Home » Language IDEs » C / C++ IDE (CDT) » how to get Eclipse to run 'make'
how to get Eclipse to run 'make' [message #76493] Tue, 22 July 2003 13:49 Go to next message
Originally posted by: eipe.NOSPAMuiuc.edu
I installed MinGW(http://www.mingw.org) on my machine, but when I try to
get Eclipse to run 'make', make fails.
Console output:
gcc -c hello.c
process begin: CreateProcess((null), gcc -c hello.c, ...) failed.
make (e=2): The system cannot find the file specified.
C:\mingw\bin\mingw32-make.exe: *** [hello.o] Error 2
The last line above is also the location of the make executable, in the
build path of the Properties page of the project.
Its just a simple project, with a hello.c file, and a makefile:
hello : hello.o
gcc -o hello hello.o
hello.o : hello.c
gcc -c hello.c
I know this is kind of a basic question, but any help is appreciated,
thanks.
Rohit Eipe
Re: how to get Eclipse to run 'make' [message #76683 is a reply to message #76493] Wed, 23 July 2003 21:25 Go to previous messageGo to next message
Originally posted by: alain.nowhere.ca
Rohit Eipe wrote:
> Hi
> Console output:
> gcc -c hello.c
> C:mingwbinmingw32-make.exe: *** [hello.o] Error 2
> hello : hello.o
> hello.o : hello.c
> gcc -c hello.c
> thanks.
Actually looking at this it seems you mingw32-make did not fine
"gcc", You will have to also set you path or instead of just doing
"gcc" put the exact path:
hello : hello.o
C:\mingw\bin\gcc -o hello hello.o
hello.o : hello.c
C:\mingw\bin\gcc -c hello.c
Or something similar
> Rohit Eipe
Re: how to get Eclipse to run 'make' [message #76947 is a reply to message #76683] Thu, 24 July 2003 14:40 Go to previous messageGo to next message
alain wrote:
> Rohit Eipe wrote:
> > Hi
> > Console output:
> > gcc -c hello.c
> > hello : hello.o
> > hello.o : hello.c
> > gcc -c hello.c
> > thanks.
> hello : hello.o
> C:mingwbingcc -o hello hello.o
> hello.o : hello.c
> C:mingwbingcc -c hello.c
> > Rohit Eipe
That was it .. thanks.
Rohit Eipe
Re: how to get Eclipse to run 'make' [message #79858 is a reply to message #76683] Sat, 06 September 2003 13:31 Go to previous messageGo to next message
Originally posted by: sdratva.gmx.net
alain wrote:
> Rohit Eipe wrote:
> > Hi
> > Console output:
> > gcc -c hello.c
> > hello : hello.o
> > hello.o : hello.c
> > gcc -c hello.c
> > thanks.
> hello : hello.o
> hello.o : hello.c
> > Rohit Eipe
I've got the same problem, and solved it the same way, but g++ was in my
path variable and if I started make (mingw32-make -f makefile) from
DOS-Window, it worked correct. As I renamed g++.exe in gpp.exe, it began
to work also in eclipse correct...
Alex
Re: how to get Eclipse to run 'make' [message #94482 is a reply to message #76683] Tue, 17 February 2004 13:11 Go to previous messageGo to next message
Originally posted by: lazareer.nospam.retsat1.net
I have similar problem:
Error make * CreateProcess((null), rm -rf src/ProbnaKlasa.o main.o
proba.exe, ...) failed. The system cannot find the file specified. proba
line 0
console output:
make clean all
process_begin: CreateProcess((null), rm -rf src/ProbnaKlasa.o main.o
make: [clean] Error 2 (ignored)
rm -rf src/ProbnaKlasa.o main.o proba.exe
make: Nothing to be done for `all'.
Build complete for project proba
I was trying to change rm to del but when I rebuild the project del is
automatically changed into rm again. I have installed CygWin to provide rm
command for eclipse but it seems that it cannot see it. I have done that rm
command from command line and it works, but Eclipse is blind for it :(
Any suggestions? Thanks for help...
lazareer
"Połowa tego co się mówi o sztucznej inteligencji nie jest prawdą,
druga połowa - nie jest możliwa"
D. Partrige
Re: how to get Eclipse to run 'make' [message #94570 is a reply to message #94482] Tue, 17 February 2004 19:22 Go to previous messageGo to next message
Originally posted by: ddaoust.ca.ibm.com
This error is comming from the make executable. It is saying that it cannot
create a process running "rm".
You should get the same error message if you run make from the command line.
The solution is to ensure that "rm", "g++", and "make" are all on the path.
It probably makes sense to debug this outside of eclipse, by going to the
correct directory in a command shell and typing make.
- Dave
"lazareer" <lazareer@nospam.retsat1.net> wrote in message
news:Xns9492C3B76BFF9lazareerretsat1compl@127.0.0.1...
> line 0
> console output:
> make clean all
rm
> lazareer
> "Po
Re: how to get Eclipse to run 'make' [message #94585 is a reply to message #94570] Wed, 18 February 2004 01:25 Go to previous messageGo to next message
> cannot create a process running "rm".
> line. The solution is to ensure that "rm", "g++", and "make" are all
> on the path.
> the correct directory in a command shell and typing make.
As I have written in the previous post - everything works fine from the
shell command line, only Eclipse cannot work properly.
lazareer
D. Partrige
Re: how to get Eclipse to run 'make' [message #94599 is a reply to message #94585] Wed, 18 February 2004 08:57 Go to previous message
Well,
If you have installed Cygwin and are using the Cygwin bash shell, the
environment will obviously be correct. The question is whether those
commands are available from a Win32 shell. If you are certain that they
are, have you restarted Eclipse under the new environment? If it is an
old session (one that was running before you installed Cygwin), then it
will not have inheritted the proper environment.
>>on the path.
Previous Topic:Can't get to resource
Next Topic:Managed Make on C:/Documents and Settings/blah
Current Time: Tue Jul 15 23:47:09 EDT 2025
Powered by FUDForum. Page generated in 0.09036 seconds
