Home » Archived » BIRT » Start swt Shell widget from script
Start swt Shell widget from script [message #76720] Fri, 23 September 2005 08:47
Hi;
I’m trying to start shell window using the following code in mine script:
new Packages.nl.remain.mx.db.dynamicFields.DynamicFields();
But I get the following error :
no swt-win32-3063 in java.library.path
Is there any idea how to set the library path in BIRT ?
Said;
Previous Topic:question on howto change the row background based on table data
Next Topic:ReportEngine.destroy doesn't clear all links
Current Time: Fri Jul 18 02:07:20 EDT 2025
Powered by FUDForum. Page generated in 0.03349 seconds
