_RESTART|SA_SIGINFO, 0x7e58d0}, NULL, 8) = 0
[pid 15984] old_getrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=1024}) = 0
[pid 15984] setrlimit(RLIMIT_NOFILE, {rlim_cur=1024, rlim_max=1024}) = 0
[pid 15984] open(" /usr/java/j2sdk1.4.2_07/jre/lib/i386/native_threads/libhpi.s o ", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\220+\0"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=33188, ...}) = 0
[pid 15984] old_mmap(NULL, 35584, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0x769000
[pid 15984] old_mmap(0x771000, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x7000) = 0x771000
[pid 15984] geteuid32() = 500
[pid 15984] socket(PF_FILE, SOCK_STREAM, 0) = 4
[pid 15984] fcntl64(4, F_GETFL) = 0x2 (flags O_RDWR)
[pid 15984] fcntl64(4, F_SETFL, O_RDWR|O_NONBLOCK) = 0
[pid 15984] connect(4, {sa_family=AF_FILE, path="/var/run/nscd/socket"}, 110) = -1 ENOENT (No such file or directory)
[pid 15984] open("/etc/passwd", O_RDONLY) = 4
[pid 15984] fcntl64(4, F_GETFD) = 0
[pid 15984] fcntl64(4, F_SETFD, FD_CLOEXEC) = 0
[pid 15984] fstat64(4, {st_mode=S_IFREG|0644, st_size=1750, ...}) = 0
[pid 15984] mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xe71000
[pid 15984] read(4, "root:x:0:0:root:/root:/bin/bash\n"..., 4096) = 1750
[pid 15984] munmap(0xe71000, 4096) = 0
[pid 15984] open("/tmp/hsperfdata_bikehead", O_RDONLY|O_NONBLOCK|O_LARGEFILE|O_DIRECTORY) = 4
[pid 15984] fstat64(4, {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] lstat64("/tmp/hsperfdata_bikehead", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
[pid 15984] getdents64(4, /* 3 entries */, 4096) = 80
[pid 15984] kill(15975, SIG_0) = -1 ESRCH (No such process)
[pid 15984] unlink("/tmp/hsperfdata_bikehead/15975") = 0
[pid 15984] getdents64(4, /* 0 entries */, 4096) = 0
[pid 15984] mkdir("/tmp/hsperfdata_bikehead", 0755) = -1 EEXIST (File exists)
[pid 15984] open("/tmp/hsperfdata_bikehead/15984", O_RDWR|O_CREAT|O_TRUNC, 0600) = 4
[pid 15984] ftruncate(4, 16384) = 0
[pid 15984] mmap2(NULL, 16384, PROT_READ|PROT_WRITE, MAP_SHARED, 4, 0) = 0x605000
[pid 15984] mmap2(0xbfe0e000, 12288, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xbfe0e000
[pid 15984] mprotect(0xbfe0e000, 12288, PROT_NONE) = 0
[pid 15984] mmap2(0xbfe04000, 40960, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xbfe04000
[pid 15984] sigaltstack({ss_sp=0xbfe04000, ss_flags=0, ss_size=40960}, NULL) = 0
[pid 15984] rt_sigaction(SIGHUP, NULL, {SIG_IGN}, 8) = 0
[pid 15984] rt_sigaction(SIGINT, NULL, {0x804d0f0, [INT], SA_RESTORER|SA_RESTART, 0x813a48}, 8) = 0
[pid 15984] rt_sigaction(SIGTERM, NULL, {0x804d0f0, [TERM], SA_RESTORER|SA_RESTART, 0x813a48}, 8) = 0
[pid 15984] rt_sigprocmask(SIG_UNBLOCK, [INT QUIT USR2 TERM CHLD], NULL, 8) = 0
[pid 15984] gettimeofday({1109093371, 588826}, NULL) = 0
[pid 15984] gettimeofday({1109093371, 588869}, NULL) = 0
[pid 15984] gettimeofday({1109093371, 588904}, NULL) = 0
[pid 15984] gettimeofday({1109093371, 588940}, NULL) = 0
[pid 15984] gettimeofday({1109093371, 588975}, NULL) = 0
[pid 15984] open("/usr/java/j2sdk1.4.2_07/jre/lib/i386/libverify.so", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\260\37"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=70980, ...}) = 0
[pid 15984] old_mmap(NULL, 73396, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0xd26000
