Re: [buckminster-dev] Error Resolving Buckminster [message #6886] |
Tue, 26 February 2008 16:24 |
Apparently I'm a victim of gremlins. Tried the same thing today and worked
fine...
Did the dev-cquery/dogfood2.rmap change?
Either way, don't worry about it - works now.
Todd
AMI Semiconductor - "Silicon Solutions for the Real World"
NOTICE:
This electronic message contains information that may be confidential or privileged. The information is intended for the use of the individual or entity named above. If you are not the intended recipient, please be aware that any disclosure, copying, distribution or use of the contents of this information is prohibited. If you received this electronic message in error, please notify the sender and delete the copy you received.
FUDForum. Page generated in 0.45981 seconds
