Home » Archived » Visual Editor (VE) » How to add JMenuItem to JMenu?
How to add JMenuItem to JMenu? [message #76613] Thu, 13 January 2005 04:59 Go to next message
Originally posted by: eclipse.knowthem.de
First i make a visual class (Jframe) with JPanel in it. Then I make a
JMenuBar and put JMenu's in it. But if I try to put JMenuItem's in the
JMenu's the cursor shows a 'x' -> don't work. I only can put Items in the
JPanel, but the Item is not connect withe the Menu. How can I make this
with Drag'n'Drop?
Thanks! Sorry for the bad english ;)
Re: How to add JMenuItem to JMenu? [message #76629 is a reply to message #76613] Thu, 13 January 2005 05:06 Go to previous messageGo to next message
Try using the Java Beans view. You should be able to click on a
JMenuItem and drop it on the JMenu there.
@D
> the JPanel, but the Item is not connect withe the Menu. How can I make
> this with Drag'n'Drop?
Re: How to add JMenuItem to JMenu? [message #76644 is a reply to message #76629] Thu, 13 January 2005 05:40 Go to previous message
Thanks!
> @D
Re: How to add JMenuItem to JMenu? [message #604378 is a reply to message #76613] Thu, 13 January 2005 05:06 Go to previous message
@D
Re: How to add JMenuItem to JMenu? [message #604382 is a reply to message #76629] Thu, 13 January 2005 05:40 Go to previous message
Thanks!
> @D
Previous Topic:How to add JMenuItem to JMenu?
Next Topic:Extending ve palette
Current Time: Sat Jul 26 12:35:40 EDT 2025
Powered by FUDForum. Page generated in 0.04505 seconds
