Home » Language IDEs » Java Development Tools (JDT) » Re: Source locator does not exist. Error message
Re: Source locator does not exist. Error message [message #76237] Tue, 15 July 2003 14:28
Originally posted by: bdangelo.stanford.edu
The exact same problem came up for me, and I just got it go away, but I
don't know if it's a jdt problem or what. I had the same error message
when trying to run the run-time workbench, with no properties for the
error message, and I noticed the same behavior of the regular workbench's
preferences page showing up blank the first time then not at all after
that. This was all using Eclipse 2.1.1 on Windows XP (same java version
as Charalampos, though, 1.4.1_03).
The problem went away when I renamed my main Eclipse directory (and it
continues to work having renamed it back). Can anyone think of why this
would be?
-- Ben
P.S. I had Eclipse 2.1.0 around, and it worked fine the whole time while
2.1.1 wasn't working.
On Mon, 07 Jul 2003 19:53:00 +0000, Charalampos Alexopoulos wrote:
> Hello
> Im not sure if this is the right place for my problem, if its not please
> somebody to tell me where i have to write.
> I start to work with eclipse just a couple of weeks and so far
> everythink is nice.But today when im trying to run my project i have the
> message:
> Exception occured during launch
> Reason:
> Source locator does not exist:
> org.eclipse.jdt.debug.ui.javaSourceLocator
> I run the project a couple of hours before with no problem. Nothing
> change in the project nor to eclipse nor to my computer in between.I try
> to see if the problem comes from project properties but i have a message
> said that there is no properties for this project,I also try to check
> preferences but i have an empty preference dialog, i close the dialog
> and i try to reopen it but the preference dialog is not opening any
> more.I remove eclipse from my computer and install it again to the same
> directory with exactly the same results.
> I use eclipse for gtk version 2.1.0 with build ID 200306051737 in SUSE
> 8.1 Linux
> Sun Java SDK 1.4.1_03
> Sorry for my english.
> Thanks in advance
Previous Topic:How can I turn on auto-complete feature
Next Topic:Format ICompilationUnit?
Current Time: Mon Jul 21 21:20:09 EDT 2025
Powered by FUDForum. Page generated in 0.04776 seconds
