Home » Eclipse Projects » GEF » unconnected connections
unconnected connections [message #76581] |
Thu, 24 April 2003 15:54  |
Originally posted by: amititz.yahoo.com
I would like to find a reasonable way to make a connection not connected to
anything. that is, for example, when I delete a node, I want the connections
that were connected to it to stay where they are (and not jump to the
screen's corner). I want to be able to move the loose endpoint around, and
then connect it to a new node
(for example, in visio, you can drop a connection on the page, and only then
connect it to some other shape if you wish). Is there any way to accomplish
that ?
I tried putting an anchor on the location of the request, and set the
connection's anchor to this new anchor. it doesn't work, and seems like a
pretty bad idea.
Amit
Re: unconnected connections [message #76598 is a reply to message #76581] |
Thu, 24 April 2003 15:01   |
Don't use AbstractConnectionEditPart for this. Use just a regular
GraphicalEditPart whose figure happens to be a connection.
"Amit" <amititz@yahoo.com> wrote in message
news:b89bu4$iqf$1@rogue.oti.com...
to
connections
then
accomplish
> that ?
> pretty bad idea.
> Amit
Re: unconnected connections [message #76715 is a reply to message #76598] |
Fri, 25 April 2003 11:38   |
Originally posted by: Vadim.Strizhevsky.nowhere.com
I need to do the same thing, but this suggestion seems strange to me.
Would I have to change the connection's edit part when it gets
disconnected and then change it again if it gets connected? Or did you
mean to always have the connection's edit part be a standard
GraphicalEditPart? Would all the connection's logic still work?
I was thinking instead, creating a dummy/error edit part that
"disconnected" connections would connect to. You can display it as X or
even be almost invisble. have it placed anywhere on the graph. These parts
can be constructed/destructed automatically as needed for connections.
I haven't tried this yet. Would such an approach make sense?
Vadim
> > Hi,
> to
> connections
> then
> accomplish
> > that ?
> > pretty bad idea.
> > Thanks,
> > Amit
Re: unconnected connections [message #76746 is a reply to message #76715] |
Fri, 25 April 2003 14:09   |
I forgot to think about the connecting parts. Basically, it's hard to
guarantee that the "connection" is created after the nodes at either end.
Therefore, at startup, the connection might create its figure first (before
the nodes exist), and then try to find its "source" or "target"
connectionanchors, and fail. The solution is to do a double check. The
connection tries to find the source, but can't. Then, when the source is
created, it tries to find its connection. If it does, it says "ok, now you
can set your connection anchor". This is what the viewer's part registry is
for.
Keep in mind I'm using the terms connection, source, and target loosely
here. If this type of thing gets added to GEF, it would be referred to as
an association probably.
"Vadim Strizhevsky" <Vadim.Strizhevsky@nowhere.com> wrote in message
news:b8bkqc$82q$1@rogue.oti.com...
> Vadim
> > > Hi,
connected
> > to
> > connections
and
only
> > then
> > accomplish
> > > that ?
like a
> > > pretty bad idea.
> > > Thanks,
> > > Amit
Re: unconnected connections [message #76926 is a reply to message #76746] |
Sat, 26 April 2003 17:07   |
Originally posted by: vadim.nowhere.com
Sorry, but don't quite get what you mean. Was this for my suggestion or
Amit's? And how does
this apply? I was thinking that the model would know this and will cause
the root part generate
"dummy" models for nodes to which "disconnected" connections get
connected. Does that make
sense would this be a bad aproach?
Vadim
> for.
> > Thanks,
> > Vadim
> > > > Hi,
> connected
> > > to
> > > connections
> and
> only
> > > then
> > > accomplish
> > > > that ?
> like a
> > > > pretty bad idea.
> > > > Thanks,
> > > > Amit
Re: unconnected connections [message #76942 is a reply to message #76926] |
Sat, 26 April 2003 20:27   |
This was for your suggestion. I think your technique would work too, but
it's forcing something to be a connection when it isn't. Do you want the
z-order of these "connections" to be mixed with the z-order of other
objects? In visio, if I drop a shape, it will cover up a connection
previously dropped.
"Vadim Strizhevsky" <vadim@nowhere.com> wrote in message
news:b8eseo$6g3$1@rogue.oti.com...
> Vadim
end.
(before
is
you
registry is
> > for.
as
or
parts
> > > Thanks,
> > > Vadim
> > > > > Hi,
> > connected
> > > > to
> > > > connections
the
around,
> > and
> > only
> > > > then
> > > > accomplish
> > > > > that ?
the
> > like a
> > > > > pretty bad idea.
> > > > > Thanks,
> > > > > Amit
Re: unconnected connections [message #77055 is a reply to message #76942] |
Mon, 28 April 2003 09:49  |
Perhaps "connection" is in the eye of the beholder? ;)
The reason why I want this to be a real connection is that I want users to
be able to pick the bad end of it and re-connect it to an existing node. I
don't see how you can do that without it being a real connection part with
all connection policies.
On the general level, which is what Amit asked in the first place, the
question is how to best allow display of connections with one or two
endpoints not connected, while still allowing those endpoints to be
reconnected. It be nice if GEF had some provision for this.
-Vadim
> previously dropped.
> > Thanks,
> > Vadim
> end.
> (before
> is
> you
> registry is
> > > for.
> as
> or
> parts
> > > > Thanks,
> > > > Vadim
> > > > > > Hi,
> > > connected
> > > > > to
> > > > > connections
> the
> around,
> > > and
> > > only
> > > > > then
> > > > > accomplish
> > > > > > that ?
> the
> > > like a
> > > > > > pretty bad idea.
> > > > > > Thanks,
> > > > > > Amit
Current Time: Tue Jul 22 08:58:06 EDT 2025
Powered by FUDForum. Page generated in 0.13757 seconds