[pid 15984] old_mmap(0xd36000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0xf000) = 0xd36000
[pid 15984] open("/home/development/rac/lib/libjvm.so", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/libjvm.so", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/client/libjvm.so", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0`\332\t"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=5192831, ...}) = 0
[pid 15984] old_mmap(NULL, 4371592, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0x355d000
[pid 15984] old_mmap(0x395b000, 114688, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x3fd000) = 0x395b000
[pid 15984] old_mmap(0x3977000, 70792, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x3977000
[pid 15984] open("/usr/java/j2sdk1.4.2_07/jre/lib/i386/libjava.so", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\200\200"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=142076, ...}) = 0
[pid 15984] old_mmap(NULL, 137668, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0x623000
[pid 15984] old_mmap(0x643000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x1f000) = 0x643000
[pid 15984] open("/home/development/rac/lib/libverify.so", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/libverify.so", O_RDONLY) = 4
[pid 15984] open("/usr/java/j2sdk1.4.2_07/jre/lib/i386/libzip.so", O_RDONLY) = 4
[pid 15984] read(4, "\177ELF\1\1\1\0\0\0\0\0\0\0\0\0\3\0\3\0\1\0\0\0\320\35"..., 512) = 512
[pid 15984] fstat64(4, {st_mode=S_IFREG|0755, st_size=90008, ...}) = 0
[pid 15984] old_mmap(NULL, 91488, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 4, 0) = 0xe45000
[pid 15984] old_mmap(0xe59000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 4, 0x13000) = 0xe59000
[pid 15984] open("/home/development/rac/lib/libjava.so", O_RDONLY) = -1 ENOENT (No such file or directory)
[pid 15984] open("/home/development/java/jre/lib/i386/libjava.so", O_RDONLY) = 4
[pid 15984] stat64("/usr/java/j2sdk1.4.2_07/jre/lib/rt.jar", {st_mode=S_IFREG|0644, st_size=26905782, ...}) = 0
[pid 15984] lstat64("/usr/java/j2sdk1.4.2_07/jre/lib/rt.jar", {st_mode=S_IFREG|0644, st_size=26905782, ...}) = 0
[pid 15984] --- SIGSEGV (Segmentation fault) @ 0 (0) ---
[pid 15984] rt_sigprocmask(SIG_SETMASK, [SEGV], ~[KILL STOP RTMIN RT_1], 8) = 0
[pid 15984] gettimeofday({1109093371, 594494}, {480, 0}) = 0
[pid 15984] time(NULL) = 1109093371
[pid 15984] stat64("/etc/localtime", {st_mode=S_IFREG|0644, st_size=1017, ...}) = 0
[pid 15984] write(3, "<CommonBaseEvent creationTime=\"2"..., 608) = 608
Process 15984 detached
[pid 15985] +++ killed by SIGSEGV +++
PANIC: handle_group_exit: 15985 leader 15984
--------------060701020600040301020602--
Re: Getting started with hyades... [message #7122 is a reply to message #6991] |
Wed, 23 February 2005 10:21   |
Can you crank up the logging level for the log? You can do this by modifying
the "config/serviceconfig.xml" file. Look for the line:
<AgentControllerConfiguration activeConfiguration="default" filePort="10005"
jvm="D:\jdk1.4.1\jre\bin\classic\jvm.dll" loggingDetail="LOW"
loggingLevel="DEBUG" port="10002" processPolling="true" securedPort="10003"
version="3.2.0">
and change the value of the "loggingLevel" attribute to "DEBUG". Remove the
old log and restart RAServer to generate a detailed log. Please post the log
here. Thanks.
