MenuBar backgroud [message #76564] |
Tue, 04 March 2008 22:29  |
Originally posted by: dnise.hotmail.com
HI All:
can I implement to set background Color for MenuBar or StatusBar in RAP?
could anyone give me some ideas?
allen
Re: MenuBar backgroud [message #76868 is a reply to message #76821] |
Thu, 06 March 2008 02:04  |
Originally posted by: fappel.innoopract.com
the answer was already given by Ralf:
> There is no Menu#setBackground method in RAP because this method does
> not exist in SWT either and RAP implements a strict subset of SWT. I
> guess the reason that this method does not exist in SWT is that on the
> desktop, the menu colors are under operating system / window manager
control.
And as menus belong to the trimming part of a shell, I guess Ralf is
right about that.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: dnise [mailto:dnise@hotmail.com]
Bereitgestellt: Donnerstag, 6. März 2008 04:46
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: MenuBar backgroud
Betreff: Re: MenuBar backgroud
Ralf Sternberg wrote:
> dnise wrote:
>> HI All:
RAP?
control.
> That's were the RAP theming comes in: You can register a property file
> like the following with the extension point org.eclipse.rap.ui.themes
> to set the menu colors for your application:
> menu.foreground: black
> menu.hover.foreground: white
> menu.background: #ffff23
> menu.hover.background: #0000ff
> For more information on RAP Theming, refer to the RAP Help, also
> available at
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. rap.help/hel
p/html/advanced/theming.html
> Best,
> Ralf
Hi:
Thanks for you ideas.I can change the back-ground color for menu using
theme properties file.But Theme properties file is used for the whole
application(as for the whole system's button, text ect.),we can't change
the color displayed for menu after the application started, so it's
not flexibility. I can change the Coolbar's back-ground color using
code.
why menu not? does anyone give me some advice?
thanks & regards
FUDForum. Page generated in 0.07139 seconds
