Home » Eclipse Projects » GEF » painting Grid
painting Grid [message #76358] Wed, 23 April 2003 15:30 Go to next message
Originally posted by: junost.gmx.de
Hello
in my editor I want to draw a Grid (points) in background. So I modified
the paintFigure -method of FreeformLayer -class. But with small a grid
pattern it becomes very slow. The reason is that with every adding or moving
of a figure the whole area is repainted.
How can I solve this problem?
Alexander M
Re: painting Grid [message #76374 is a reply to message #76358] Wed, 23 April 2003 15:44 Go to previous messageGo to next message
When you add a figure, it gets added with its default bounds, which are (0,
0, 64, 36). Then, the figure is positioned by its constraint, causing an
erase at its original location. So, the damage region is the union of its
default location and its location after the layout occurs.
I don't see why drawing a grid should be slow. Please post the code you are
using to draw the grid.
"Alexander M
Re: painting Grid [message #76404 is a reply to message #76374] Wed, 23 April 2003 15:53 Go to previous messageGo to next message
Here is code to paint black dots on white background spaced every 3 pixels.
I can't imagine a grid any smaller.
I cannot detect any performance hit from displaying this grid.
protected void paintFigure(Graphics g) {
g.setForegroundColor(ColorConstants.white);
Rectangle region = new Rectangle();
g.getClip(region);
g.setBackgroundColor(ColorConstants.black);
g.fillRectangle(region);
g.setLineWidth(2);
for (int i=region.x - 2; i<region.right()+2; i++)
if (i % 3 == 0)
g.drawLine(i, region.y-2, i, region.bottom()+2);
for (int i=region.y-2; i<region.bottom()+2; i++)
if (i % 3 == 0)
g.drawLine(region.x-2, i, region.right()+2, i);
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b86por$mbe$1@rogue.oti.com...
(0,
are
> "Alexander M
Re: painting Grid [message #76436 is a reply to message #76374] Wed, 23 April 2003 16:00 Go to previous messageGo to next message
(0,
BTW, one way for us to fix this would be to have the default size of a
figure be (0,0). That way, when it calls erase(), nothing will happen
because the erase region will be an empty Rectangle.
Re: painting Grid [message #76467 is a reply to message #76436] Wed, 23 April 2003 17:21 Go to previous message
Thnk you very much, your code works very good.
My code was not very efficient. I draw points instead of lines.
Previous Topic:Feedback on connection anchors
Next Topic:Editing Element Properties
Current Time: Sun Jul 27 06:06:47 EDT 2025
Powered by FUDForum. Page generated in 0.05602 seconds
