Re: Installing on Eclipse 3.4 [message #76260 is a reply to message #76245] |
Thu, 17 July 2008 18:26   |
Originally posted by: codeslave.ca.ibm.com
Try it and see. :)
Glen wrote:
> I understand that I must use 2.0 on Ganymede, so must I use the latest
> integration build? Is it fairly stable?
Re: Installing on Eclipse 3.4 [message #76414 is a reply to message #76245] |
Fri, 18 July 2008 21:26   |
Originally posted by: germand.mx1.ibm.com
Hi all,
I haven't been able to make it work under 3.4/Windows, I followed the
installation instructions on the website, and started a -clean launch for
Eclipse.
Whenever I open the PHP Prespective I get a
java.lang.NullPointerException at
org.eclipse.dltk.core.DLTKContentTypeManager.isValidResource ForContentType(DLTKContentTypeManager.java:138)
on the PHP Explorer panel, the PHP Project Outline panel.
I cannot create a PHP Project either. And in the Preferences Window, when
trying to access PHP prefs, I also get an exception.
Right now I'm using version N20080717 and the same problem happened with
the Integration build dated on 20080717.
Is it maybe I have something wrong configured? Or perhaps some plug-ins
are in conflict?
Thanks in advance.
Re: Installing on Eclipse 3.4 [message #76949 is a reply to message #76443] |
Thu, 24 July 2008 11:29   |
Originally posted by: dont.care.com
>> I'm using 2.0.0 Nightly Build: N20080717 should I use 2.0.0 Integration
>> Build? btw, I have an error with 2.0.0 Nightly Build: N20080717 when I try
>> to open a PHP file:
>> An internal error occurred during: "Selection Job titile".
org.eclipse.dltk.core.SourceParserUtil.getModuleDeclaration( Lorg/eclipse/dltk/core/ISourceModule;)Lorg/eclipse/dltk/ast/ declarations/ModuleDeclaration;
I've got this problem too. But with Integration Build I20080722.
Re: Installing on Eclipse 3.4 [message #77559 is a reply to message #76245] |
Fri, 01 August 2008 12:25   |
Originally posted by: quasar.ja.rosz.org
So, i have a question about this.
If i read here:
http://wiki.eclipse.org/PDT/Installation
it claims installation is very simple - just install the package.
However, based on some other information i've seen around, and what has
been said on this thread, it sounds like you actually have to install some
of the extras (all of them?) such as those listed on the page about the
specific build (ie,
http://download.eclipse.org/tools/pdt/downloads/release.php? release=I20080722).
Things like EMF, XSD, GEF, DLTK? This seems like a lot to install, but i
can give it a shot if it's needed.
I followed the wiki instructions and it kinda works, but gives the
"Selection Job title" error whenever i open a .php file.
Thanks for any input!
Quasar
Re: Installing on Eclipse 3.4 [message #77634 is a reply to message #77575] |
Sat, 02 August 2008 20:03  |
Originally posted by: tefl.ebcidiomas.com
Standard install Ganymede with PDT 2 gave me the section titile error.
I installed dltk-I-I200807211242-200807211242-incubation and it went away
(R1.0 Mon, 21 Jul 2008 -- 12:42 (UTC))
This version and later versions can be found at
http://download.eclipse.org/technology/dltk/downloads/ in the Integration
downloads section.
Windows install procedure: download and unzip the file then start eclipse,
then click help, software updates, add site, local then browse to the
directory where you unzipped the file. Click OK until the install starts.
If you get the message that the DLTK is already installed and that Eclipse
will update what you've got, click OK and continue until prompted to
restart. Do the restart and PDT should now work without the section titile
error.
FUDForum. Page generated in 0.02743 seconds
