Makefiles and migrating to Eclipse [message #76201] |
Tue, 17 June 2003 07:51  |
Originally posted by: meghani.strandgenomics.com
We have a Java/Swing project that was entirely built using vi and makefiles
We wish to port the entire project to Eclipse (read: use eclipse as an IDE)
However we find that we are not able to use our makefiles (which used to
perform some specific tasks)
How can we work around this problem?
Shripal
Re: Makefiles and migrating to Eclipse [message #76377 is a reply to message #76216] |
Tue, 17 June 2003 10:48   |
Originally posted by: kalabp.netscape.net
Depending on how many makefiles you have, you may be able to create simple
Ant build.xml files which simply exec make. This would be a bit quicker than
actually rewriting your makefiles.
Peter
"Stelian Iancu" <stelian.iancu@gmx.net> wrote in message
news:oprqwu25na9svh55@news.gmx.net...
> On Tue, 17 Jun 2003 17:21:19 +0530, Shripal Meghani
> <meghani@strandgenomics.com> wrote:
> > Hi,
> > makefiles
> > IDE)
> > Shripal
> Well, AFAIK, you will not be able to use those makefiles from within
> Eclipse, as it has no direct support for those. Maybe you can use an Ant
> build file to perform those specific tasks. Eclipse integrates very nice
> with Ant.
> For information regarding Eclipse and Ant, see the Eclipse help. For
> information about Ant, see http://ant.apache.org/
> Stelian Iancu
> Linux Registered User 287835
> Be different. Think.
Re: Makefiles and migrating to Eclipse [message #76392 is a reply to message #76377] |
Tue, 17 June 2003 11:01   |
The problem is that most of the project was made on Linux using makefiles...
Now some of us are using cygwin to emulate linux on windows.
Some of both Linux and Windows users want to use eclipse...
the makefiles remain the same (more or less, only some library related
things change)
1. Does windows have a compatible make? (NMAKE is giving some errors)
2. How can I force Eclipse to run a make inside cygwin?
"Kalab, Peter" <kalabp@netscape.net> wrote in message
news:bcn9n1$g5v$1@rogue.oti.com...
than
> Peter
> > > Hi,
> > > makefiles
> > > IDE)
to
> > > Shripal
> > with Ant.
> > Stelian Iancu
Re: Makefiles and migrating to Eclipse [message #76692 is a reply to message #76392] |
Tue, 17 June 2003 14:11   |
As long as cygwin is in your path on Windows, you should be able to launch
cygwin commands from Eclipse. As an alternative to creating an Ant build.xml
file which uses the <exec> task to launch make, you could configure Eclipse
to run make directly using the external tools launcher. You may have to
configure Eclipse to run bash as the external tool and pass your make
command on the bash command line (e.g. the external program to launch is
bash, and the command line passed by Eclipse will be "-c make") to set up
the environment for make. Unfortunately I think you will have to experiment
with the external tool configuration to get this to work correctly, but it
should be possible.
Something else which may be worth trying is the Eclipse C/C++ IDE (CDT:
http://www.eclipse.org/cdt/) which supports make for building, but I don't
know how it would work with Java files.
Peter
"Shripal Meghani" <meghani@strandgenomics.com> wrote in message
news:bcnagg$h65$1@rogue.oti.com...
makefiles...
> things change)
simple
> than
> > Peter
> > > > Hi,
> > > > makefiles
an
> > > > IDE)
used
> to
> > > > Shripal
Ant
nice
> > > with Ant.
> > > Stelian Iancu
FUDForum. Page generated in 0.04528 seconds
