Home » Archived » BIRT » URI Expression for Image
URI Expression for Image [message #76337] Wed, 21 September 2005 17:45 Go to next message
I am having trouble getting an image from a URL in my reports. I see this
is a FAQ in the uncategorized section, but the answer doesn't spell it out
well enough for me I guess.
Can anyone give me an example of an actual expression that will work for
putting an image in a report from a URL? Whatever I put in there either
gives me a "failed to evaluate" error or just nothing shows up at all. This
is despite the fact that the preview window where I set the URI displays the
image, as does the template in Eclipse.
Thanks in advance,
Floor
Re: URI Expression for Image [message #76672 is a reply to message #76337] Thu, 22 September 2005 17:08 Go to previous messageGo to next message
Since the URI is an expression, not a String, I tried making a report
parameter called myCompanyLogo, giving it a default value of the URL to my
image, then setting the image URI to be params["myCompanyLogo"]. I thought
I had an expression that would've worked, but the image still doesn't show
up on the report.
--floor
"floor" <floorflux@hotmail.com> wrote in message
news:dgskcc$tl9$1@news.eclipse.org...
> This is despite the fact that the preview window where I set the URI
> displays the image, as does the template in Eclipse.
> Thanks in advance,
> Floor
Re: URI Expression for Image [message #76800 is a reply to message #76672] Fri, 23 September 2005 10:26 Go to previous messageGo to next message
floor,
Have you tried using a local file and then c\testdir\pic.jpg?
Jason Weathersby
BIRT PMC
news:dgv6jq$a06$1@news.eclipse.org...
> thought I had an expression that would've worked, but the image still
> doesn't show up on the report.
> --floor
>> Thanks in advance,
>> Floor
Re: URI Expression for Image [message #76929 is a reply to message #76800] Fri, 23 September 2005 15:30 Go to previous message
I cut my image out of the Simple Master Page Header and pasted it into the
Body page and it shows up fine now. It looks like, at least for me, images
in the Simple Master Page don't work but they do in the Body. If I paste it
back into the Master Page it doesn't show up again.
--floor
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:dh13b4$k74$1@news.eclipse.org...
> floor,
> Jason Weathersby
> BIRT PMC
>> my image, then setting the image URI to be params["myCompanyLogo"]. I
>> --floor
>>>this is a FAQ in the uncategorized section, but the answer doesn't spell
>>>it out well enough for me I guess.
>>> Thanks in advance,
>>> Floor
Previous Topic:Review BIRT 2.0 feature - Dynamic Parameter Selection (BPS 14 )
Next Topic:a error!help
Current Time: Tue Jul 22 15:28:01 EDT 2025
Powered by FUDForum. Page generated in 0.04145 seconds
