Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo]Supported DB vendor/versions
[Teneo]Supported DB vendor/versions [message #76338] Thu, 22 March 2007 19:37 Go to next message
Is there an official set of database vendors/versions that Teneo attempts to
integrate with?
I know the list is huge so narrowing it down is certainly reasonable.
We have found problems with Teneo's integration with Hibernate/HSQL DB
(bugzilla number 178471) that don't show up on Hibernate/MySQL.
Do we file a bugzilla for this or should we stick to the db vendors/versions
that are tested?
-mike
Re: [Teneo]Supported DB vendor/versions [message #76354 is a reply to message #76338] Fri, 23 March 2007 02:04 Go to previous messageGo to next message
There is no official list and teneo is tested only on mysql and occasionally on ms sql server. I
would like to test on more databases but there is but so much time in a day available.
Note that Teneo does not add any database specific code and uses standard hibernate/jpox. So
therefore it is safe to say that Teneo should work for the same databases as supported by
hibernate/jpox. If a certain hibernate mapping is not working on a certain database (while it works
on mysql) then this is more a hibernate issue then a Teneo issue (imo).
However, having said this. In general if you encounter an issue with a specific database then I am
willing to spend time/adapt Teneo to check/solve it (provided I do not need to add db specific code).
So for your specific issue, if you would like hsqldb support for this then please analyse the cause
of the issue (what is the difference you see between hsqldb and mysql, which db constraint is
violated, etc.), and preferably a solution (which mapping works).
gr. Martin
> integrate with?
> that are tested?
> -mike
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo]Supported DB vendor/versions [message #78908 is a reply to message #76338] Mon, 09 April 2007 08:13 Go to previous message
Hi Martin,
Just so you know, bug 178471, which I referred to in the message below,
now works with HSQLDB as of Teneo v200703301226.
Thanks alot!
-mike
"Michael Kanaley" <mkanaley@tibco.com> wrote in message
news:etv3vo$m7g$1@utils.eclipse.org...
> to integrate with?
> vendors/versions that are tested?
> -mike
Re: [Teneo]Supported DB vendor/versions [message #603814 is a reply to message #76338] Fri, 23 March 2007 02:04 Go to previous message
gr. Martin
> integrate with?
> that are tested?
> -mike
The Netherlands
Re: [Teneo]Supported DB vendor/versions [message #604486 is a reply to message #76338] Mon, 09 April 2007 08:13 Go to previous message
Hi Martin,
Thanks alot!
-mike
> to integrate with?
> -mike
Previous Topic:[Teneo]Custom primary key column is not being defined correctly.
Next Topic:Jet 2.0?
Current Time: Sat Aug 30 23:04:36 EDT 2025
Powered by FUDForum. Page generated in 0.04125 seconds
