Home » Eclipse Projects » GEF » Feedback on connection anchors
Feedback on connection anchors [message #76244] Tue, 22 April 2003 13:01 Go to next message
For a part that has multiple connection anchors, I would like to display
feedback to the user (say higlight a small square in red) when the user
is dragging the connection tool over an anchor location.
Where is the best place to do that: in getSourceConnectionAnchor(Request
request)/getTargetConnectionAnchor(Request request)?
How do I - properly - generate the event to repaint the figure with the
anchor highlighted?
Many thanks
Bruno
Re: Feedback on connection anchors [message #76295 is a reply to message #76244] Tue, 22 April 2003 18:13 Go to previous message
The best place is in your NodeEditPolicy.showFeedback(Request)
and eraseFeedback(..) methods.
If you figure has some helper API on it like "highlightAnchor(int index)",
then the implementation of that might call the repaint() method on the
figure (which triggers a paint(Graphics) ). You could also use the feedback
layer to place a highlight figure anywhere you want, including outside the
bounds of the node. This is useful if you want the highlight to be slightly
larger than the ?anchor.
"Bruno Grieder" <bgrieder@quadrem.com> wrote in message
news:b83rpa$672$1@rogue.oti.com...
> anchor highlighted?
> Many thanks
> Bruno
Previous Topic:hit testing on drop in container nodes
Next Topic:painting Grid
Current Time: Sun Aug 31 23:25:14 EDT 2025
Powered by FUDForum. Page generated in 0.04643 seconds
