Home » Archived » Test and Performance Tools Platform (TPTP) » firefox and tptp
firefox and tptp [message #76370] Wed, 05 July 2006 11:20 Go to next message
Hello
I try URL recording with firefox. At first I had to remove the following
line from my prefs.js
user_pref("network.proxy.autoconfig_url", "http://myURL");
otherwise it throws the error that autoconfig is not supported.
My other proxy settings are correct.
When I try to start a test suite it starts firefox but then my cpu is up
to 100%.
I stop recording without entering an URL, it closes firefox and generates
a big rec file. The last TRConnection entry looks like following:
<TRCConnection type="OPEN" ticket="7001" connectionNumber="1747"
timestamp="8383">
<servername>
localhost</servername>
<port>1080</port>
<clientInetAddress>xx.xx.xx.xx</clientInetAddress>
<clientPort>4217</clientPort>
</TRCConnection>
I assume it tries to establish 1747 connection till I aborted the
recording.
I also can't laod an URL, firefox hangs during loading.
Where could be the mistake I have done???
Re: firefox and tptp [message #76523 is a reply to message #76370] Thu, 06 July 2006 10:48 Go to previous messageGo to next message
Hi Allon,
What version of TPTP and OS are you using? This is a tested scenario
and should work after changing the "Window >> Preferences >> Test >> HTTP
Recording >> Application to Record" preference.
Paul
"allon" <allon.moritz@gmail.com> wrote in message
news:4c31b97f97a5023e610ec9ec7d0739b0$1@www.eclipse.org...
> Hello
> to 100%.
> timestamp="8383">
> <servername>
> <port>1080</port>
> </TRCConnection>
> recording.
> Thanks
Re: firefox and tptp [message #76553 is a reply to message #76523] Thu, 06 July 2006 11:36 Go to previous messageGo to next message
i use the newest tptp version 4.2 with eclipse 3.2 (created from callisto).
the os is windows xp sp1
thanks allon
Re: firefox and tptp [message #81942 is a reply to message #76553] Tue, 29 August 2006 07:32 Go to previous message
Hi Allon,
My appologies for the late reply.
This scenario has been tested in the last test pass (TPTP V4.2.1). Can
you try the same recording session with the latest TPTP stable drvier
( http://www.eclipse.org/tptp/home/downloads/drops/TPTP-4.2.1- 200608041327.html)?
Paul
news:9a450d704e7c985ff0ca0a9df456fee2$1@www.eclipse.org...
> thanks allon
Previous Topic:Execution Time Analysis Fails Due To OutOfMemoryException
Next Topic:TPTP plugin dependencies
Current Time: Tue Jul 22 21:19:53 EDT 2025
Powered by FUDForum. Page generated in 0.06979 seconds