BTW, what is the value of the attribute "jvm" in your config file?
Samson
news:cvfqsa$653$1@www.eclipse.org...
> Samson Wai wrote:
> > Hi Brian,
generate
config
> > files.
> and it looked good.
is
available
connection
output
> > of "netstat -a".
> > Samson
product.
> -Brian
> >>Thanks,
> >>Brian
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
processId="15944"
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
processId="15975"
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
processId="15984"
> </situation>
> </CommonBaseEvent>
> </situation>
> </CommonBaseEvent>
....}) = 0
fig.xml", O_RDONLY) = 5
= 0x605000
> close(5) = 0
> close(4) = 0
|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID|CLONE _DETACHED,
O_RDONLY) = 4
> [pid 15984] read(4,
file or directory)
file or directory)
directory)
file or directory)
or directory)
or directory)
directory)
> [pid 15984] read(4,
....}) = 0
> [pid 15984]
directory)
directory)
0x7e58d8}, 8) = 0
0
> [pid 15984]
O_RDONLY) = 4
> [pid 15984] read(4,
exists)
0600) = 4
0x605000
NULL) = 0
8) = 0
O_RDONLY) = 4
> [pid 15984] read(4,
O_RDONLY) = 4
> [pid 15984] read(4,
O_RDONLY) = 4
> [pid 15984] read(4,
O_RDONLY) = 4
> [pid 15984] read(4,
O_RDONLY) = 4
> [pid 15984] read(4,
O_RDONLY) = 4
> [pid 15984] read(4,
....}) = 0
8) = 0
....}) = 0
Re: Getting started with hyades... [message #8225 is a reply to message #8194] |
Thu, 03 March 2005 18:59  |
Originally posted by: bike_head.hotmail.com
Hmm, I see. My mistake was that I noticed two libjvm.so in the java SDK
from sun, so I put both on the path. The client variant is the first on
the LD_LIBRARY_PATH so it gets picked up first. I should change the
LD_LIBRARY_PATH to only have one of them and the config entry should match.
Samson Wai wrote:
> There is no requirement on which libjvm.so (client or server) to use. But
> the important point is that whatever is specified in the serviceconfig.xml
> should match the environment variable LD_LIBRARY_PATH. For example, if the
> config file is pointing to the "client" libjvm.so, then the LD_LIBRARY_PATH
> env should point to the "/usr/java/j2sdk1.4.2_07/jre/lib/i386/client" path.
> This is because RAServer will try to do a dlopen() on the libjvm.so
> specified in the config file using the FQ path name. If the LD_LIBRARY_PATH
> is pointing to another libjvm.so, we will get a dlsym() error when trying to
> resolve symbols in the library and crash.
> Samson
> news:cvl91k$45q$1@www.eclipse.org...
>>Well, I noticed that there are two versions of libjvm.so in 1.4.2_07. I
>>changed the jvm entry to
>>'/usr/java/j2sdk1.4.2_07/jre/lib/i386/client/libjvm.so' and it started
>>working! I'm unclear as to the difference between the client and server
>>java versions.
>>Brian Anderson wrote:
>>>Ok,
>>>the jvm entry in that element is
>>>jvm=/usr/java/j2sdk1.4.2_07/jre/lib/i386/server/libjvm.so. I assume
>>>that the setup script set this since I didn't.
>>>I changed the log level and reran RAServer. The resulting log is
>>>attached. Seems to be having problems just after loading libjvm.so and
>>>resolving JNI_CreateJavaVM.
>>>I'm using Sun's most recent 1.4.2_7 rpm from their web site.
>>>Samson Wai wrote:
>>>>Hi,
>>>>modifying
>>>>filePort="10005"
>>>>securedPort="10003"
>>>>version="3.2.0">
>>>>Remove the
>>>>the log
>>>>here. Thanks.
>>>>Samson
Current Time: Tue Jul 22 01:51:02 EDT 2025
Powered by FUDForum. Page generated in 0.05853 seconds
