Home » Archived » BIRT » Is there any way to remove table columns at runtime?
Is there any way to remove table columns at runtime? [message #76497] Thu, 22 September 2005 11:30
I was hoping that there would be a visibility attribute for table columns.
It does not look like there is. In certain cases i need to remove certain
columns depending on input parameters. I could probably transform the
..rptdesign file to remove the columns, but i was wondering if anyone had any
other suggestions? Can it be done from scripting in the report? Can
someone point me to the correct API to inspect and edit a table?
Thanks.
Previous Topic:How do you use BIRT Scripting?
Next Topic:beforeOpen on a datasource, scripting, and passing in parameters
Current Time: Tue Jul 22 02:36:05 EDT 2025
Powered by FUDForum. Page generated in 0.03472 seconds
