Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Newbie: teneo configuration question
Newbie: teneo configuration question [message #76302] Thu, 22 March 2007 13:49 Go to next message
I get this error when I generate EMF-JDO/JPOX OR Mapping (superclass):
The java class is not found: javax.jdo.JDOUnsupportedOptionException
I'm using Eclipse 3.3, EMF 2.3 and jre5.
I did the following steps:
1) Followed the library.xsd tutorial (Step 4 didn't work here)
2) Added EMF 2.3, Teneo EMF persistency and EMF-JPOX plugin using the
update manager, downloaded jpox-1.1.7 and jpox-enhancer-1.1.7.jar and
included them in a plugin called jpox_1.1.7 with the manifest changes.
3) Updated the plugin.xml of the model and editor with the changes listed
in elver.org install instructions. Enable jpox support.
Am I missing a step? Thanks
Julia
Re: Newbie: teneo configuration question [message #76322 is a reply to message #76302] Thu, 22 March 2007 13:57 Go to previous message
Hi Julia,
Did you also download the dependencies of jpox and placed them in the same plugin as the jpox jars
(and added the packages to the runtime/export of the plugin)?
See here for the dependencies:
http://www.jpox.org/docs/1_1/dependencies.html
gr. Martin
> listed in elver.org install instructions. Enable jpox support.
> Julia
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Newbie: teneo configuration question [message #603806 is a reply to message #76302] Thu, 22 March 2007 13:57 Go to previous message
Hi Julia,
gr. Martin
> Julia
The Netherlands
Previous Topic:Newbie: teneo configuration question
Next Topic:[Teneo]Supported DB vendor/versions
Current Time: Mon Jul 21 21:46:07 EDT 2025
Powered by FUDForum. Page generated in 0.03281 seconds
